Ads get blocked
Ads don't get blocked. Spinner on the /admin keeps spinning
l87ezdtyxg
Ads get blocked
l87ezdtyxg
what's the status of:
systemctl status dnsmasq
systemctl status pihole-FTL.service
also are there any errors in /var/log/lighttpd/error.log ?
Here is the output
[kus@localhost ~]$ systemctl status dnsmasq
● dnsmasq.service - DNS caching server.
Loaded: loaded (/usr/lib/systemd/system/dnsmasq.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2018-06-29 16:20:19 EDT; 21min ago
Main PID: 5483 (dnsmasq)
Tasks: 1 (limit: 1720)
Memory: 15.8M
CGroup: /system.slice/dnsmasq.service
└─5483 /usr/sbin/dnsmasq -k
Jun 29 16:20:19 localhost.localdomain systemd[1]: Started DNS caching server..
[kus@localhost ~]$ systemctl status pihole-FTL.service
Loaded: loaded (/etc/rc.d/init.d/pihole-FTL; generated)
Active: active (exited) since Fri 2018-06-29 15:45:58 EDT; 55min ago
Process: 924 ExecStart=/etc/rc.d/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Jun 29 15:45:45 localhost.localdomain systemd[1]: Starting LSB: pihole-FTL daemon...
Jun 29 15:45:45 localhost.localdomain pihole-FTL[924]: Not running
Jun 29 15:45:46 localhost.localdomain pihole-FTL[924]: rm: cannot remove '/var/run/pihole/FTL.sock': No such file or directory
Jun 29 15:45:51 localhost.localdomain su[971]: (to pihole) root on none
Jun 29 15:45:58 localhost.localdomain pihole-FTL[924]: FTL started!
Jun 29 15:45:58 localhost.localdomain systemd[1]: Started LSB: pihole-FTL daemon.
[kus@localhost ~]$ cat /var/log/lighttpd/error.log
cat: /var/log/lighttpd/error.log: Permission denied
[kus@localhost ~]$ sudo cat /var/log/lighttpd/error.log
[sudo] password for kus:
Sorry, try again.
Sorry, try again.
2018-06-29 15:45:45: (server.c.1423) server started (lighttpd/1.4.49)
2018-06-29 15:47:08: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:47:08: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:47:08: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:47:08: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 15:47:41: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:47:41: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:47:41: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:47:41: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 15:47:42: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:47:42: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:47:42: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:47:42: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 15:47:48: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:47:48: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:47:48: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:47:48: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 15:52:40: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:52:40: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:52:40: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:52:40: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 15:53:00: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:53:00: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:53:00: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:53:00: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 15:53:01: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:53:01: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:53:01: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:53:01: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 15:54:26: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:54:26: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:54:26: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:54:26: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 15:54:31: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:54:31: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:54:31: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:54:31: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 15:54:45: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:54:45: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:54:45: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:54:45: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 15:57:38: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:57:38: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:57:38: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:57:38: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 15:57:39: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 15:57:39: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 15:57:39: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 15:57:39: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:00:32: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:00:32: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:00:32: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:00:32: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:00:33: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:00:33: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:00:33: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:00:33: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:01:33: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:01:33: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:01:33: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:01:33: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:01:37: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:01:37: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:01:37: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:01:37: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:02:34: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:02:34: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:02:34: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:02:34: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:02:38: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:02:38: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:02:38: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:02:38: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:03:33: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:03:33: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:03:33: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:03:33: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:03:34: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:03:34: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:03:34: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:03:34: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:04:24: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:04:24: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:04:24: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:04:24: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:05:51: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:05:51: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:05:51: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:05:51: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:06:52: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:06:52: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:06:52: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:06:52: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:07:07: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:07:07: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:07:07: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:07:07: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:12:07: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:12:07: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:12:07: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:12:07: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:12:21: (mod_fastcgi.c.434) FastCGI-stderr: PHP Warning: parse_ini_file(/etc/pihole/pihole-FTL.conf): failed to open stream: No such file or directory in /var/www/html/admin/api_db.php on line 21
