pihole-FTL won't start?
service pihole-FTL start should start the service...
root@raspberrypi:~# service pihole-FTL start
Stopped
rm: cannot remove `/var/run/pihole/FTL.sock': No such file or directory
FTL started!
--> But the service isn't running... I already tried a repair of pihole and nothing changed. Can anyone please give me a hint?
7zd4qjzftn
What's the output of sudo systemctl status pihole-FTL.service ?
Hi RamSet,
i can give you the following:
service pihole-FTL status
/etc/init.d/pihole-FTL: line 73: status: command not found
As systemctl isn’t available on my raspi.
This is a known issue that you can read about more here:
What's the output of pihole -v and cat /etc/os-release
RamSet Moderator
June 14
laserbrain:
pihole-FTL is working, but webmin says the service is not running Help
Despite nice weather today (sunny, 22°C), I finished coding the systemd unit. More details can be found here:
What’s the output of pihole -v and cat /etc/os-release
Okay, you are right, it’s seems to be running:
root@raspberrypi:~# ps fax | grep pihole*
32414 pts/0 S+ 0:00 _ grep pihole*
24459 ? Sl 0:33 /usr/bin/pihole-FTL
root@raspberrypi:~# pihole -v
Pi-hole version is v3.3.1 (Latest: ERROR)
AdminLTE version is v3.3 (Latest: v3.3)
FTL version is v3.0 (Latest: v3.0)
root@raspberrypi:~# cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
NAME="Raspbian GNU/Linux"
VERSION_ID="7"
VERSION="7 (wheezy)"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL=http://www.raspbian.org/RaspbianBugs
But I’m still not seeing any action in the webinterface of pihole about dns requests…
This version of Raspbian is End of Life and no longer supported with the Pi-hole.
You would have to update to a newer (Stretch - Latest) version.
