- output for the dig command requested below
dig www.google.com 8.8.8.8
; <<>> DiG 9.16.1-Ubuntu <<>> www.google.com 8.8.8.8
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 16446
;www.google.com. IN A
www.google.com. 156 IN A 142.250.204.4
;; Query time: 37 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Tue Oct 12 08:23:04 AEDT 2021
;; MSG SIZE rcvd: 59
- I am using Portainer to manage the docker containers.
Below is the output from Portainer.
"AppArmorProfile": "",
"Args": [],
"Config": {
"AttachStderr": false,
"AttachStdin": false,
"AttachStdout": false,
"Cmd": null,
"Domainname": "",
"Entrypoint": [
"/s6-init"
"Env": [
"ARCH=armv7l",
"DNSMASQ_USER=root",
"DOCKER_REPO=multiarch/debian-debootstrap",
"FTL_CMD=no-daemon",
"IPv6=True",
"PATH=/opt/pihole:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"PHP_ENV_CONFIG=/etc/lighttpd/conf-enabled/15-fastcgi-php.conf",
"PHP_ERROR_LOG=/var/log/lighttpd/error.log",
"PIHOLE_ARCH=arm",
"PIHOLE_INSTALL=/etc/.pihole/automated install/basic-install.sh",
"PIHOLE_TAG=pihole/pihole:2021.09-armhf-buster",
"S6_BEHAVIOUR_IF_STAGE2_FAILS=2",
"S6_KEEP_ENV=1",
"S6_LOGGING=0",
"S6OVERLAY_RELEASE=https://github.com/just-containers/s6-overlay/releases/download/v2.1.0.2/s6-overlay-arm.tar.gz",
"ServerIP=127.0.0.1",
"UBUNTU_SUITE=buster",
"VERSION=v5.3.1",
"CORE_VERSION=",
"WEB_VERSION=",
"FTL_VERSION=",
"PIHOLE_VERSION=2021.10",
"S6_OVERLAY_VERSION=v2.1.0.2",
"TZ=Australia/Melbourne"
"ExposedPorts": {
"443/tcp": {},
"53/tcp": {},
"53/udp": {},
"67/udp": {},
"80/tcp": {}
"Healthcheck": {
"Test": [
"CMD-SHELL",
"dig +norecurse +retry=0 @127.0.0.1 pi.hole || exit 1"
"Hostname": "pihole",
"Image": "pihole/pihole:latest",
"Labels": {
"image": "pihole/pihole:v5.3.1_arm",
"maintainer": "adam@diginc.us",
"org.opencontainers.image.created": "2021-10-01T09:45:51.482Z",
"org.opencontainers.image.description": "Pi-hole in a docker container",
"org.opencontainers.image.licenses": "",
"org.opencontainers.image.revision": "d036e0d0c00b614599e1007e89df6937ff1835f0",
"org.opencontainers.image.source": "https://github.com/pi-hole/docker-pi-hole",
"org.opencontainers.image.title": "docker-pi-hole",
"org.opencontainers.image.url": "https://github.com/pi-hole/docker-pi-hole",
"org.opencontainers.image.version": "2021.10",
"url": "https://www.github.com/pi-hole/docker-pi-hole"
"OnBuild": null,
"OpenStdin": false,
"StdinOnce": false,
"Tty": false,
"User": "",
"Volumes": {
"/etc/dnsmasq.d": {},
"/etc/pihole": {}
"WorkingDir": ""
"Created": "2021-10-10T13:59:27.35158536Z",
"Driver": "overlay2",
"ExecIDs": null,
"GraphDriver": {
"Data": {
"LowerDir": "/var/lib/docker/overlay2/9e51e6fd126e1fc3b5a5fe3182ff1f2e87a923bd9dc16d5d223fa7a8540d74ba-init/diff:/var/lib/docker/overlay2/371fcaabb4bf73dc61502dd27ad299b0f546dc81e41720ff151b857e230f2daf/diff:/var/lib/docker/overlay2/024a529491597800f34773d2e14147157944d1f0132dfbc3a518cc4f25629d82/diff:/var/lib/docker/overlay2/01d5beda623cb2e14e7712ad09a79d0cb14c8c0b73c985e5b5d3e02570355d3c/diff:/var/lib/docker/overlay2/5d75897dcb90f1c22f5fc6fe3358a92ed5bcf0296ebcdb7e8d5d5556fb6785a8/diff:/var/lib/docker/overlay2/d785faed582cb2299098894962682968c6849626335612dbb0a25d2432324be0/diff:/var/lib/docker/overlay2/8f2ac368545e3dc4acb09daf2ef505a626afe72534490f88a81551181f013c34/diff:/var/lib/docker/overlay2/fc6eb3c7bdc56ad8e33e8e9f4cfa1cd3ec7304b48e4aa1014191bd6463388483/diff",
