pihole for access point
My current setup is a fritzbox from my isp and after that an access point (ubiquiti ap lite). I would like to use pi hole, however I do not have the login for the fritzbox admin panel, so the question is wether I can use pi hole directly for the access point somehow or wether it can only be set for the router. Thanks for the help
You can use Pi-hole directly, since it's just a DNS server.
thank you for the fast answer. How could I do this? I could not find out how to set a dns server for an access point.
Just set it manually on each client if you can't edit the DHCP Server settings on your router.
Weird ISP by the way... most of them allow changing the settings on Fritz!Box router models!
There isn't much a customer could break on those things :wink:
Good luck!
Yeah thats why I asked wether there is another way to set it for the whole network,since setting it for each device is really annoying lol
Kind of already thought it´s not possible ... Guess I will write my isp a mail wether I can get a login for my router otherwise I will replace it.
I have 3 Ubiquiti AP Lite's as well, with a cloud key (the controller for the APs- not required, but helps). I just tested this on one of my APs to see if it would work, and it is not possible. You'll just have to manually set each device's DNS server.
ty for the answer. Yes checked the settings aswell and could not find anything, but since I am new to the topic I thought I might miss out on something :slight_smile:
