Hardware: Rapberry PI 5
OS: Linux piholeRPI5 6.6.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.47-1+rpt1 (2024-09-02) aarch64 GNU/Linux
Pihole should show working counters and tables on the dashboard
Pihole is blocking what it should but the dashboard is not showing (queries blocked and percentage blocked is 0).
'Total queries' and 'Domains in adlists' is working fine
Could you upload a fresh debug log and post the token again pls?
They expire after 48 hours and the mods/devs that can review them are all volunteers doing this in their free time.
Your debug log shows many errors related to pialert language switch:
2024-10-05 20:50:23: (mod_fastcgi.c.449) FastCGI-stderr:PHP Warning: Undefined variable $pia_lang_selected in /home/pi/pialert/front/php/server/language_switch.php on line 5
2024-10-05 20:50:30: (mod_fastcgi.c.449) FastCGI-stderr:PHP Warning: Undefined variable $pia_lang_selected in /home/pi/pialert/front/php/server/language_switch.php on line 5
The dashboard is not showing errors. Only the 'queries blocked' and 'percentage blocked' is showing 0 (zero).
That has nothing to do with pialert (but I need to check the language error indeed but that has nothing to do with this I guess).
I just noticed you have a regex to allow everything (.*).
Allow rules always take precedence over block rules.
This means every device using the Default group will never block domains.
You have an entry for your "Local Net" (192.168.175.0/24), setting it in the Default group.
This means all devices in this IP range will allow everything.
Are you sure? Does these blocked domains show up in the Query Log page?
Try nslookup command again, but this time using a domain that you expect to be blocked and look at the Query Log page.