"MergedDir": "/var/lib/docker/overlay2/9e51e6fd126e1fc3b5a5fe3182ff1f2e87a923bd9dc16d5d223fa7a8540d74ba/merged",
"UpperDir": "/var/lib/docker/overlay2/9e51e6fd126e1fc3b5a5fe3182ff1f2e87a923bd9dc16d5d223fa7a8540d74ba/diff",
"WorkDir": "/var/lib/docker/overlay2/9e51e6fd126e1fc3b5a5fe3182ff1f2e87a923bd9dc16d5d223fa7a8540d74ba/work"
"Name": "overlay2"
"HostConfig": {
"AutoRemove": false,
"Binds": [
"/srv/dev-disk-by-uuid-619c3fc1-1e63-4317-9d5c-8b56f73f45d3/AppData/Config/PiHole/DNS:/etc/dnsmasq.d",
"/srv/dev-disk-by-uuid-619c3fc1-1e63-4317-9d5c-8b56f73f45d3/AppData/Config/PiHole:/etc/pihole"
"BlkioDeviceReadBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceWriteIOps": null,
"BlkioWeight": 0,
"BlkioWeightDevice": null,
"CapAdd": [
"AUDIT_WRITE",
"CHOWN",
"DAC_OVERRIDE",
"FOWNER",
"FSETID",
"KILL",
"MKNOD",
"NET_BIND_SERVICE",
"NET_RAW",
"SETFCAP",
"SETGID",
"SETPCAP",
"SETUID",
"SYS_CHROOT"
"CapDrop": [
"AUDIT_CONTROL",
"BLOCK_SUSPEND",
"DAC_READ_SEARCH",
"IPC_LOCK",
"IPC_OWNER",
"LEASE",
"LINUX_IMMUTABLE",
"MAC_ADMIN",
"MAC_OVERRIDE",
"NET_ADMIN",
"NET_BROADCAST",
"SYSLOG",
"SYS_ADMIN",
"SYS_BOOT",
"SYS_MODULE",
"SYS_NICE",
"SYS_PACCT",
"SYS_PTRACE",
"SYS_RAWIO",
"SYS_RESOURCE",
"SYS_TIME",
"SYS_TTY_CONFIG",
"WAKE_ALARM"
"Cgroup": "",
"CgroupParent": "",
"CgroupnsMode": "host",
"ConsoleSize": [
0,
0
"ContainerIDFile": "",
"CpuCount": 0,
"CpuPercent": 0,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpuShares": 0,
"CpusetCpus": "",
"CpusetMems": "",
"DeviceCgroupRules": null,
"DeviceRequests": null,
"Devices": [],
"Dns": [],
"DnsOptions": [],
"DnsSearch": [],
"ExtraHosts": [],
"GroupAdd": null,
"IOMaximumBandwidth": 0,
"IOMaximumIOps": 0,
"IpcMode": "private",
"Isolation": "",
"KernelMemory": 0,
"KernelMemoryTCP": 0,
"Links": null,
"LogConfig": {
"Config": {},
"Type": "json-file"
"MaskedPaths": [
"/proc/asound",
"/proc/acpi",
"/proc/kcore",
"/proc/keys",
"/proc/latency_stats",
"/proc/timer_list",
"/proc/timer_stats",
"/proc/sched_debug",
"/proc/scsi",
"/sys/firmware"
"Memory": 0,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"NanoCpus": 0,
"NetworkMode": "bridge",
"OomKillDisable": null,
"OomScoreAdj": 0,
"PidMode": "",
"PidsLimit": null,
"PortBindings": {
"443/tcp": [
"HostIp": "",
"HostPort": "4443"
"53/tcp": [
"HostIp": "",
"HostPort": "53"
"53/udp": [
"HostIp": "",
"HostPort": "53"
"67/udp": [
"HostIp": "",
"HostPort": "67"
"80/tcp": [
"HostIp": "",
"HostPort": "1010"
"Privileged": false,
"PublishAllPorts": false,
"ReadonlyPaths": [
"/proc/bus",
"/proc/fs",
"/proc/irq",
"/proc/sys",
"/proc/sysrq-trigger"
"ReadonlyRootfs": false,
"RestartPolicy": {
"MaximumRetryCount": 0,
"Name": "unless-stopped"
"Runtime": "runc",
"SecurityOpt": null,
"ShmSize": 67108864,
"UTSMode": "",
"Ulimits": null,
"UsernsMode": "",
"VolumeDriver": "",
"VolumesFrom": null
"HostnamePath": "/var/lib/docker/containers/94a970040479a57f5323d5131d13b416e862c8b9c38a01ea65d82a495b91ebcf/hostname",
