Hi, I'm still having issues.
My current version is:
Pi-hole version is 51673e1 (Latest: v5.17.3)
web version is v5.21 (Latest: null)
FTL version is N/A 5.23 (Latest: v5.25.1)
I'm running the Alpine Linux version by yvelon you can find here: yvelon / pi-hole · GitLab
When I tried to run pihole -g I get:
sqlite3: Error: unknown option: -ni
Use -help for a list of options.
[i] No source list found, or it is empty
[i] Preparing new gravity database...
[✗] Unable to create new database /etc/pihole/gravity.db_temp
[✓] Cleaning up stray matter
[✓] FTL is listening on port 53
[✓] UDP (IPv4)
[✓] TCP (IPv4)
[✓] UDP (IPv6)
[✓] TCP (IPv6)
Looking at gravity.sh, the "double -ni" problem has already been resolved, I only see one "-ni" option.
I have:
php82-sqlite3-8.2.18-r0 x86_64 {php82} (PHP-3.01 BSD-3-Clause LGPL-2.0-or-later MIT Zend-2.0) [installed]
sqlite-3.45.3-r0 x86_64 {sqlite} (blessing) [installed]
sqlite-libs-3.45.3-r0 x86_64 {sqlite} (blessing) [installed]
installed.
Am I running a version of sqlite3 which is too old?
Thanks!
