I have Raspberry Pi 1 installed and running only Pihole, i have configured the pi to work perfectly in wifi and ethernet mode without issues. Pi hole works fine with ethernet cable connected as it should.
I am able to connect to the portal and see the settings, but does not do the blocking. I have IPV6 Disabled in the PI Settings and the router.
Although this works in Ethernet mode and does the blocking for all devices acting as a DHCP, it does not block when the Pi is connected via Wifi. Do note i am able to ping google and the internet is up.
Kindly help me here.
Debug Token: https://tricorder.pi-hole.net/d92m1n0u19
From your debug log, you still have connectivity problems on the Pi-hole host.
[✗] No IPv4 address(es) found on the enxb827ebe77832 interface.
[✗] No IPv6 address(es) found on the enxb827ebe77832 interface.
* Pinging 192.168.1.1...
[✓] www.mgsmedia.ru is 0.0.0.0 via localhost (127.0.0.1)
[✗] Failed to resolve www.mgsmedia.ru via Pi-hole (192.168.1.30)
PIHOLE_INTERFACE=enxb827ebe77832
IPV4_ADDRESS=192.168.1.30/24
How do i resolve it ? i did the below and tried, still does not work
sudo ifconfig enxb827ebe77832 down
sudo ifconfig wlx801f02bf0b5b up
Pinging google.com works fine
ping google.com
PING google.com (74.125.24.101) 56(84) bytes of data.
64 bytes from 74.125.24.101 (74.125.24.101): icmp_seq=1 ttl=59 time=36.8 ms
64 bytes from 74.125.24.101 (74.125.24.101): icmp_seq=2 ttl=59 time=36.3 ms
also i am able to ping the gateway which is my wifi modem from Pi1
ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=1.96 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=1.48 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=1.67 ms
Even after executing the steps i am able to see the same error, it does not seem to use wlan config instead still uses ethernet and somehow able to ping google. https://tricorder.pi-hole.net/rxk6heoxur
This is the profile in dhcpcd.conf #fallback to static profile on eth0 #interface eth0 #fallback static_eth0
interface wlx801f02bf0b5b
static ip_address=192.168.1.30/24
static routers=192.168.1.1
interface enxb827ebe77832
You have two different interface names assigned to the same IP. Look at the output of the following command: it will tell you which interfaces are active.
