Pihole not blocking ads on client
I set-up a pi-hole as DHCP server, due to unstopable dns in supplier router (KPN experia box, netherlands) (Routers dhcp = off) Normal add blocking behavior, but adds are still visible.
I see some action in the log, but no adds blocked on webpages.
Debug Token: nfqco5kmbo
Please note i'm a beginner in network/linux.
Thanks a lot in advance!
There could be several reasons why you are still seeing ads while you are browsing.
A few things to check:
Make sure your clients are using the Pi-hole IP (as the sole DNS) server.
If your network is set for IPV6 IPs then make sure that the clients use the IPV6 IP of the Pi-hole and not the router (or anything else).
If you don't care about IPV6, you can disable it front he router all the way but keep in mind that if you do that, if a website has an IPV6 address only, you won't be able to access it.
See if analyzing/fixing these issues, resolves your problem.
Thanks for your reply.
I checked IPCONFIG /ALL
It states an another DNS IP 192.168.1.7 than the IP of the PI-HOLE, which is 192.168.2.38.
How to correct this?
My routers DHCP is off, PI-Hole DHCP is on.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Laptop>ipconfig/all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Laptop-PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : lan
Wireless LAN adapter Wireless Network Connection:
   Connection-specific DNS Suffix  . : lan
   Description . . . . . . . . . . . : Intel(R) Centrino(R) Ultimate-N 6300 AGN
   Physical Address. . . . . . . . . : 00-24-D7-52-E9-0C
   Link-local IPv6 Address . . . . . : fe80::11e3:751d:ec79:eb06%15(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.2.38(Preferred)
   Lease Obtained. . . . . . . . . . : Wednesday, August 08, 2018 1:48:23 PM
   Lease Expires . . . . . . . . . . : Thursday, August 09, 2018 1:48:24 PM
   Default Gateway . . . . . . . . . : 192.168.2.254
   DHCP Server . . . . . . . . . . . : 192.168.2.36
   DHCPv6 IAID . . . . . . . . . . . : 436217047
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-9C-8E-12-88-AE-1D-B2-4E-B8
   DNS Servers . . . . . . . . . . . : 192.168.1.7
                                       8.8.8.8
Ethernet adapter Local Area Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . : home
   Description . . . . . . . . . . . : Intel(R) 82577LM Gigabit Network Connecti
on
   Physical Address. . . . . . . . . : *************
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.lan:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Tunnel adapter isatap.home:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
C:\Users\Laptop>
Log from pi-hole
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations.  This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected.  Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2018-08-08:11:58:21 debug log has been initialized.
[i] Core: v4.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.0-0-gddbdb51
[i] Web: v4.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.0-0-gaf8c926
[✓] FTL: vDev-5396fc9 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
*** [ DIAGNOSING ]: dnsmasq version
[i] 340:
[i] 1.4.45
[i] 7.0.30
[✓] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv6l
   192.168.2.36/24 matches the IP found in /etc/pihole/setupVars.conf
   fe80::d2cf:41b6:dd40:9585 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.2.254
   * Pinging 192.168.2.254...
[✓] Gateway responded.
