The issue I am facing is that I have one domain that I am using that is not resolving the MX records. The strange thing is that other domains with similar MX records are resolving. I have been through the normal faulting process and confirmed the issue has something to do with the pihole-FTL. When I bypass the pi, the MX record resolves correctly. When I query the bind9 server, it resolves correctly. The issue seems to be when I use the pihole-FTL this domain is not returning a result.
What I am after is some tips about where to look next.
I am using pihole on a raspberry Pi 4 8Gb and bind9 as a recursive server. pihole-FTL is on port 53 and bind is running on local host port 5353.
The pihole is working on a number of domains however there is one domain that is not resolving for some reason. A debug shows no obvious faults with the only error being an IPv6 gateway issue.
Here are the lookups I am using to test:
$ dig alflawyers.com.au MX
; <<>> DiG 9.11.5-P4-5.1+deb10u7-Debian <<>> alflawyers.com.au MX
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 56004
;alflawyers.com.au. IN MX
;; Query time: 0 msec
;; WHEN: Sun Jul 03 10:50:54 AEST 2022
;; MSG SIZE rcvd: 46
$ dig alflawyers.com.au MX -p 5353
; <<>> DiG 9.11.5-P4-5.1+deb10u7-Debian <<>> alflawyers.com.au MX -p 5353
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 43180
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 4, ADDITIONAL: 5
; COOKIE: 77e5a516504a052018be20b262c0e7f8ae751c63b904e04a (good)
alflawyers.com.au. 2321 IN MX 0 alflawyers-com-au.mail.protection.outlook.com.
;; AUTHORITY SECTION:
au. 171473 IN NS r.au.
au. 171473 IN NS t.au.
au. 171473 IN NS s.au.
au. 171473 IN NS q.au.
;; ADDITIONAL SECTION:
q.au. 171473 IN A 65.22.196.1
r.au. 171473 IN A 65.22.197.1
s.au. 171473 IN A 65.22.198.1
t.au. 171473 IN A 65.22.199.1
;; SERVER: 127.0.0.1#5353(127.0.0.1)
;; WHEN: Sun Jul 03 10:51:04 AEST 2022
;; MSG SIZE rcvd: 263
$ dig microsoft.com MX
; <<>> DiG 9.11.5-P4-5.1+deb10u7-Debian <<>> microsoft.com MX
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 1813
;microsoft.com. IN MX
microsoft.com. 2195 IN MX 10 microsoft-com.mail.protection.outlook.com.
;; Query time: 46 msec
;; WHEN: Sun Jul 03 10:54:18 AEST 2022
;; MSG SIZE rcvd: 96
$ dig microsoft.com MX -p 5353
; <<>> DiG 9.11.5-P4-5.1+deb10u7-Debian <<>> microsoft.com MX -p 5353
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 48698
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 4, ADDITIONAL: 2
; COOKIE: b04f27957acb94321fe7066962c0e8c9c2f20d90ca447dca (good)
microsoft.com. 3600 IN MX 10 microsoft-com.mail.protection.outlook.com.
microsoft.com. 172799 IN NS ns4-39.azure-dns.info.
microsoft.com. 172799 IN NS ns1-39.azure-dns.com.
microsoft.com. 172799 IN NS ns3-39.azure-dns.org.
microsoft.com. 172799 IN NS ns2-39.azure-dns.net.
ns1-39.azure-dns.com. 172799 IN A 150.171.10.39
;; Query time: 770 msec
;; WHEN: Sun Jul 03 10:54:33 AEST 2022
;; MSG SIZE rcvd: 274
From another server using the pihole as it's DNS I get:
; <<>> DiG 9.16.30-RH <<>> alflawyers.com.au MX
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 1392
;; Query time: 2 msec
;; SERVER: 192.168.10.2#53(192.168.10.2)
;; WHEN: Sun Jul 03 10:49:44 AEST 2022
]$ dig microsoft.com MX
; <<>> DiG 9.16.30-RH <<>> microsoft.com MX
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 32109
;; WHEN: Sun Jul 03 11:15:56 AEST 2022
No other changes have been made.
Thanks in advance
