PiHole FTL: no process found - Fresh install - Ubuntu 20.04 LTS
I tried searching for my issue but most of the posts I saw were from 2018
Pi-hole FTL should be able to start. Tried to reconfigure with -r. Tried to start manually with
$sudo service pihole-FTL start
Nothing is using port 53. Installed dns-crypt proxy to use 5353.
 -$cat /etc/*release*
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION="Ubuntu 20.04 LTS"
NAME="Ubuntu"
VERSION="20.04 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
-hardware: Mid 2012 Macbook Pro (have used with PiHole before successfully)
Cannot access web interface - states Lost connection to API
PiHole FTL shows it is running:
$ sudo service pihole-FTL status
     Active: active (exited) since Tue 2020-07-14 21:40:27 UTC; 4min 25s ago
    Process: 7409 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Jul 14 21:40:26 elder-mac-smash systemd[1]: Starting LSB: pihole-FTL daemon...
Jul 14 21:40:26 elder-mac-smash pihole-FTL[7409]: Not running
Jul 14 21:40:26 elder-mac-smash su[7433]: (to pihole) root on none
Jul 14 21:40:26 elder-mac-smash su[7433]: pam_unix(su:session): session opened for user pihole by (uid=0)
Jul 14 21:40:27 elder-mac-smash su[7433]: pam_unix(su:session): session closed for user pihole
Jul 14 21:40:27 elder-mac-smash systemd[1]: Started LSB: pihole-FTL daemon.
$ pihole status
  [βœ—] DNS service is NOT running
$ pihole disable
  [i] Disabling blocking
  [βœ—] pihole-FTL: no process found
  [βœ“] Pi-hole Disabled
$ pihole enable
  [i] Enabling blocking
  [βœ“] Pi-hole Enabled
$ tail pihole-FTL.log
[2020-07-14 21:40:27.087 7448] Imported 0 queries from the long-term database
[2020-07-14 21:40:27.087 7448]  -> Total DNS queries: 0
[2020-07-14 21:40:27.087 7448]  -> Cached DNS queries: 0
[2020-07-14 21:40:27.087 7448]  -> Forwarded DNS queries: 0
[2020-07-14 21:40:27.087 7448]  -> Blocked DNS queries: 0
[2020-07-14 21:40:27.087 7448]  -> Unknown DNS queries: 0
[2020-07-14 21:40:27.087 7448]  -> Unique domains: 0
[2020-07-14 21:40:27.087 7448]  -> Unique clients: 0
[2020-07-14 21:40:27.087 7448]  -> Known forward destinations: 0
[2020-07-14 21:40:27.087 7448] Successfully accessed setupVars.conf
jorg@elder-mac-smash:/var/log$
Debug token fails to upload:
[βœ—]  There was an error uploading your debug log.
   * A local copy of the debug log can be found at: /var/log/pihole_debug.log
I can upload it somewhere if need be.
Just a note, uninstalled and reinstalled after a reboot:
[i] Target: https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
[βœ“] Status: Retrieval successful
[i] Received 2701 domains
[βœ“] Storing downloaded domains in new gravity database
[βœ“] Building tree
[βœ“] Swapping databases
[i] Number of gravity domains: 87052 (84625 unique domains)
[i] Number of exact blacklisted domains: 0
[i] Number of regex blacklist filters: 0
[i] Number of exact whitelisted domains: 0
[i] Number of regex whitelist filters: 0
[βœ“] Cleaning up stray matter
[βœ“] Restarting DNS server
[i] Web Interface password: 9VVraxZS
[i] This can be changed using 'pihole -a -p'
[i] View the web interface at http://pi.hole/admin or http://192.168.50.3/admin
[i] You may now configure your devices to use the Pi-hole as their DNS server
[i] Pi-hole DNS (IPv4): 192.168.50.3
[i] If you set a new IP address, please restart the server running the Pi-hole
[i] The install log is located at: /etc/pihole/install.log
Installation Complete!
What does
which pihole-FTL
say?
Does
pihole -r
(select Repair) fix it? If not, are there any warnings/errors/etc. shown during the process?
