So I've trying to get pihole and pivpn setup on a vps from vultr, everything installs fine with no visible errors but when I connect to the dns manually or with pivpn I get no internet on my devices
It used to work perfectly fine, been using the exact same setup for the past few months with no issues.. messed up some files on the vps on my end and had to reset it.. doesnt work since
Tested on both windows pc and android phone.
VPS is running ubuntu 20.04
Ignore the CORS error.. its cause of nginx reverse proxy which I've fixed