*:22 sshd (IPv4)
*:22 sshd (IPv6)
*:80 lighttpd (IPv4)
*:80 lighttpd (IPv6)
*:53 pihole-FTL (IPv4)
*:53 pihole-FTL (IPv6)
127.0.0.1:4711 pihole-FTL (IPv4)
[::1]:4711 pihole-FTL (IPv6)
[✓] 208.185.87.14.liveadvert.com is 0.0.0.0 via localhost (127.0.0.1)
[✓] 208.185.87.14.liveadvert.com is 0.0.0.0 via Pi-hole (192.168.2.36)
[✓] doubleclick.com is 172.217.17.142 via a remote, public DNS server (8.8.8.8)
[✗] dnsmasq daemon is inactive
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.2.36/24
IPV6_ADDRESS=
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
DHCP_ACTIVE=true
DHCP_START=192.168.2.1
DHCP_END=192.168.2.200
DHCP_ROUTER=192.168.2.254
DHCP_LEASETIME=24
PIHOLE_DOMAIN=lan
DHCP_IPv6=true
DNSMASQ_LISTENING=all
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSSEC=false
CONDITIONAL_FORWARDING=false
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 3039333 Aug  6 19:26 /etc/pihole/gravity.list
   0.0.0.0
   0.r.msn.com
   0.start.bz
   000.0x1f4b0.com
   zzz.clickbank.net
   zzzezeroe.fr
   zzzpooeaz-france.com
   zzzrtrcm2.com
-rw-r--r-- 1 root root 381 Aug  5 19:01 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 46 Aug  6 19:26 /etc/pihole/local.list
   192.168.2.36 raspberrypi
   192.168.2.36 pi.hole
-rw-r--r-- 1 root root 234 Aug  5 19:09 /etc/pihole/logrotate
   /var/log/pihole.log {
   	su root root
   	daily
   	copytruncate
   	rotate 5
   	compress
   	delaycompress
   	notifempty
   	nomail
   /var/log/pihole-FTL.log {
   	su root root
   	weekly
   	copytruncate
   	rotate 3
   	compress
   	delaycompress
   	notifempty
   	nomail
-rw-r--r-- 1 root root 1547 Aug  7 18:51 /etc/dnsmasq.d/01-pihole.conf
   localise-queries
   no-resolv
   cache-size=10000
   log-queries=extra
   local-ttl=2
   log-async
   server=8.8.8.8
   server=8.8.4.4
   domain-needed
   bogus-priv
   except-interface=nonexisting
-rw-r--r-- 1 root root 618 Aug  6 19:16 /etc/dnsmasq.d/02-pihole-dhcp.conf
   dhcp-authoritative
   dhcp-range=192.168.2.1,192.168.2.200,24h
   dhcp-option=option:router,192.168.2.254
   dhcp-leasefile=/etc/pihole/dhcp.leases
   domain=lan
   dhcp-option=option6:dns-server,[::]
   dhcp-range=::100,::1ff,constructor:eth0,ra-names,slaac,24h
   ra-param=*,0,0
-rw-r--r-- 1 root root 3027 Aug  5 19:09 /etc/lighttpd/lighttpd.conf
   server.modules = (
   	"mod_access",
   	"mod_accesslog",
   	"mod_auth",
   	"mod_expire",
   	"mod_compress",
   	"mod_redirect",
   	"mod_setenv",
   	"mod_rewrite"
   server.error-handler-404    = "pihole/index.php"
   server.pid-file             = "/var/run/lighttpd.pid"
   accesslog.filename          = "/var/log/lighttpd/access.log"
   accesslog.format            = "%{%s}t|%V|%r|%s|%b"
   compress.cache-dir          = "/var/cache/lighttpd/compress/"
   compress.filetype           = ( "application/javascript", "text/css", "text/html", "text/plain" )
   include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
   $HTTP["url"] =~ "^/admin/" {
       "X-Frame-Options" => "DENY"
   $HTTP["url"] =~ ".ttf$" {
    url.access-deny = ("")
-rw-r--r-- 1 root root 1496 Aug  5 19:09 /etc/cron.d/pihole
   46 4   * * 7   root    PATH="$PATH:/usr/local/bin/" pihole updateGravity
   00 00   * * *   root    PATH="$PATH:/usr/local/bin/" pihole flush once quiet
   */10 *  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker local
   37 13  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
   @reboot root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 412 Aug  6 09:53 /var/log/lighttpd/error.log
   2018-08-05 19:04:06: (log.c.217) server started
   2018-08-05 19:10:52: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-08-05 19:10:54: (log.c.217) server started
