PiHole keeps crashing and restarting every 30 mins, causing mobile devices to switch to 4g briefly. Has been happening since install. Tried turning off logging and cleaning up gravity lists (one of the default ones didn't work so hashed out). Doesn't make any difference. Have tried reconfig and also rebuilding the entire solution including OS.
-latest official rasbian
-piZeroW
Have tried number of solutions found on forums including disable logging but nothing helps.
Thanks for the quick reply. Not since I flushed logs today (that seems to stabilise it for a little while)
I do see the caches being grown often. Is this normal? Could this become problematic once it grows.past a certain point?
[2020-08-01 12:59:33.943 17939M] Resizing "/FTL-strings" from 4096 to 8192
[2020-08-01 13:07:46.692 17939M] Resizing "/FTL-dns-cache" from 4096 to 8192
[2020-08-01 13:09:04.534 17939M] Resizing "/FTL-strings" from 8192 to 12288
[2020-08-01 13:21:43.269 17939M] Resizing "/FTL-strings" from 12288 to 16384
[2020-08-01 13:21:43.307 17939M] Resizing "/FTL-dns-cache" from 8192 to 12288