Check if dnsmasq is running and if so, stop it and enable pihole
sudo service dnsmasq status
sudo service dnsmasq stop
sudo service dnsmasq disable
sudo service pihole-FTL enable
Changing this to Community Help, as Ubuntu 20 is not on Pi-hole's list of supported OS.
That does not mean you won't be able to run Pi-hole under Ubuntu 20 - there are users who managed to run it successfully (like @Coro).
~$ which pihole-FTL
/usr/bin/pihole-FTL
jorg@elder-mac-smash:~$
And pihole -r didn't fix it I tried both options and then tried full uninstall and re-install. Do you want me to run again?
:~$ sudo service dnsmasq status
[sudo] password for jorg:
Unit dnsmasq.service could not be found.                                jorg@elder-mac-smash:~$ sudo service pihole-FTL start
jorg@elder-mac-smash:~$ sudo service pihole-FTL enable
Usage: /etc/init.d/pihole-FTL {start|stop|restart|reload|status}        jorg@elder-mac-smash:~$ sudo service pihole-FTL status
     Active: active (exited) since Tue 2020-07-14 22:41:25 UTC; 12h ago        Docs: man:systemd-sysv-generator(8)
      Tasks: 0 (limit: 4515)
     Memory: 0B
Jul 14 22:41:24 elder-mac-smash systemd[1]: Starting LSB: pihole-FTL da>
Jul 14 22:41:24 elder-mac-smash pihole-FTL[4992]: Not running
Jul 14 22:41:24 elder-mac-smash su[5016]: (to pihole) root on none
Jul 14 22:41:24 elder-mac-smash su[5016]: pam_unix(su:session): session>J
ul 14 22:41:25 elder-mac-smash su[5016]: pam_unix(su:session): session>
Jul 14 22:41:25 elder-mac-smash systemd[1]: Started LSB: pihole-FTL dae>
jorg@elder-mac-smash:~$ pihole status
What's the output of
cat /var/log/pihole-FTL.log
There are two logs. The first one is blank.
pihole-FTL.log
pihole-FTL.log.1
$ cat pihole-FTL.log
jorg@elder-mac-smash:/var/log$ cat pihole-FTL.log.1
[2020-07-14 22:29:42.662 4048] Using log file /var/log/pihole-FTL.log
[2020-07-14 22:29:42.662 4048] ########## FTL started! ##########
[2020-07-14 22:29:42.662 4048] FTL branch: master
[2020-07-14 22:29:42.662 4048] FTL version: v5.0
[2020-07-14 22:29:42.662 4048] FTL commit: 3d7c095
[2020-07-14 22:29:42.662 4048] FTL date: 2020-05-10 18:58:38 +0100
[2020-07-14 22:29:42.662 4048] FTL user: pihole
[2020-07-14 22:29:42.662 4048] Compiled for x86_64 (compiled on CI) using gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
[2020-07-14 22:29:42.662 4048] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-07-14 22:29:42.662 4048]    SOCKET_LISTENING: only local
[2020-07-14 22:29:42.662 4048]    AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-07-14 22:29:42.663 4048]    MAXDBDAYS: max age for stored queries is 365 days
[2020-07-14 22:29:42.663 4048]    RESOLVE_IPV6: Resolve IPv6 addresses
[2020-07-14 22:29:42.663 4048]    RESOLVE_IPV4: Resolve IPv4 addresses
[2020-07-14 22:29:42.663 4048]    DBINTERVAL: saving to DB file every minute
[2020-07-14 22:29:42.663 4048]    DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-07-14 22:29:42.663 4048]    MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-07-14 22:29:42.663 4048]    PRIVACYLEVEL: Set to 0
[2020-07-14 22:29:42.663 4048]    IGNORE_LOCALHOST: Show queries from localhost
[2020-07-14 22:29:42.663 4048]    BLOCKINGMODE: Null IPs for blocked domains
[2020-07-14 22:29:42.663 4048]    ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-07-14 22:29:42.663 4048]    DBIMPORT: Importing history from database
[2020-07-14 22:29:42.663 4048]    PIDFILE: Using /var/run/pihole-FTL.pid
[2020-07-14 22:29:42.663 4048]    PORTFILE: Using /var/run/pihole-FTL.port
[2020-07-14 22:29:42.663 4048]    SOCKETFILE: Using /var/run/pihole/FTL.sock
[2020-07-14 22:29:42.663 4048]    SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-07-14 22:29:42.663 4048]    MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-07-14 22:29:42.663 4048]    GRAVITYDB: Using /etc/pihole/gravity.db
[2020-07-14 22:29:42.663 4048]    PARSE_ARP_CACHE: Active
[2020-07-14 22:29:42.663 4048]    CNAME_DEEP_INSPECT: Active
[2020-07-14 22:29:42.663 4048]    DELAY_STARTUP: No delay requested.