"HostsPath": "/var/lib/docker/containers/94a970040479a57f5323d5131d13b416e862c8b9c38a01ea65d82a495b91ebcf/hosts",
"Id": "94a970040479a57f5323d5131d13b416e862c8b9c38a01ea65d82a495b91ebcf",
"Image": "sha256:af1f33379115311a6fc6e6906d9c8564e28ba421a75490d320c1cd6d56a018e4",
"LogPath": "/var/lib/docker/containers/94a970040479a57f5323d5131d13b416e862c8b9c38a01ea65d82a495b91ebcf/94a970040479a57f5323d5131d13b416e862c8b9c38a01ea65d82a495b91ebcf-json.log",
"MountLabel": "",
"Mounts": [
"Destination": "/etc/dnsmasq.d",
"Mode": "",
"Propagation": "rprivate",
"RW": true,
"Source": "/srv/dev-disk-by-uuid-619c3fc1-1e63-4317-9d5c-8b56f73f45d3/AppData/Config/PiHole/DNS",
"Type": "bind"
"Destination": "/etc/pihole",
"Mode": "",
"RW": true,
"Source": "/srv/dev-disk-by-uuid-619c3fc1-1e63-4317-9d5c-8b56f73f45d3/AppData/Config/PiHole",
"Type": "bind"
"Name": "/pihole",
"NetworkSettings": {
"Bridge": "",
"EndpointID": "78b3170a24b9adc980dbf5be1c75f84c089736dcff5cd570807b4f70e152b4eb",
"Gateway": "172.17.0.1",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"HairpinMode": false,
"IPAddress": "172.17.0.4",
"IPPrefixLen": 16,
"IPv6Gateway": "",
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"MacAddress": "02:42:ac:11:00:04",
"Networks": {
"bridge": {
"Aliases": null,
"DriverOpts": null,
"IPAMConfig": {},
"IPPrefixLen": 16,
"IPv6Gateway": "",
"Links": null,
"NetworkID": "5b4cdaf7ff257e1e1375b34f10bfb07be90b86f46f20c7cb94b32bd66e31f5fa"
"Ports": {
"443/tcp": [
"HostIp": "0.0.0.0",
"HostPort": "4443"
"HostIp": "::",
"HostPort": "4443"
"53/tcp": [
"HostPort": "53"
"HostIp": "::",
"HostPort": "53"
"53/udp": [
"HostPort": "53"
"HostIp": "::",
"HostPort": "53"
"67/udp": [
"HostPort": "67"
"HostIp": "::",
"HostPort": "67"
"80/tcp": [
"HostPort": "1010"
"HostIp": "::",
"HostPort": "1010"
"SandboxID": "2956a2b22f2100d009f2c6591c13c49c5f6d2d19a77009296cb53d4d21eb83e6",
"SandboxKey": "/var/run/docker/netns/2956a2b22f21",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null
"Path": "/s6-init",
"Platform": "linux",
"Portainer": {
"ResourceControl": {
"Id": 15,
"ResourceId": "94a970040479a57f5323d5131d13b416e862c8b9c38a01ea65d82a495b91ebcf",
"SubResourceIds": [],
"Type": 1,
"UserAccesses": [],
"TeamAccesses": [],
"Public": false,
"AdministratorsOnly": true,
"System": false
"ProcessLabel": "",
"ResolvConfPath": "/var/lib/docker/containers/94a970040479a57f5323d5131d13b416e862c8b9c38a01ea65d82a495b91ebcf/resolv.conf",
"RestartCount": 0,
"State": {
"Dead": false,
"Error": "",
"ExitCode": 0,
"FinishedAt": "2021-10-11T00:33:09.934651753Z",
"Health": {
"FailingStreak": 0,
"Log": [
"End": "2021-10-12T08:22:06.852157111+11:00",
"ExitCode": 0,
"Output": "\n; <<>> DiG 9.11.5-P4-5.1+deb10u5-Debian <<>> +norecurse +retry=0 @127.0.0.1 pi.hole\n; (1 server found)\n;; global options: +cmd\n;; Got answer:\n;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 27577\n;; flags: qr aa ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1\n\n;; OPT PSEUDOSECTION:\n; EDNS: version: 0, flags:; udp: 4096\n;; QUESTION SECTION:\n;pi.hole.\t\t\tIN\tA\n\n;; ANSWER SECTION:\npi.hole.\t\t0\tIN\tA\t127.0.0.1\n\n;; Query time: 0 msec\n;; SERVER: 127.0.0.1#53(127.0.0.1)\n;; WHEN: Tue Oct 12 08:22:06 AEDT 2021\n;; MSG SIZE rcvd: 52\n\n",
