Hello,
I installed my pihole on raspberry pi 4, openmediavolt 5, docker, portainer.
I set it up according to the article: https://pcmac.biz/pi-hole-on-openmediavault-5-inside-docker-with-portainer-using-raspberry-pi-4/
It still reports an error when turned on. Log:
nameserver 127.0.0.11
options ndots:0
[i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u7
[i] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf...
[✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
chown: cannot access '/etc/pihole/dhcp.leases': No such file or directory
::: Pre existing WEBPASSWORD found
Using custom DNS servers: 1.1.1.1 & 1.1.4.4
DNSMasq binding to default interface: eth0
Added ENV to php:
"PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
"ServerIP" => "192.168.1.100",
"VIRTUAL_HOST" => "192.168.1.100",
Using IPv4 and IPv6
::: Preexisting ad list /etc/pihole/adlists.list detected ((exiting setup_blocklists early))
sudo: unable to stat /etc/sudoers: Permission denied
sudo: no valid sudoers sources found, quitting
sudo: unable to initialize policy plugin
::: Testing pihole-FTL DNS: [cont-init.d] 20-start.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 01-resolver-resolv: applying...
[fix-attrs.d] 01-resolver-resolv: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 20-start.sh: executing...
::: Starting docker specific checks & setup for docker pihole/pihole
WARNING Misconfigured DNS in /etc/resolv.conf: Two DNS servers are recommended, 127.0.0.1 and any backup server
WARNING Misconfigured DNS in /etc/resolv.conf: Primary DNS should be 127.0.0.1 (found 127.0.0.11)
Portainer settings:
I will be glad for any advice.
