Debug token: https://tricorder.pi-hole.net/9x4egmv0z1
Environment:
PiHole deployed in a docker container on my RaspberryPi host.
I've successfully deployed pihole following this guide here http://networktoolbox.de/pi-hole/ but I've changed the port binding as 85:80 and 445:443 as ports 80 and 443 are already in use by Caddy on my host machine (I use caddy to reverse proxy several services). I've not binded port 67 as I am not interested in DHCP functionalities.
Pihole seems to work smoothly as I can access the admin panel and it is correctly filtering the raspberrypi itself web connections.
I want to use PiHole on my Windows laptop so I've changed my DNS1: 192.168.1.66 (LAN ip of the raspberrypi) and DNS2: 8.8.8.8.
Since Windows can't have different DNS for each WiFi connection I'm using the RaspberryPi (with PiHole running) as a primary DNS for when I'm home and the common google DNS as a secondary DNS for the occasions that I'm elsewhere so that the primary will fail and the secondary dns will be used.
My PiHole network panel shows:
(172.17.0.1 is the docker ip)
I'd expect to see my laptop too there.
