constanty working pihole
pihole stop working with not apparent reason and only come back after restart raspberry pi or pihole-FTL service
Are there any errors shown in the following logs:
/var/log/pihole.log
/var/log/pihole-FTL.log
/var/log/syslog
Please generate a new debug log, upload and post the token. The first log did not appear to complely upload.
there you go, thank you for your response
DEBUG TOKEN: https://tricorder.pi-hole.net/ohwvk191vr
This debug log shows that Pi-Hole is operating properly. You do have a large number of domains on blocklist, which may be filling memory.
[2019-08-21 10:50:55.984 1003] /etc/pihole/gravity.list: parsed 3895087 domains (took 62099.4 ms)
[2019-08-21 10:59:00.421 1003] Notice: Database size is 372.43 MB, deleted 1810 rows
[2019-08-21 11:59:00.300 1003] Notice: Database size is 372.43 MB, deleted 197 rows
What are the outputs of free
and df -a
when i generate that second debug the pihole was online, in the first try if was offline. the problem is random. it doesnt happen at regular time or regular basics.
here are free and df -a
free
> total used free shared buff/cache available
> Mem: 948304 648476 34428 51420 265400 189296
> Swap: 102396 102388 8
sudo df -a
> Filesystem 1K-blocks Used Available Use% Mounted on
> /dev/root 30094204 17882424 10928736 63% /
> devtmpfs 469544 0 469544 0% /dev
> sysfs 0 0 0 - /sys
> proc 0 0 0 - /proc
> tmpfs 474152 244 473908 1% /dev/shm
> devpts 0 0 0 - /dev/pts
> tmpfs 474152 48272 425880 11% /run
> tmpfs 5120 4 5116 1% /run/lock
> tmpfs 474152 0 474152 0% /sys/fs/cgroup
> cgroup2 0 0 0 - /sys/fs/cgroup/unified
> cgroup 0 0 0 - /sys/fs/cgroup/systemd
> cgroup 0 0 0 - /sys/fs/cgroup/blkio
> cgroup 0 0 0 - /sys/fs/cgroup/cpuset
> cgroup 0 0 0 -/sys/fs/cgroup/cpu,cpuacct
> cgroup 0 0 0 - /sys/fs/cgroup/freezer
> cgroup 0 0 0 - /sys/fs/cgroup/devices
> cgroup 0 0 0 - /sys/fs/cgroup/net_cls
> cgroup 0 0 0 - /sys/fs/cgroup/pids
> cgroup 0 0 0 - /sys/fs/cgroup/memory
> systemd-1 - - - - /proc/sys/fs/binfmt_misc
> sunrpc 0 0 0 - /run/rpc_pipefs
> mqueue 0 0 0 - /dev/mqueue
> debugfs 0 0 0 - /sys/kernel/debug
> configfs 0 0 0 - /sys/kernel/config
> /dev/mmcblk0p1 64456 41488 22968 65% /boot
> binfmt_misc 0 0 0 - /proc/sys/fs/binfmt_misc
> 10.0.0.12:/nfs/Jorge 2879644160 1076525088 1744608064 39% /home/pi/Media
> tmpfs 94828 0 94828 0% /run/user/999
> tmpfs 94828 8 94820 1% /run/user/1000
> gvfsd-fuse 0 0 0 - /run/user/1000/gvfs
> fusectl 0 0 0 - /sys/fs/fuse/connections
Hi jfb
The pihole isn't responding all over again. This is the debug token as right now
DEBUG TOKEN
ux3few75h3
I don't see pihole-FTL listed in the debug log as a running process. What are the outputs of the following from the Pi terminal:
sudo netstat -nltup | grep 'Proto\|:53 \|:5053 \|:5353 \|:8953 \|:67 \|:80 \|:471'
Also check the following logs for errors related to pihole-FTL:
/var/log/pihole.log
/var/log/syslog
The outpot of
> Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
> tcp 0 0 127.0.0.1:4711 0.0.0.0:* LISTEN 1002/pihole-FTL
> tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 634/lighttpd
> tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 1002/pihole-FTL
> tcp6 0 0 ::1:4711 :::* LISTEN 1002/pihole-FTL
> tcp6 0 0 :::80 :::* LISTEN 634/lighttpd
> tcp6 0 0 :::53 :::* LISTEN 1002/pihole-FTL
> udp 0 0 0.0.0.0:53 0.0.0.0:* 1002/pihole-FTL
> udp 0 0 0.0.0.0:5353 0.0.0.0:* 338/avahi-daemon: r
> udp6 0 0 :::53 :::* 1002/pihole-FTL
> udp6 0 0 :::5353 :::* 338/avahi-daemon: r
And i found this in the syslog
> Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892048] Plex Media Serv invoked oom-killer: gfp_mask=0x6200ca(GFP_HIGHUSER_MOVABLE), nodemask=(null), order=0, oom_score_adj=0
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892089] Plex Media Serv cpuset=/ mems_allowed=0
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892105] CPU: 0 PID: 6454 Comm: Plex Media Serv Tainted: G C 4.19.66-v7+ #1253
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892108] Hardware name: BCM2835
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892128] [<80111f38>] (unwind_backtrace) from [<8010d4b0>] (show_stack+0x20/0x24)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892139] [<8010d4b0>] (show_stack) from [<808191e0>] (dump_stack+0xd4/0x118)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892151] [<808191e0>] (dump_stack) from [<8023cee0>] (dump_header+0x80/0x250)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892161] [<8023cee0>] (dump_header) from [<8023c258>] (oom_kill_process+0x358/0x3a8)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892170] [<8023c258>] (oom_kill_process) from [<8023cb88>] (out_of_memory+0x134/0x36c)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892179] [<8023cb88>] (out_of_memory) from [<80242fe0>] (__alloc_pages_nodemask+0x1024/0x1178)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892188] [<80242fe0>] (__alloc_pages_nodemask) from [<802383dc>] (filemap_fault+0x5d0/0x704)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892198] [<802383dc>] (filemap_fault) from [<8036f87c>] (ext4_filemap_fault+0x38/0x4c)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892209] [<8036f87c>] (ext4_filemap_fault) from [<80270fe8>] (__do_fault+0x5c/0x194)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892219] [<80270fe8>] (__do_fault) from [<802758a4>] (handle_mm_fault+0x568/0xd68)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892228] [<802758a4>] (handle_mm_fault) from [<80836e28>] (do_page_fault+0x330/0x3a4)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892238] [<80836e28>] (do_page_fault) from [<8011674c>] (do_PrefetchAbort+0x54/0xd8)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892247] [<8011674c>] (do_PrefetchAbort) from [<80101f24>] (ret_from_exception+0x0/0x1c)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892251] Exception stack(0x826a1fb0 to 0x826a1ff8)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892256] 1fa0: 00000000 0000006d 03581120 0000006d
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892263] 1fc0: 74fc3868 651ecbc8 0356f840 74fc3868 74fc3868 74fc3868 03581140 651ec0c8
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892268] 1fe0: 7028ac90 651ebf80 03559d90 74f274f4 60000010 ffffffff
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892304] Mem-Info:
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892317] active_anon:83501 inactive_anon:101946 isolated_anon:0
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892317] active_file:217 inactive_file:536 isolated_file:3
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892317] unevictable:0 dirty:0 writeback:0 unstable:0
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892317] slab_reclaimable:5762 slab_unreclaimable:12985
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892317] mapped:1914 shmem:7496 pagetables:2051 bounce:0
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892317] free:4077 free_pcp:59 free_cma:27
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892328] Node 0 active_anon:334004kB inactive_anon:407784kB active_file:868kB inactive_file:2144kB unevictable:0kB isolated(anon):0kB isolated(file):12kB mapped:7656kB dirty:0kB writeback:0kB shmem:29984kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892340] Normal free:16308kB min:16384kB low:20480kB high:24576kB active_anon:334004kB inactive_anon:407784kB active_file:948kB inactive_file:2364kB unevictable:0kB writepending:0kB present:970752kB managed:948304kB mlocked:0kB kernel_stack:3264kB pagetables:8204kB bounce:0kB free_pcp:236kB local_pcp:236kB free_cma:108kB
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892342] lowmem_reserve[]: 0 0
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892351] Normal: 2630*4kB (MEHC) 404*8kB (UMEHC) 45*16kB (UMH) 18*32kB (H) 11*64kB (H) 3*128kB (H) 1*256kB (H) 1*512kB (H) 0*1024kB 0*2048kB 0*4096kB = 16904kB
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892403] 9599 total pagecache pages
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892407] 1277 pages in swap cache
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892411] Swap cache stats: add 36559, delete 35282, find 102444/103977
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892413] Free swap = 0kB
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892416] Total swap = 102396kB
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892419] 242688 pages RAM
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892422] 0 pages HighMem/MovableOnly
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892424] 5612 pages reserved
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892427] 2048 pages cma reserved
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892430] Tasks state (memory values in pages):
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892433] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892456] [ 115] 0 115 8877 324 96256 0 0 systemd-journal
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892463] [ 166] 0 166 4702 68 20480 172 -1000 systemd-udevd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892505] [ 303] 119 303 1644 49 14336 38 0 rpcbind
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892511] [ 336] 105 336 1639 58 16384 34 0 avahi-daemon
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892518] [ 337] 111 337 5884 22 18432 35 0 rtkit-daemon
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892525] [ 339] 0 339 3366 87 22528 93 0 systemd-logind
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892532] [ 340] 0 340 16762 398 40960 85 0 udisksd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892539] [ 341] 0 341 2936 54 22528 99 0 alsactl
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892545] [ 349] 0 349 13662 201 34816 41 0 ModemManager
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892552] [ 351] 0 351 6465 301 26624 9 0 rsyslogd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892559] [ 353] 104 353 1899 154 16384 58 -900 dbus-daemon
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892566] [ 354] 65534 354 674 43 10240 1 0 noip2
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892572] [ 360] 0 360 2675 95 18432 8 0 wpa_supplicant
