Pihole should block most or all adds. When I first set-up Pihole, it blocked pretty much everything.
I moved my unRAID OS flash drive to a new motherboard. Everything works, except Pihole.
In the new motherboard, Pihole initially showed zero blocking and no log history. I deleted the Docker.img/configs and then reinstalled Pihole from scratch. Now I see 10 queries and 6 blocked queries. I should be seeing hundreds in each of these categories.
Pihole port mappings are setup in the Docker to handle all router DNS traffic via 10.0.1.2, using ports 53 UDP/TCP and 80 TCP. I noticed additional ports being used, though I do not think they should be: 443 and 67.
Update: I decided to double check all my settings via the official Pihole setup guide. One of the first things in that guide is to set a router static dns. It was then I realized that I forgot to change this back to the static local IP pointing to the Pihole Docker. I had previously removed/changed this in my router when the Pihole stopped working as a means to have internet on all my devices on the home network until Pihole got fixed.
So, now Pihole appears to be seeing/blocking traffic.
But, I'm still seeing two additional ports being used that I did not set in the Pihole Docker container.
Take a look in your debug log, about a third of the way down from the top, for the listing of ports in use. This matches a port to a process. In my install on a Pi, for example, I show the following ports in use.
[] is in use by
[] is in use by
[22] is in use by sshd
[53] is in use by dnsmasq
[548] is in use by afpd
[5900] is in use by vncserver
[80] is in use by lighttpd
[5353] is in use by unbound
[8953] is in use by unbound