2018-06-29 16:12:21: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api_db.php:329
2018-06-29 16:12:21: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:12:21: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:12:21: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api_db.php on line 329
2018-06-29 16:12:28: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/scripts/pi-hole/php/get.php:77
2018-06-29 16:12:28: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:12:28: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:12:28: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/scripts/pi-hole/php/get.php on line 77
2018-06-29 16:12:34: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/scripts/pi-hole/php/get.php:77
2018-06-29 16:12:34: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:12:34: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:12:34: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/scripts/pi-hole/php/get.php on line 77
2018-06-29 16:12:38: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/scripts/pi-hole/php/get.php:77
2018-06-29 16:12:38: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:12:38: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:12:38: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/scripts/pi-hole/php/get.php on line 77
2018-06-29 16:13:28: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:13:28: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:13:28: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:13:28: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:13:53: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:13:53: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:13:53: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:13:53: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:13:54: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:13:54: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:13:54: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:13:54: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:14:54: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:14:54: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:14:54: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:14:54: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:15:55: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:15:55: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:15:55: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:15:55: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:16:24: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:16:24: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:16:24: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:16:24: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:17:24: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:17:24: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:17:24: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:17:24: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:18:25: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:18:25: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:18:25: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:18:25: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:20:02: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:20:02: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:02: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:02: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:20:03: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:20:03: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:03: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:03: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:20:09: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:20:09: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:09: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:09: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:20:26: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:20:26: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:26: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:26: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:20:42: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/api.php:100
2018-06-29 16:20:42: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:42: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:42: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/api.php on line 100
2018-06-29 16:20:49: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/scripts/pi-hole/php/tailLog.php:46
2018-06-29 16:20:49: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:49: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:49: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/scripts/pi-hole/php/tailLog.php on line 46
2018-06-29 16:20:50: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/scripts/pi-hole/php/tailLog.php:46
2018-06-29 16:20:50: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:50: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:50: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/scripts/pi-hole/php/tailLog.php on line 46
2018-06-29 16:20:51: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/scripts/pi-hole/php/tailLog.php:46
2018-06-29 16:20:51: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:51: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:51: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/scripts/pi-hole/php/tailLog.php on line 46
2018-06-29 16:20:52: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/scripts/pi-hole/php/tailLog.php:46
2018-06-29 16:20:52: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:52: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:52: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/scripts/pi-hole/php/tailLog.php on line 46
2018-06-29 16:20:53: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/scripts/pi-hole/php/tailLog.php:46
2018-06-29 16:20:53: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:53: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:53: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/scripts/pi-hole/php/tailLog.php on line 46
2018-06-29 16:20:54: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/scripts/pi-hole/php/tailLog.php:46
2018-06-29 16:20:54: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:54: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:54: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/scripts/pi-hole/php/tailLog.php on line 46
2018-06-29 16:20:55: (mod_fastcgi.c.434) FastCGI-stderr: PHP Fatal error: Uncaught Error: Call to undefined function json_encode() in /var/www/html/admin/scripts/pi-hole/php/tailLog.php:46
2018-06-29 16:20:55: (mod_fastcgi.c.434) FastCGI-stderr: Stack trace:
2018-06-29 16:20:55: (mod_fastcgi.c.434) FastCGI-stderr: #0 {main}
2018-06-29 16:20:55: (mod_fastcgi.c.434) FastCGI-stderr: thrown in /var/www/html/admin/scripts/pi-hole/php/tailLog.php on line 46
[kus@localhost ~]$
pihole ftl is not working
Active: active (exited) since Fri 2018-06-29 15:45:58 EDT; 1h 1min ago
Ran -g
[kus@localhost ~]$ pihole -g
[i] Target: raw.githubusercontent.com (hosts)
[i] Target: mirror1.malwaredomains.com (justdomains)
[✓] Status: No changes detected
[i] Target: sysctl.org (hosts)
[i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist)
[i] Target: s3.amazonaws.com (simple_tracking.txt)
[i] Target: s3.amazonaws.com (simple_ad.txt)
[✓] Consolidating blocklists
[✓] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 150808
[✓] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 127570
[i] Nothing to whitelist!
