"pihole-FTL" service should keep running.
I was having an issue with "illegal repeated keyword at line 33 of /etc/dnsmasq.d/01-pihole.conf" and finally realized that I had made a copy of 01-pihole.conf in that same directory. Once I deleted the "bkp" file, "sudo service pihole-FTL restart" worked. But, over the last 24 hrs or so, "pihole-FTL" has stopped twice. I ran the debug after restarting pihole-FTL.
It is not a bug that I am aware of. It happens with FTL is launched as root user, causing the shared memory files to be created under root. Then if FTL crashed, when started as pihole user, there is no permission to clean up the memory files.
Ensure that when you stop, start or restart FTL you only do so using the service command, never directly with a call to FTL.
To help us understand the problem, please provide the section of that pihole-FTL log from 20 lines prior to the crash and through all the output following the crash that it says to send to the developers. Thanks.
#1 has crashed again and pihole-FTL stopped. Should I open a new topic or continue this one?
#1 new token for "pihole -d" is: 5o8qjejmom
Meanwhile I'm prepping a fresh SD card for #1 with raspian, cloudflare DoH, & pihole. I won't do this until I hear that the uploads aren't telling us anything.
What is the best way for me to send you the output for "cat /var/log/pihole-FTL.log" (I ran this prior to:
We can close this thread. I've decided against continuing down this rabbit hole. I'm not knowledgeable enough to running "pihole checkout...". I've done a clean install on #2.