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892579] [ 361] 65534 361 1243 40 16384 13 0 thd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892622] [ 427] 105 427 1606 10 12288 65 0 avahi-daemon
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892629] [ 429] 0 429 9903 305 30720 99 0 polkitd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892635] [ 437] 0 437 2827 75 18432 78 0 wpa_supplicant
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892642] [ 465] 0 465 535 30 10240 1 0 hciattach
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892648] [ 468] 0 468 2452 82 16384 4 0 bluetoothd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892655] [ 469] 0 469 6676 33 22528 49 0 bluealsa
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892662] [ 529] 0 529 740 23 10240 71 0 dhcpcd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892668] [ 531] 1000 531 45670 16353 184320 1320 0 mono
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892675] [ 547] 0 547 2181 0 18432 61 0 vncserver-x11-s
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892681] [ 548] 0 548 484 24 10240 4 0 minissdpd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892688] [ 555] 106 555 2170 71 18432 50 0 ntpd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892694] [ 557] 0 557 2722 37 18432 120 -1000 sshd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892702] [ 558] 112 558 485 0 12288 17 0 sh
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892745] [ 560] 0 560 12298 1266 47104 168 0 vncserver-x11-c
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892752] [ 570] 112 570 106178 4030 206848 2233 0 Plex Media Serv
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892758] [ 580] 108 580 14457 4126 65536 8212 0 rpc.statd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892765] [ 590] 0 590 2080 24 18432 38 0 cron
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892772] [ 607] 0 607 11844 69 30720 113 0 lightdm
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892778] [ 664] 65534 664 636 23 10240 11 0 gdomap
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892785] [ 705] 33 705 2397 42 16384 98 0 lighttpd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892791] [ 757] 0 757 38558 3806 137216 806 0 Xorg
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892798] [ 764] 0 764 1164 25 14336 3 0 agetty
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892805] [ 784] 33 784 46930 956 51200 88 0 php-cgi
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892811] [ 898] 999 898 3664 188 24576 56 0 systemd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892818] [ 969] 999 969 4379 50 24576 444 0 (sd-pam)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892857] [ 986] 116 986 3676 82 24576 81 0 exim4
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892863] [ 998] 33 998 46930 420 38912 84 0 php-cgi
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892870] [ 999] 33 999 46930 420 38912 84 0 php-cgi
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892876] [ 1000] 33 1000 46930 420 38912 84 0 php-cgi
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892883] [ 1001] 33 1001 46930 420 38912 84 0 php-cgi
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892889] [ 1003] 999 1003 89220 75184 327680 240 0 pihole-FTL
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892896] [ 1053] 0 1053 7585 178 24576 5 0 lightdm
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892903] [ 1064] 1000 1064 3665 140 22528 120 0 systemd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892909] [ 1067] 1000 1067 4379 162 24576 331 0 (sd-pam)
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892916] [ 1084] 1000 1084 13628 80 43008 232 0 lxsession
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892923] [ 1093] 1000 1093 1798 72 16384 60 0 dbus-daemon
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.892929] [ 1095] 112 1095 45187 5987 100352 595 0 Plex Script Hos
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893010] [ 1133] 1000 1133 1120 9 14336 69 0 ssh-agent
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893017] [ 1149] 1000 1149 10852 116 28672 39 0 gvfsd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893023] [ 1154] 1000 1154 13627 128 36864 0 0 gvfsd-fuse
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893030] [ 1167] 1000 1167 16074 412 43008 274 0 openbox
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893037] [ 1169] 1000 1169 11783 33 43008 236 0 lxpolkit
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893043] [ 1171] 1000 1171 105938 1330 102400 222 0 lxpanel
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893085] [ 1172] 1000 1172 20317 426 59392 345 0 pcmanfm
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893092] [ 1179] 0 1179 2964 78 20480 53 0 vncagent
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893099] [ 1180] 1000 1180 1120 1 14336 78 0 ssh-agent
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893105] [ 1182] 1000 1182 10112 28 32768 69 0 agent