[2020-07-14 22:29:42.663 4048]    BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-07-14 22:29:42.663 4048] Finished config file parsing
[2020-07-14 22:29:42.664 4048] No database file found, creating new (empty) database
[2020-07-14 22:29:45.557 4048] Database version is 3
[2020-07-14 22:29:45.557 4048] Updating long-term database to version 4
[2020-07-14 22:29:45.744 4048] Updating long-term database to version 5
[2020-07-14 22:29:46.858 4048] Database successfully initialized
[2020-07-14 22:29:46.859 4048] Imported 0 queries from the long-term database
[2020-07-14 22:29:46.859 4048]  -> Total DNS queries: 0
[2020-07-14 22:29:46.859 4048]  -> Cached DNS queries: 0
[2020-07-14 22:29:46.859 4048]  -> Forwarded DNS queries: 0
[2020-07-14 22:29:46.859 4048]  -> Blocked DNS queries: 0
[2020-07-14 22:29:46.860 4048]  -> Unknown DNS queries: 0
[2020-07-14 22:29:46.860 4048]  -> Unique domains: 0
[2020-07-14 22:29:46.860 4048]  -> Unique clients: 0
[2020-07-14 22:29:46.860 4048]  -> Known forward destinations: 0
[2020-07-14 22:29:46.860 4048] Successfully accessed setupVars.conf
[2020-07-14 22:29:58.729 4361] Using log file /var/log/pihole-FTL.log
[2020-07-14 22:29:58.729 4361] ########## FTL started! ##########
[2020-07-14 22:29:58.729 4361] FTL branch: master
[2020-07-14 22:29:58.729 4361] FTL version: v5.0
[2020-07-14 22:29:58.729 4361] FTL commit: 3d7c095
[2020-07-14 22:29:58.729 4361] FTL date: 2020-05-10 18:58:38 +0100
[2020-07-14 22:29:58.729 4361] FTL user: pihole
[2020-07-14 22:29:58.729 4361] Compiled for x86_64 (compiled on CI) using gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
[2020-07-14 22:29:58.729 4361] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-07-14 22:29:58.729 4361]    SOCKET_LISTENING: only local
[2020-07-14 22:29:58.729 4361]    AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-07-14 22:29:58.729 4361]    MAXDBDAYS: max age for stored queries is 365 days
[2020-07-14 22:29:58.729 4361]    RESOLVE_IPV6: Resolve IPv6 addresses
[2020-07-14 22:29:58.729 4361]    RESOLVE_IPV4: Resolve IPv4 addresses
[2020-07-14 22:29:58.729 4361]    DBINTERVAL: saving to DB file every minute
[2020-07-14 22:29:58.729 4361]    DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-07-14 22:29:58.730 4361]    MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-07-14 22:29:58.730 4361]    PRIVACYLEVEL: Set to 0
[2020-07-14 22:29:58.730 4361]    IGNORE_LOCALHOST: Show queries from localhost
[2020-07-14 22:29:58.730 4361]    BLOCKINGMODE: Null IPs for blocked domains
[2020-07-14 22:29:58.730 4361]    ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-07-14 22:29:58.730 4361]    DBIMPORT: Importing history from database
[2020-07-14 22:29:58.730 4361]    PIDFILE: Using /var/run/pihole-FTL.pid
[2020-07-14 22:29:58.730 4361]    PORTFILE: Using /var/run/pihole-FTL.port
[2020-07-14 22:29:58.730 4361]    SOCKETFILE: Using /var/run/pihole/FTL.sock
[2020-07-14 22:29:58.730 4361]    SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-07-14 22:29:58.730 4361]    MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-07-14 22:29:58.730 4361]    GRAVITYDB: Using /etc/pihole/gravity.db
[2020-07-14 22:29:58.730 4361]    PARSE_ARP_CACHE: Active
[2020-07-14 22:29:58.730 4361]    CNAME_DEEP_INSPECT: Active
[2020-07-14 22:29:58.730 4361]    DELAY_STARTUP: No delay requested.