   2018-08-05 19:13:24: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-08-05 19:14:03: (log.c.217) server started
   2018-08-06 09:53:05: (server.c.1828) server stopped by UID = 0 PID = 1
   2018-08-06 09:53:34: (log.c.217) server started
-rw-r--r-- 1 pihole pihole 82 Aug  8 04:00 /var/log/pihole-FTL.log
   [2018-08-08 04:00:04.193] Notice: Increasing overTime struct size from 200 to 300
*** [ DIAGNOSING ]: Locale
LANG=
-rw-r--r-- 1 pihole pihole 3905638 Aug  8 11:58 /var/log/pihole.log
   -----head of pihole.log------
   Aug  8 00:00:05 dnsmasq[15060]: 6037 192.168.2.35/25148 query[A] reports.crashlytics.com from 192.168.2.35
   Aug  8 00:00:05 dnsmasq[15060]: 6037 192.168.2.35/25148 /etc/pihole/gravity.list reports.crashlytics.com is 0.0.0.0
   Aug  8 00:00:06 dnsmasq[15060]: 6038 192.168.2.39/55973 query[A] developer.asustor.com from 192.168.2.39
   Aug  8 00:00:06 dnsmasq[15060]: 6038 192.168.2.39/55973 cached developer.asustor.com is 107.21.242.130
   Aug  8 00:00:06 dnsmasq[15060]: 6039 192.168.2.39/55973 query[AAAA] developer.asustor.com from 192.168.2.39
   Aug  8 00:00:06 dnsmasq[15060]: 6039 192.168.2.39/55973 cached developer.asustor.com is NODATA-IPv6
   Aug  8 00:00:22 dnsmasq[15060]: 6040 192.168.2.39/56998 query[A] developer.asustor.com from 192.168.2.39
   Aug  8 00:00:22 dnsmasq[15060]: 6040 192.168.2.39/56998 cached developer.asustor.com is 107.21.242.130
   Aug  8 00:00:22 dnsmasq[15060]: 6041 192.168.2.39/56998 query[AAAA] developer.asustor.com from 192.168.2.39
   Aug  8 00:00:22 dnsmasq[15060]: 6041 192.168.2.39/56998 cached developer.asustor.com is NODATA-IPv6
   Aug  8 00:00:36 dnsmasq[15060]: 6042 192.168.2.35/10743 query[A] graph.instagram.com from 192.168.2.35
   Aug  8 00:00:36 dnsmasq[15060]: 6042 192.168.2.35/10743 /etc/pihole/gravity.list graph.instagram.com is 0.0.0.0
   Aug  8 00:00:38 dnsmasq[15060]: 6043 192.168.2.39/38143 query[A] developer.asustor.com from 192.168.2.39
   Aug  8 00:00:38 dnsmasq[15060]: 6043 192.168.2.39/38143 cached developer.asustor.com is 107.21.242.130
   Aug  8 00:00:38 dnsmasq[15060]: 6044 192.168.2.39/38143 query[AAAA] developer.asustor.com from 192.168.2.39
   Aug  8 00:00:38 dnsmasq[15060]: 6044 192.168.2.39/38143 cached developer.asustor.com is NODATA-IPv6
   Aug  8 00:00:55 dnsmasq[15060]: 6045 192.168.2.39/43712 query[A] developer.asustor.com from 192.168.2.39
   Aug  8 00:00:55 dnsmasq[15060]: 6045 192.168.2.39/43712 forwarded developer.asustor.com to 8.8.4.4
   Aug  8 00:00:55 dnsmasq[15060]: 6045 192.168.2.39/43712 forwarded developer.asustor.com to 8.8.8.8
   Aug  8 00:00:55 dnsmasq[15060]: 6046 192.168.2.39/43712 query[AAAA] developer.asustor.com from 192.168.2.39
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
* Using openssl for transmission.
[✓] Your debug token is: x76c3dio1n
Your DNS servers are specified manually in your IPV4 properties for that Wireless network card.
With the current settings, your DNS request goes to the (assuming) non working IP (192.168.1.7), that one fails to prove resolution and the request fails over to Google's DNS (8.8.8.8), and you have no ads blocked because, no requests are instructed to be resolved by the Pi-hole DNS.
You need to edit the DNS settings for the network card and either set it to automatic, or correct the IP and remove the Google one.
Here's why (as stated above also) you should use Pi-hole as your sole DNS:
The Pi-hole IP (based on the diagnostic you shared) is 192.168.2.36 not .38 (that's the IP of the Laptop).
Thanks for the support.
Checking every option in the chain i see that my internet company supplied router pushes his DNS in between. I can't figure out how to bypass this w/o buying my one.
