Pihole not blocking after upgrade to V5 on Synology DSM FTL offline
Hello,
I run Pihole on my Synology NAS. When I upgraded to V5 it stopped blocking queries. When I check pi-hole diagnosis it says Warning in DNSMAQ core "interface eth0 does not exist" Also FTL is offline.
I have tried added the 5 second delay at startup in the FTL config file and no change.
Here is my debug token. https://tricorder.pi-hole.net/NKMH1nn8/
Thanks in advance for any help and guidance.
You have a connectivity problem:
[✗] No IPv4 address(es) found on the eth0 interface.
[✗] No IPv6 address(es) found on the eth0 interface.
[i] Default IPv4 gateway(s):
     192.168.1.1
   * Pinging first gateway 192.168.1.1...
[i] Default IPv6 gateway(s):
[✗] Failed to resolve  on lo (127.0.0.1)
[✗] Failed to resolve  on ovs_eth0 (192.168.1.213)
[✗] Failed to resolve  on ovs_eth1 (192.168.1.122)
[✗] Failed to resolve  on docker0 (172.17.0.1)
[✗] Failed to resolve  on tun0 (10.8.0.1 peer 10.8.0.2)
[✗] Failed to resolve  on tun1000 (169.254.182.88)
[✓] doubleclick.com is 142.250.69.206 via a remote, public DNS server (8.8.8.8)
Neither of your ethernet ports has an active connection.
Thank you. What causes that? Is there a setting on my router I need to set? The traffic is routing to my pihole from my router. Eth0 is my router's connection to my fiber modem and the outside world. It is a PPPOE connection and Centurylink set it up as a vlan so my vlan address is eth0.201.