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893112] [ 1188] 1000 1188 42927 1644 131072 214 0 light-locker
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893118] [ 1201] 1000 1201 111046 828 88064 0 0 pulseaudio
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893125] [ 1203] 1000 1203 8043 307 34816 262 0 vncserverui
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893132] [ 1228] 1000 1228 6498 103 20480 0 0 dconf-service
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893138] [ 1234] 1000 1234 7880 297 40960 184 0 vncserverui
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893145] [ 1239] 1000 1239 24532 331 49152 0 0 gvfs-udisks2-vo
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893152] [ 1245] 1000 1245 14005 180 40960 0 0 gvfs-afc-volume
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893158] [ 1255] 1000 1255 6610 114 20480 0 0 menu-cached
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893198] [ 1261] 1000 1261 10032 101 32768 0 0 gvfs-mtp-volume
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893205] [ 1268] 1000 1268 10424 123 34816 0 0 gvfs-gphoto2-vo
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893212] [ 1279] 1000 1279 10025 80 28672 0 0 gvfs-goa-volume
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893218] [ 1295] 1000 1295 13239 201 34816 0 0 gvfsd-trash
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893225] [ 1302] 1000 1302 7744 83 28672 0 0 gvfsd-metadata
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893232] [ 1362] 1000 1362 21130 1015 71680 0 0 lxterminal
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893239] [ 1372] 1000 1372 2228 247 18432 0 0 bash
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893245] [ 1437] 112 1437 44920 1693 90112 0 0 Plex DLNA Serve
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893252] [ 1440] 112 1440 27124 237 57344 0 0 Plex Tuner Serv
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893258] [ 1517] 1000 1517 57978 21045 176128 673 0 python2.7
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893265] [ 2243] 113 2243 26813 6763 79872 274 0 transmission-da
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893313] [ 6162] 0 6162 2722 147 20480 0 0 sshd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893320] [ 6164] 107 6164 2749 151 20480 0 0 sshd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893327] [ 6185] 112 6185 38853 6274 83968 0 0 Plex Script Hos
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893333] [ 6221] 0 6221 2722 147 20480 0 0 sshd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893340] [ 6263] 112 6263 34583 6416 81920 0 0 Plex Script Hos
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893347] [ 6352] 112 6352 31098 6656 106496 0 0 Plex Media Scan
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893354] [ 6357] 112 6357 32667 3777 77824 0 0 Plex Script Hos
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893361] [ 6366] 0 6366 2722 152 18432 0 0 sshd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893367] [ 6386] 107 6386 2749 151 18432 0 0 sshd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893374] [ 6407] 0 6407 3157 197 20480 0 0 sshd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893380] [ 6419] 0 6419 3157 197 20480 0 0 sshd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893387] [ 6430] 107 6430 2749 162 20480 0 0 sshd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893443] [ 6455] 0 6455 1326 29 10240 0 0 sshd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893451] [ 6456] 0 6456 1124 45 12288 0 0 modprobe
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893457] [ 6457] 0 6457 1124 45 12288 0 0 modprobe
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893478] [ 6459] 0 6459 238 1 8192 0 0 sshd
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893483] Out of memory: Kill process 1003 (pihole-FTL) score 287 or sacrifice child
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.893558] Killed process 1003 (pihole-FTL) total-vm:356880kB, anon-rss:300508kB, file-rss:0kB, shmem-rss:228kB
Aug 23 13:32:49 Jorge-RasPi kernel: [23325.980667] oom_reaper: reaped process 1003 (pihole-FTL), now anon-rss:0kB, file-rss:0kB, shmem-rss:228kB
it seems the cause of stopping the pihole-FTL process
You're out of available memory and Plex is killing what it can to try to save the situation.
A post was split to a new topic: Pi-Hole crashes after fresh install
thank you for your respond, so i need to kill plex? that will fix my problem?
You either need to stop the PLEX process, or fix the memory issue that is causing PLEX to do memory management.
fixing the memory issue is a software thing or hardware?
Plex Server needs way more than 1G RAM. You may be able to increase the size of the swapfile but it's not going to help much. Don't run network critical things like DNS on a small device with memory hungry software.
i have been running pihole and plex for more that a year now, and didnt have this problem before. i suppose it had to be related to the buster upgrade.
i will disable plex and see how it goes
