[I installed Pihole on my raspberry pi 5 with latest version of raspbian as I have done before without issue but this time around it is not blocking any ads. I have an TP-Link Archer A7 router and set the static address of the pi as the DNS server. My pi is connected via ethernet cable directly to the router.]
[No ads being blocked and I do not seen anything hitting the query log as well.]
My old memory card crashed so I had to do a clean install and no other devices are using pihole due to some issue with my configuration which you two have highlighted so just need to find a way to remedy this now.
Try to set Pi-hole IP twice (Primary and Secondary), or set 0.0.0.0 as Secondary.
EDIT:
If your router doesn't allow 0.0.0.0, try to use some unused IP from your network, like 192.168.1.250 or even from a non-existent network, like 192.168.10.100