[2020-07-14 22:29:58.730 4361]    BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-07-14 22:29:58.730 4361] Finished config file parsing
[2020-07-14 22:29:58.731 4361] Database version is 5
[2020-07-14 22:29:58.731 4361] Database successfully initialized
[2020-07-14 22:29:58.731 4361] Imported 0 queries from the long-term database
[2020-07-14 22:29:58.731 4361]  -> Total DNS queries: 0
[2020-07-14 22:29:58.731 4361]  -> Cached DNS queries: 0
[2020-07-14 22:29:58.731 4361]  -> Forwarded DNS queries: 0
[2020-07-14 22:29:58.731 4361]  -> Blocked DNS queries: 0
[2020-07-14 22:29:58.731 4361]  -> Unknown DNS queries: 0
[2020-07-14 22:29:58.731 4361]  -> Unique domains: 0
[2020-07-14 22:29:58.731 4361]  -> Unique clients: 0
[2020-07-14 22:29:58.732 4361]  -> Known forward destinations: 0
[2020-07-14 22:29:58.732 4361] Successfully accessed setupVars.conf
[2020-07-14 22:40:56.619 4884] Using log file /var/log/pihole-FTL.log
[2020-07-14 22:40:56.619 4884] ########## FTL started! ##########
[2020-07-14 22:40:56.619 4884] FTL branch: master
[2020-07-14 22:40:56.619 4884] FTL version: v5.0
[2020-07-14 22:40:56.619 4884] FTL commit: 3d7c095
[2020-07-14 22:40:56.619 4884] FTL date: 2020-05-10 18:58:38 +0100
[2020-07-14 22:40:56.619 4884] FTL user: pihole
[2020-07-14 22:40:56.619 4884] Compiled for x86_64 (compiled on CI) using gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
[2020-07-14 22:40:56.619 4884] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-07-14 22:40:56.619 4884]    SOCKET_LISTENING: only local
[2020-07-14 22:40:56.619 4884]    AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-07-14 22:40:56.619 4884]    MAXDBDAYS: max age for stored queries is 365 days
[2020-07-14 22:40:56.619 4884]    RESOLVE_IPV6: Resolve IPv6 addresses
[2020-07-14 22:40:56.619 4884]    RESOLVE_IPV4: Resolve IPv4 addresses
[2020-07-14 22:40:56.619 4884]    DBINTERVAL: saving to DB file every minute
[2020-07-14 22:40:56.619 4884]    DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-07-14 22:40:56.619 4884]    MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-07-14 22:40:56.619 4884]    PRIVACYLEVEL: Set to 0
[2020-07-14 22:40:56.619 4884]    IGNORE_LOCALHOST: Show queries from localhost
[2020-07-14 22:40:56.619 4884]    BLOCKINGMODE: Null IPs for blocked domains
[2020-07-14 22:40:56.619 4884]    ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-07-14 22:40:56.619 4884]    DBIMPORT: Importing history from database
[2020-07-14 22:40:56.619 4884]    PIDFILE: Using /var/run/pihole-FTL.pid
[2020-07-14 22:40:56.619 4884]    PORTFILE: Using /var/run/pihole-FTL.port
[2020-07-14 22:40:56.619 4884]    SOCKETFILE: Using /var/run/pihole/FTL.sock
[2020-07-14 22:40:56.620 4884]    SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-07-14 22:40:56.620 4884]    MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-07-14 22:40:56.620 4884]    GRAVITYDB: Using /etc/pihole/gravity.db
[2020-07-14 22:40:56.620 4884]    PARSE_ARP_CACHE: Active
[2020-07-14 22:40:56.620 4884]    CNAME_DEEP_INSPECT: Active
[2020-07-14 22:40:56.620 4884]    DELAY_STARTUP: No delay requested.