[✓] Parsing domains into hosts format
[✓] Cleaning up stray matter
[✓] Force-reloading DNS service
[✓] DNS service is running
run a php --version to find the PHP version installed on your system.
if it's PHP 7, install json_encode:
sudo yum install php70u-json
run a php -i | grep json and check for json support => enalbled
If it's missing, edit the ini file that shows up there and uncomment ;extension=json.so (remove the ;) and restart lighttpd (sudo systemctl restart lighttpd.service) and try the admin page again.
it is working now. Thank you!
[kus@localhost ~]$ sudo dnf info php-json
Last metadata expiration check: 1:42:56 ago on Fri 29 Jun 2018 03:14:52 PM EDT.
Available Packages
Version : 7.2.7
Release : 1.fc28
Arch : x86_64
Source : php-7.2.7-1.fc28.src.rpm
Repo : updates
Summary : JavaScript Object Notation extension for PHP
URL : http://www.php.net/
License : PHP
Description : The php-json package provides an extension that will add
: support for JavaScript Object Notation (JSON) to PHP.
[kus@localhost ~]$ sudo dnf install php-json
Last metadata expiration check: 1:43:04 ago on Fri 29 Jun 2018 03:14:52 PM EDT.
Dependencies resolved.
Package Arch Version Repository Size
Installing:
php-json x86_64 7.2.7-1.fc28 updates 77 k
Transaction Summary
Install 1 Package
Total download size: 77 k
Installed size: 89 k
Is this ok [y/N]: y
Downloading Packages:
php-json-7.2.7-1.fc28.x86_64.rpm 122 kB/s | 77 kB 00:00
Total 87 kB/s | 77 kB 00:00
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : php-json-7.2.7-1.fc28.x86_64 1/1
Running scriptlet: php-json-7.2.7-1.fc28.x86_64 1/1
Verifying : php-json-7.2.7-1.fc28.x86_64 1/1
Installed:
php-json.x86_64 7.2.7-1.fc28
Complete!
[kus@localhost ~]$ php -i | grep json
/etc/php.d/20-json.ini,
json
json support => enabled
json version => 1.6.0
[kus@localhost ~]$ sudo systemctl restart lighttpd.service
[kus@localhost ~]$ sudo systemctl status lighttpd.service
● lighttpd.service - Lightning Fast Webserver With Light System Requirements
Loaded: loaded (/usr/lib/systemd/system/lighttpd.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2018-06-29 16:59:48 EDT; 6s ago
Main PID: 12713 (lighttpd)
Tasks: 9 (limit: 1720)
Memory: 25.3M
CGroup: /system.slice/lighttpd.service
├─12713 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
├─12716 /usr/bin/php-cgi
├─12717 /usr/bin/php-cgi
├─12718 /usr/bin/php-cgi
├─12719 /usr/bin/php-cgi
├─12721 /usr/bin/php-cgi
├─12722 /usr/bin/php-cgi
├─12723 /usr/bin/php-cgi
└─12724 /usr/bin/php-cgi
Jun 29 16:59:48 localhost.localdomain systemd[1]: Started Lightning Fast Webserver With Light System Requirements.
Active: active (exited) since Fri 2018-06-29 15:45:58 EDT; 1h 14min ago
[kus@localhost ~]$
out of curiosity, are you running fedora on a raspberry pi?
if so, fedora28?
and what window manager?
asking b/c I'd like to get another raspberry if it can handle fed28 with e16 or some other lightweight wm.
Sorry, it is a Thinkpad (I think T400?) with a busted display.
I have 1.5GB RAM on a core2duo processor. I just plugged it in the Ethernet port. I was previously using it to play with docker but figured this was a more productive use.
Where are you located? Would it make sense for you to buy a cheap used desktop instead? Anything with a 64 bit processor (any x86 processor in the last eight years is x86-64, I think). Plug it into your router and ssh into this desktop machine from anywhere on your local network.
