pihole-FTL can't execute (GLIBC_2.14 not found)
pihole-FTL started
pihole-FTL dont start and FTL is offline
l7qiw5zq5f
More information
root:~# uname -a
Linux XXXX.ovh.net 2.6.32-042stab123.9 #1 SMP Thu Jun 29 13:01:59 MSK 2017 x86_64 GNU/Linux
root:~# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 7.11 (wheezy)
Release: 7.11
Codename: wheezy
root:~#pihole -up
[i] Checking for updates...
[i] Pi-hole Core: up to date
/usr/bin/pihole-FTL: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /usr/bin/pihole-FTL)
[i] FTL: update available
[i] FTL out of date
[i] FTL Checks...
[✓] Detected x86_64 architecture
[✓] Downloading and Installing FTL
[i] Web Interface: up to date
root:~# ldd -v /usr/bin/pihole-FTL
linux-vdso.so.1 => (0x00007ffc4a0dc000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f66bf4f9000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f66bf16c000)
/lib64/ld-linux-x86-64.so.2 (0x00007f66bfa0d000)
    Version information:
            libpthread.so.0 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libpthread.so.0
            libc.so.6 (GLIBC_2.3) => /lib/x86_64-linux-gnu/libc.so.6
            libc.so.6 (GLIBC_2.14) => not found
            libc.so.6 (GLIBC_2.8) => /lib/x86_64-linux-gnu/libc.so.6
            libc.so.6 (GLIBC_2.4) => /lib/x86_64-linux-gnu/libc.so.6
            libc.so.6 (GLIBC_2.3.4) => /lib/x86_64-linux-gnu/libc.so.6
            libc.so.6 (GLIBC_2.2.5) => /lib/x86_64-linux-gnu/libc.so.6
    /lib/x86_64-linux-gnu/libpthread.so.0:
            ld-linux-x86-64.so.2 (GLIBC_2.2.5) => /lib64/ld-linux-x86-64.so.2
            ld-linux-x86-64.so.2 (GLIBC_2.3) => /lib64/ld-linux-x86-64.so.2
            ld-linux-x86-64.so.2 (GLIBC_PRIVATE) => /lib64/ld-linux-x86-64.so.2
            libc.so.6 (GLIBC_2.3.2) => /lib/x86_64-linux-gnu/libc.so.6
            libc.so.6 (GLIBC_PRIVATE) => /lib/x86_64-linux-gnu/libc.so.6
root:~# apt-get update;apt-get install libc6 libc6-dev
=> Nothing to update
We do not officially support Wheezy any longer.
Note that we have to abandon old operating systems at some point to be able to move forward and use new functionality.
Wheezy has been superseded by Jessie already in 2015, and Jessie has already been superseded by Stretch.
The kernel you are using 2.6.32 dates back to December 2009. You should consider upgrading soon, mainly also to be able continuously receive (critical) security updates for your system.
See also
apt-cache show libc6 | grep Version
Modern systems should at least run version 2.15 (my PC is running 2.23)
Ok I understand. Thanks for your quick reply!
My version is 2.13-38+deb7u12, you are right, it's too old :confused:
