instead of lighttpd
pi-hole admin interface should be available automatically after reboot.
- ubuntu/jammy container on Proxmox
- Mac Mini late 2012
/admin
interface does not start with reboot, after I did apt upgrade
and pihole -up
Seems to work fine after running pihole -d
. Then fails to run on next boot.
pihole -r ran successfully but made no difference I can see.
