Hi, this is my first post, so please let me know if it is incomplete.
I recently installed PiHole on my Raspberry Pi 4 that already had the Raspbx image on it. I had to move the admin folder after install so it would not interfere with the FreePBX admin GUI and it all seems to be working well EXCEPT to logon to the Admin GUI.
I followed the install bash script steps and let it install default, no changes to using Lighttpd or such. I just changed the port to 8081 and then moved the admin folder.
I reconfigured in the lighttpd file to point to the new folder, changed the permissions and it is all running fine.
The issue is when I click on Login, nothing happens. When I click the CTRL-RETURN on the login screen, I get in, but with an error:
Error
There was a problem applying your settings.
Debugging information:
PHP error (2): session_regenerate_id(): Session write failed. ID: files (path: /var/lib/php/sessions) in /var/www/pihole/admin/scripts/pi-hole/php/password.php:69
I assumed it was a permission issue so I created a user group and put the www-data as well as the FreePBX users in it and granted permission on the /var/lib/php/sessions folder to that group and put 755 on it. The error continues.
I am not an experienced Linux user, but I know a bit. I am not sure what I need to do to resolve this. Some info on the directory:
root@raspbx:~# stat /var/lib/php/sessions
File: /var/lib/php/sessions
Size: 4096 Blocks: 16 IO Block: 4096 directory
Device: b302h/45826d Inode: 3518 Links: 2
Access: (2777/drwxrwsrwx) Uid: ( 0/ root) Gid: ( 1002/ admins)
Access: 2019-09-22 19:32:10.000000000 +0100
Modify: 2021-07-12 10:11:24.177001354 +0100
Change: 2021-07-12 10:16:00.955377414 +0100
Birth: -
Any help would be appreciated.
Aecio Lemos
