Pihole not showing index.php blockpage
When i visit a gravity blocked page, display default blockpage
just getting site not found
i found that my router, using ddwrt, uses No DNS Rebind
In order to make the blocked page work, disable it.
But i still get onoy site not found
Are there more options in ddwrt that i need to dis-/enable?
With the update to v4.0 the default blocking behaviour has been changed to NULL as it works better with https. you can read more about the changes Here
