Pihole should be working and blocking all the ads (with or without Wireguard on) on mobile/other devices
Through an adlist check, the blocking only goes to 52% when wireguard is off and the ads come through. With Wireguard on, everything is normal and blocking is to a level where it should be. The DNS in my router setting point towards my pihole.
I know the solution would be "Keep Wireguard On" but id rather have it be working without using Wireguard in my own home (Saves mobile battery and all that)
Edit: Also, any other tips are welcome. I keep seeing " Warning in dnsmasq
core: using interface eth0 instead". Is this a problem? How do I fix it?