"Start": "2021-10-12T08:22:06.569161745+11:00"
"End": "2021-10-12T08:22:37.168619766+11:00",
"ExitCode": 0,
"Output": "\n; <<>> DiG 9.11.5-P4-5.1+deb10u5-Debian <<>> +norecurse +retry=0 @127.0.0.1 pi.hole\n; (1 server found)\n;; global options: +cmd\n;; Got answer:\n;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 25349\n;; flags: qr aa ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1\n\n;; OPT PSEUDOSECTION:\n; EDNS: version: 0, flags:; udp: 4096\n;; QUESTION SECTION:\n;pi.hole.\t\t\tIN\tA\n\n;; ANSWER SECTION:\npi.hole.\t\t0\tIN\tA\t127.0.0.1\n\n;; Query time: 0 msec\n;; SERVER: 127.0.0.1#53(127.0.0.1)\n;; WHEN: Tue Oct 12 08:22:37 AEDT 2021\n;; MSG SIZE rcvd: 52\n\n",
"Start": "2021-10-12T08:22:36.875139824+11:00"
"End": "2021-10-12T08:23:07.51980967+11:00",
"ExitCode": 0,
"Output": "\n; <<>> DiG 9.11.5-P4-5.1+deb10u5-Debian <<>> +norecurse +retry=0 @127.0.0.1 pi.hole\n; (1 server found)\n;; global options: +cmd\n;; Got answer:\n;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 39186\n;; flags: qr aa ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1\n\n;; OPT PSEUDOSECTION:\n; EDNS: version: 0, flags:; udp: 4096\n;; QUESTION SECTION:\n;pi.hole.\t\t\tIN\tA\n\n;; ANSWER SECTION:\npi.hole.\t\t0\tIN\tA\t127.0.0.1\n\n;; Query time: 0 msec\n;; SERVER: 127.0.0.1#53(127.0.0.1)\n;; WHEN: Tue Oct 12 08:23:07 AEDT 2021\n;; MSG SIZE rcvd: 52\n\n",
"Start": "2021-10-12T08:23:07.189601187+11:00"
"End": "2021-10-12T08:23:37.848270329+11:00",
"ExitCode": 0,
"Output": "\n; <<>> DiG 9.11.5-P4-5.1+deb10u5-Debian <<>> +norecurse +retry=0 @127.0.0.1 pi.hole\n; (1 server found)\n;; global options: +cmd\n;; Got answer:\n;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 53213\n;; flags: qr aa ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1\n\n;; OPT PSEUDOSECTION:\n; EDNS: version: 0, flags:; udp: 4096\n;; QUESTION SECTION:\n;pi.hole.\t\t\tIN\tA\n\n;; ANSWER SECTION:\npi.hole.\t\t0\tIN\tA\t127.0.0.1\n\n;; Query time: 0 msec\n;; SERVER: 127.0.0.1#53(127.0.0.1)\n;; WHEN: Tue Oct 12 08:23:37 AEDT 2021\n;; MSG SIZE rcvd: 52\n\n",
"Start": "2021-10-12T08:23:37.542009575+11:00"
"End": "2021-10-12T08:24:08.245993719+11:00",
"ExitCode": 0,
"Output": "\n; <<>> DiG 9.11.5-P4-5.1+deb10u5-Debian <<>> +norecurse +retry=0 @127.0.0.1 pi.hole\n; (1 server found)\n;; global options: +cmd\n;; Got answer:\n;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 59327\n;; flags: qr aa ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1\n\n;; OPT PSEUDOSECTION:\n; EDNS: version: 0, flags:; udp: 4096\n;; QUESTION SECTION:\n;pi.hole.\t\t\tIN\tA\n\n;; ANSWER SECTION:\npi.hole.\t\t0\tIN\tA\t127.0.0.1\n\n;; Query time: 1 msec\n;; SERVER: 127.0.0.1#53(127.0.0.1)\n;; WHEN: Tue Oct 12 08:24:08 AEDT 2021\n;; MSG SIZE rcvd: 52\n\n",
"Start": "2021-10-12T08:24:07.877185039+11:00"
"Status": "healthy"
"OOMKilled": false,
"Paused": false,
"Pid": 1908,
"Restarting": false,
"Running": true,
"StartedAt": "2021-10-11T00:34:02.128302674Z",
"Status": "running"
