Admin interface should display stats and FTL should be online
FTL offline and admin interface displays "Lost connection to API"
I ran sudo service lighttpd restart so the admin interface was finally reachable. I also ran sudo service pihole-FTL restart but the admin interface still displays "FTL offline"
Pihole is installed on a Ubuntu 18.04 environment running on an android phone using Linux Deploy app
Interesting. Can you share more info on what makes this an unsupported platform? Specifically what's missing from Ubuntu 18 running in chroot environment compared to native Ubuntu 18.
[✗] No IPv4 address(es) found on the dummy0 interface.
[✓] IPv6 address(es) bound to the dummy0 interface:
fe80::7881:80ff:fed7:2276 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[✓] li.livingsocial.com is 0.0.0.0 via localhost (127.0.0.1)
[✗] Failed to resolve li.livingsocial.com via Pi-hole (192.168.1.16)
[✓] doubleclick.com is 172.217.14.206 via a remote, public DNS server (8.8.8.8)
Missing init system.
[✗] lighttpd daemon is
[✗] pihole-FTL daemon is
Can you tell me more about what part of networking stack is missing. I can try debugging to see if I can make it work.
For the init stack, the Linux Deploy app allows using an init system (run-parts or sysv). Here are the screenshots from the app. Can I add a script here to make this work?