[2020-07-14 22:40:56.620 4884]    BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-07-14 22:40:56.620 4884] Finished config file parsing
[2020-07-14 22:40:56.622 4884] Database version is 5
[2020-07-14 22:40:56.622 4884] Database successfully initialized
[2020-07-14 22:40:56.622 4884] Imported 0 queries from the long-term database
[2020-07-14 22:40:56.623 4884]  -> Total DNS queries: 0
[2020-07-14 22:40:56.623 4884]  -> Cached DNS queries: 0
[2020-07-14 22:40:56.623 4884]  -> Forwarded DNS queries: 0
[2020-07-14 22:40:56.623 4884]  -> Blocked DNS queries: 0
[2020-07-14 22:40:56.623 4884]  -> Unknown DNS queries: 0
[2020-07-14 22:40:56.623 4884]  -> Unique domains: 0
[2020-07-14 22:40:56.623 4884]  -> Unique clients: 0
[2020-07-14 22:40:56.623 4884]  -> Known forward destinations: 0
[2020-07-14 22:40:56.623 4884] Successfully accessed setupVars.conf
[2020-07-14 22:41:25.072 5030] Using log file /var/log/pihole-FTL.log
[2020-07-14 22:41:25.072 5030] ########## FTL started! ##########
[2020-07-14 22:41:25.072 5030] FTL branch: master
[2020-07-14 22:41:25.072 5030] FTL version: v5.0
[2020-07-14 22:41:25.072 5030] FTL commit: 3d7c095
[2020-07-14 22:41:25.072 5030] FTL date: 2020-05-10 18:58:38 +0100
[2020-07-14 22:41:25.072 5030] FTL user: pihole
[2020-07-14 22:41:25.072 5030] Compiled for x86_64 (compiled on CI) using gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
[2020-07-14 22:41:25.072 5030] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-07-14 22:41:25.073 5030]    SOCKET_LISTENING: only local
[2020-07-14 22:41:25.073 5030]    AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-07-14 22:41:25.073 5030]    MAXDBDAYS: max age for stored queries is 365 days
[2020-07-14 22:41:25.073 5030]    RESOLVE_IPV6: Resolve IPv6 addresses
[2020-07-14 22:41:25.073 5030]    RESOLVE_IPV4: Resolve IPv4 addresses
[2020-07-14 22:41:25.073 5030]    DBINTERVAL: saving to DB file every minute
[2020-07-14 22:41:25.073 5030]    DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-07-14 22:41:25.073 5030]    MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-07-14 22:41:25.073 5030]    PRIVACYLEVEL: Set to 0
[2020-07-14 22:41:25.073 5030]    IGNORE_LOCALHOST: Show queries from localhost
[2020-07-14 22:41:25.073 5030]    BLOCKINGMODE: Null IPs for blocked domains
[2020-07-14 22:41:25.073 5030]    ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-07-14 22:41:25.073 5030]    DBIMPORT: Importing history from database
[2020-07-14 22:41:25.073 5030]    PIDFILE: Using /var/run/pihole-FTL.pid
[2020-07-14 22:41:25.073 5030]    PORTFILE: Using /var/run/pihole-FTL.port
[2020-07-14 22:41:25.073 5030]    SOCKETFILE: Using /var/run/pihole/FTL.sock
[2020-07-14 22:41:25.073 5030]    SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-07-14 22:41:25.073 5030]    MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-07-14 22:41:25.073 5030]    GRAVITYDB: Using /etc/pihole/gravity.db
[2020-07-14 22:41:25.073 5030]    PARSE_ARP_CACHE: Active
[2020-07-14 22:41:25.073 5030]    CNAME_DEEP_INSPECT: Active
[2020-07-14 22:41:25.073 5030]    DELAY_STARTUP: No delay requested.
