PiHole + Netboot.xyz
I have Pihole setup as my DHCP & DNS. On a separate server I have Netboot.xyz running in a docker container. I've created a dnsmasq entry, 04-netboot.conf, that points to the IP of the docker server. When I run a machine to boot from network it isn't able to get the tftp file.
This is a dnsmasq configuration issue.
You should ask that question at the dnsmasq mailing list.
