I reinstalled Pi-hole after rebooting the raspberry pi zero with a new image (Raspbian), and I kept the same configuration on both the router and the pi, but when I try to connect to the router again it does not give me internet access. Keep the same settings that I had before where if everything worked correctly, that is, I had an internet connection on all my devices. Also none of the devices appear to me as clients.
There should be Internet when I change the DNS server to the pihole ip in the router. Even when it kept the same settings as when everything was working properly.
There isn't internet when I change the primary and only DNS server in the router.
From a client that you believe should be connected to the Pi-Hole for DNS, from the command prompt or terminal on that client (and not via ssh or Putty to the Pi), what is the output of
Factory reset my router, and configure my pc to use the pi-hole dns but when I change it I don't have internet access, it doesn't even appear as a client in the pi-hole interface. I'm using ethernet.