[2020-07-14 22:41:25.073 5030]    BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-07-14 22:41:25.073 5030] Finished config file parsing
[2020-07-14 22:41:25.074 5030] Database version is 5
[2020-07-14 22:41:25.074 5030] Database successfully initialized
[2020-07-14 22:41:25.074 5030] Imported 0 queries from the long-term database
[2020-07-14 22:41:25.074 5030]  -> Total DNS queries: 0
[2020-07-14 22:41:25.074 5030]  -> Cached DNS queries: 0
[2020-07-14 22:41:25.074 5030]  -> Forwarded DNS queries: 0
[2020-07-14 22:41:25.076 5030]  -> Blocked DNS queries: 0
[2020-07-14 22:41:25.076 5030]  -> Unknown DNS queries: 0
[2020-07-14 22:41:25.076 5030]  -> Unique domains: 0
[2020-07-14 22:41:25.076 5030]  -> Unique clients: 0
[2020-07-14 22:41:25.076 5030]  -> Known forward destinations: 0
[2020-07-14 22:41:25.076 5030] Successfully accessed setupVars.conf
Strange, I see no bug or error - except the frequent restarts of pihole-FTL.
I have no further ideas.... Sorry.
I found this question while trying to troubleshoot the same problem, and you might have already tried this, but after going through all the same stuff as you, I finally thought to run
and it showed NOT RUNNING but then below that, finally, it showed me an error message that was not being logged ANYWHERE in any log file, which basically said I had a duplicate entry for IP address in /etc/dnsmasq.d/04-pihole-static-dhcp.conf
There was indeed a duplicate entry in the file, which is odd since I've only ever used the admin portal to add those static leases, but after removing the duplicate, everything was back up and running.
Your issue might not be a duplicate static lease, but perhaps running FTL from init.d will show you the actual error in the console since it's not showing up in the logs.
Update: after I solved it and knew the error, I grep'd the entire /var/log and found that the error was being logged in /var/log/daemon.log and nowhere else
Thanks for your suggestion!
Moving this form community help to help as Ubuntu 20.04 is now officially supported OS.
I tried running this and it said that dnsmasq was not installed. So I installed it and it failed to start. Is dnsmasq needed for pihole-FTL to run? An earlier comment said to disable it I think.
● dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2020-07-16 16:31:43 UTC; 28s ago
Process: 821 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=3)
Jul 16 16:31:39 elder-mac-smash systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Jul 16 16:31:41 elder-mac-smash dnsmasq[821]: dnsmasq: cannot access /etc/dnsmasq.d/lxd: No such file or directory
Jul 16 16:31:41 elder-mac-smash dnsmasq[821]: cannot access /etc/dnsmasq.d/lxd: No such file or directory
Jul 16 16:31:41 elder-mac-smash dnsmasq[821]: FAILED to start up
Jul 16 16:31:43 elder-mac-smash systemd[1]: dnsmasq.service: Control process exited, code=exited, status=3/NOTIMP>
Jul 16 16:31:43 elder-mac-smash systemd[1]: dnsmasq.service: Failed with result 'exit-code'.
Jul 16 16:31:43 elder-mac-smash systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
lines 1-12/12 (END)
Looking around the system I found this. Looks like some sort of symlink that may have been broken. Removing it did the trick!!!!!
jorg@elder-mac-smash:/etc/dnsmasq.d$ ls -la
total 24
drwxr-xr-x   2 root root  4096 Jul 16 16:29 .
drwxr-xr-x 125 root root 12288 Jul 16 16:29 ..
