PiHole Doesnt work on a fresh raspberry pi zero 2W (OS 64-Bit)
I expected Pi-hole to block ads on the one phone device when I test by only changing one device DNS to my raspberry pi IP address.
Let me start from the beginning:
I formatted an SD Card and I used raspberry pi imager to install the recommended raspberry Pi OS 64 bit for my Raspberry Pi Zero 2W model. I went to the pihole github and grabbed the pihole curl script to install. I use a TP Link Deco wifi extender so I assigned the pihole to a static IP. I install pihole and then I am able to get to the dashboard. I test it out first by changing the dns from another phone to the pihole ip address and immediately the internet doesnt connect to any websites. Google, bing, etc. I can see on my pihole dashboard the queries from the device coming in but the device cannot connect to any websites. Please help. What do I do? I tried asking different AI models and they just waste my time with methods that doesn't work.
In Indonesia I didn't have any trouble with IndoHome ISP but since I switched to Biznet, I had trouble getting this to work. I think the ISP blocks a lot of things. The only adblocker I got to work is when I put on Adguard then I changed the DNS to tcp://9.9.9.9 so is it possible I can make a workaround in Pihole settings?
Found this: Internet censorship in Indonesia - Wikipedia
On May 31, 2015, [Kominfo mandated all home and cellular ISPs operating in Indonesia to redirect port 53 for censorship purposes. This makes running own recursive server at home or changing the DNS in Indonesia impossible without workarounds such as encrypted DNS protocols as all traditional DNS requests would either be blocked or redirected to the ISP's DNS server.
Some ISPs have blocked access to popular encrypted DNS domains to prevent their users from using [DNS over HTTPS] and DNS over TLS to bypass censorship.
Replace this text with the debug token provided from running pihole -d
* Error message: curl: (6) Could not resolve host: tricorder.pi-hole.net
  • A local copy of the debug log can be found at: /var/log/pihole/pihole_debug .log
    I dont know what to do with this.
This will temporarily reset the nameserver on the Pi to bypass Pi-Hole DNS.
sudo nano /etc/resolv.conf
Edit the nameserver line to nameserver 9.9.9.9 or your preferred third party DNS service, save and exit
Run
sudo pihole -d
and upload the debug log.
