Environment:
Running pihole on a Debian 11 xcp-ng VM with 6gb RAM and with 89% vm disk space available. Pihole versions:
Pi-hole [v5.17.2]
FTL [v5.23]
Web Interface [v5.21]
Everything works well for one to several days before breaking. When it breaks, DNS, DHCP, and web interface all stop responding. Restarting pihole-FTL service seems to make functional again.
https://tricorder.pi-hole.net/uhr7Dhcs/
Unfortunately this was taken after the service restart since I didn't find the pihole -d command until after I had restarted the service. Perhaps waiting until it happens again and running this while the problem exists would be helpful.
Additional details and logs:
The logs I've checked seem to show little helpful info:
pihole.log
Jan 1 06:12:31 dnsmasq[519]: query[A] rr4---sn-vgqsrnz6.googlevideo.com from 172.23.2.163
Jan 1 06:34:11 dnsmasq[95853]: started, version pi-hole-v2.89-9461807 cachesize 10000
pihole-FTL.log
[2024-01-01 06:10:00.078 519/T887] Notice: Database size is 857.99 MB, deleted 75 rows
[2024-01-01 06:34:11.308 95853M] Using log file /var/log/pihole/FTL.log
journalctl -u pihole-FTL
Dec 28 13:19:25 dns01 pihole-FTL[519]: [2023-12-28 13:19:25.838 519M] Creating mutex
Dec 28 13:19:26 dns01 pihole-FTL[519]: [2023-1
Jan 01 06:34:01 dns01 systemd[1]: Stopping Pi-hole FTL...
Jan 01 06:34:11 dns01 systemd[1]: pihole-FTL.service: State 'stop-sigterm' timed out. Killing.
As you may be able to see, I restarted the pihole-FTL service at approximately 6:34am this morning. Everything (from a user perspective) was functioning from when I woke up at about 4am until shortly (10-20 minutes) before restarting the service.
I suppose I could create a cron job to restart the service but I'd rather figure out what's happening and try to correct it. In my research, I found some others having issues with the pihole-FTL.db. AFAICT the db reports as "ok" when running:
sqlite3 /etc/pihole/pihole-FTL.db "pragma integrity_check;"
Any thoughts or suggestions on next steps to figure out what's going on here?
