Operating System (Family and Version) : Debian 12.1 Bookworm
Hardware : Home server HP
Docker compose file or Docker run command : Docker Compose
Docker engine version: 28.1.1
I have a pihole instance installed in a docker container and it is working prety well so far. But i'm having a question regarding the network section. I have around 50 pages of ip adress in addition of my network devices that use pihole. Almost all of them are ipv6 and have zero queries recorded.
I tried delete them but they keep coming back and the list keep growing everyday. I don't know where they come from.
This may indicate a short lifetime for your router's IPv6 prefixes or IPv6 lifetimes.
Also, some OSs set lifetimes for temporary IPv6 addresses as low as 2 hours, i.e. there could be as much as 12 IPv6 addresses per prefix and machines network interfaces a day, in addition to link-local IPv6 addresses and non-temporary IPv6 addresses.
Depending on your router's and individual client's IPv6 configuration, your observation may be expected, as far as IPv6 addresses are concerned.
But as none of those addresses would seem to use Pi-hole for DNS, you may want to check your router's IPv6 DNS details: If your router would advertise its own IPv6 as local DNS server, your IPv6 devices may bypass your Pi-hole via your router.
THanks for your answer,
On my ISP router the IPv6 DNS and IPv6 DHCP are disabled. Pihole is my DNS and my DHCP.
On the Pihole instance, IPv6 (and IPv4) are checked for the DNS settings. And i've enabled also IPv6 in the DHCP settings.
Should i do something more ?
Thanks for your help