-rw-r--r--   1 root root  1406 Jul 14 22:40 01-pihole.conf
-rw-r--r--   1 root root   211 Feb 13 19:51 README
lrwxrwxrwx   1 root root    28 Feb 14  2019 lxd -> /etc/dnsmasq.d-available/lxd
jorg@elder-mac-smash:/etc/dnsmasq.d$ sudo rm lxd
total 24
drwxr-xr-x   2 root root  4096 Jul 16 16:41 .
jorg@elder-mac-smash:/etc/dnsmasq.d$ sudo systemctl restart dnsmasq.service
jorg@elder-mac-smash:/etc/dnsmasq.d$ sudo systemctl status dnsmasq.service
     Active: active (running) since Thu 2020-07-16 16:42:09 UTC; 8s ago
    Process: 1556 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUCCESS)
    Process: 1568 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=0/SUCCESS)
    Process: 1580 ExecStartPost=/etc/init.d/dnsmasq systemd-start-resolvconf (code=exited, status=0/SUCCESS)
   Main PID: 1579 (dnsmasq)
      Tasks: 1 (limit: 4515)
     Memory: 3.4M
     CGroup: /system.slice/dnsmasq.service
             └─1579 /usr/sbin/dnsmasq -x /run/dnsmasq/dnsmasq.pid -u dnsmasq -r /run/dnsmasq/resolv.conf -7 /etc/>
Jul 16 16:42:09 elder-mac-smash systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Jul 16 16:42:09 elder-mac-smash dnsmasq[1556]: dnsmasq: syntax check OK.
Jul 16 16:42:09 elder-mac-smash systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
...skipping...
     Memory: 3.4M
total 24
jorg@elder-mac-smash:/etc/dnsmasq.d$ pihole restartdns
jorg@elder-mac-smash:/etc/dnsmasq.d$ pihole status
  [βœ“] DNS service is running
  [βœ“] Pi-hole blocking is Enabled
Thank you!!!! Looks like it's working now! Not even remotely sure how that happened I don't think I've ever fooled around with dnsmasq. I wonder if it happened because I upgraded from Ubuntu 18 to 20 and something may have created that link during the upgrade process.
Once again thanks everyone!
(You can format your output for readability by using the </> Preformatted text menu option. I’ve just done that for you in your post above :slight_smile:)
There is no need to install dnsmasq in addition to Pi-hole, on the contrary: Pi-hole comes with its own tailored dnsmasq version embedded, so any additional dnsmasq package on the same machine is likely to cause conflicts.
That's why yubiuser asked you to check whether such a version was running on your system (which it wasn't then).
You may now use his commands to disable dnsmasq on your machine, and you could then also decide to deinstall it completely.
It would seem the root cause of your problem was the extra lxd configuration file (likely provided by Ubuntu for container services) that conflicted with Pi-hole's own configuration in /etc/dnsmasq.d/.
Thank you. I did actually have to disable the dnsmasq I installed for it to work actually. It was still saying that it couldn't connect to the API until I disabled it.
Also, the command to disable it I think is supposed to be systemctl instead of service:
$ sudo service dnsmasq stop
jorg@elder-mac-smash:~$ sudo service dnsmasq disable
Usage: /etc/init.d/dnsmasq {start|stop|restart|force-reload|dump-stats|status}
jorg@elder-mac-smash:~$ sudo systemctl disable dnsmasq.service
Synchronizing state of dnsmasq.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install disable dnsmasq
Removed /etc/systemd/system/multi-user.target.wants/dnsmasq.service.
Side question: what's the easiest way to transfer block lists from one Pihole to another? I have a second one running and want to transfer the lists over. Thanks!
Teleporter Export/Import
Is this normal behavior? It seems like name resolution takes a very long time sometimes, and running the dig command, sometimes I will get no response, then I run it a second time a few minutes later and it works.
$ dig google.com
; <<>> DiG 9.11.3-1ubuntu1.12-Ubuntu <<>> google.com
jorg@hogwarts-backup-pi-hole-vm:~$ dig google.com
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 60399
; EDNS: version: 0, flags:; udp: 1220
;google.com. IN A
google.com. 2399 IN A 216.58.213.142
;; Query time: 5467 msec
;; WHEN: Fri Jul 17 16:57:20 UTC 2020
;; MSG SIZE rcvd: 55
How would I go about diagnosing this? Thanks!
