Pihole only blocks ads shortly after resetting router, then hangs.
ads stop being blocked, resetting router will allow them to be blocked for a moment, and then it stops blocking again.ads should be being blocked.
ads are not being blocked unless I restart my router, then it only blocks them for a short time. I have replaced the SD card, replaced power supply with the official one, and reinstalled pihole fresh
https://tricorder.pi-hole.net/w5yhafzrz2
You have a few problems right from the bat ...
as in:
   192.168.0.16/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
   2601:803:8080:1910:6e33:d25f:af20:ceee does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
   fe80::d4b0:7638:b871:7beb does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
You should probably run a pihole -r
Also, one thing to keep in mind is that if IPV4 and IPV6 are both present, IPV6 is preferred over IPV4 and hence, your DNS requests are going through an IPV6 DNS that's definitely not Pi-hole.
I appreciate your help. I'll see what I can do.
