Here’s my container log. I’m not sure when this started happening. It might have been after upgrading Ubuntu. What’s standing out in this log is dnsmasq: cannot read /etc/dnsmasq.conf: Permission denied
Any suggestions?
::: Starting docker specific checks & setup for docker pihole/pihole
[i] Installing /etc/dnsmasq.d/01-pihole.conf...
[✓] Installed /etc/dnsmasq.d/01-pihole.conf
[i] Installing /etc/.pihole/advanced/06-rfc6761.conf...
[✓] Installed /etc/dnsmasq.d/06-rfc6761.conf
Converting DNS1 to PIHOLE_DNS_
Converting DNS2 to PIHOLE_DNS_
Setting DNS servers based on PIHOLE_DNS_ variable
::: Pre existing WEBPASSWORD found
DNSMasq binding to default interface: eth0
Added ENV to php:
"PIHOLE_DOCKER_TAG" => "2022.01.1",
"PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
"ServerIP" => "0.0.0.0",
"CORS_HOSTS" => "",
"VIRTUAL_HOST" => "0.0.0.0",
Using IPv4 and IPv6
::: Preexisting ad list /etc/pihole/adlists.list detected ((exiting setup_blocklists early))
::: Testing pihole-FTL DNS: [cont-init.d] 20-start.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 01-resolver-resolv: applying...
[fix-attrs.d] 01-resolver-resolv: exited 1.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 20-start.sh: executing...
Added ENV to php:
"CORS_HOSTS" => "",
Using IPv4 and IPv6
[fix-attrs.d] done.
Added ENV to php:
"CORS_HOSTS" => "",
Using IPv4 and IPv6
