Pihole DNS works, but android devices sometimes get "net::ERR_NETWORK_CHANGED" error
Hello,
Been trying to figure this one out without luck, I have Pi-hole installed on a k3s cluster running on a two Raspberry Pi 4s (one master node, one worker node). (I picked the docker tag as this is effectively the same thing and didn't see one related to kubernetes)
I have a Google Wifi mesh network (currently 2 routers), and have set the DNS to the IP of the worker node where Pi-hole is installed.
The ad blocking is working, however, on my Android phone, using the Google app (not Chrome) when I click a result, I receive the error "net:ERR_NETWORK_CHANGED", the odd thing is, this is only sometimes. Sometimes the results load, other times they don't.
Sometimes if I get the error and go back and click the same link, it loads.
I'm not sure what is going on here.
From what I can tell, the error doesn't seem to be related to a google redirect being blocked by pi-hole, but something with the network setup itself, if I perform the same search within Chrome directly, all the results work.
Here is my pihole -d:
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations.  This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected.  Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2020-04-22:12:53:49 debug log has been initialized.
[i] Core: v4.4 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.4-0-g9e49077
[i] Web: v4.3.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.3-0-g62f2ffc
[✓] FTL: v4.3.1
[i] 1.4.45
[i] 7.0.33
[✓] Debian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv7l
   10.42.1.6/24 matches the IP found in /etc/pihole/setupVars.conf
   fe80::4c9a:fff:fedf:5f9a does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 10.42.1.1
   * Pinging 10.42.1.1...
[✓] Gateway responded.
[53] is in use by pihole-FTL
[✓] nepomucen-dorohusk.pl is 0.0.0.0 via localhost (127.0.0.1)
[✓] nepomucen-dorohusk.pl is 0.0.0.0 via Pi-hole (10.42.1.6)
[✓] doubleclick.com is 172.217.13.238 via a remote, public DNS server (8.8.8.8)
[✗] lighttpd daemon is inactive
[✗] pihole-FTL daemon is inactive
    QUERY_LOGGING=true
    INSTALL_WEB_SERVER=true
    INSTALL_WEB_INTERFACE=true
    LIGHTTPD_ENABLED=
    IPV4_ADDRESS=10.42.1.6/24
    IPV6_ADDRESS=
    PIHOLE_INTERFACE=eth0
    BLOCKING_ENABLED=true
    DNSMASQ_LISTENING=single
    PIHOLE_DNS_1=8.8.8.8
    PIHOLE_DNS_2=8.8.4.4
    DNS_FQDN_REQUIRED=false
    DNS_BOGUS_PRIV=false
    DNSSEC=true
    CONDITIONAL_FORWARDING=true
    CONDITIONAL_FORWARDING_IP=192.168.86.1
    CONDITIONAL_FORWARDING_DOMAIN=lan
    CONDITIONAL_FORWARDING_REVERSE=86.168.192.in-addr.arpa
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 1881489 Apr 22 12:23 /etc/pihole/gravity.list
   0.0.0.0
   0.0.0.0.beeglivesex.com
   0.0.0.0.creative.hpyrdr.com
   0.0.0.0.hpyrdr.com
   zzz.clickbank.net
   zzzezeroe.fr
   zzzpooeaz-france.com
   zzzrtrcm2.com
-rw-r--r-- 1 root root 313 Apr 15 18:57 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 0 Apr 22 03:01 /etc/pihole/blacklist.txt
-rw-r--r-- 1 root root 51 Apr 22 12:23 /etc/pihole/local.list
   10.42.1.6 pihole-5c7fc9958-vk9c4
   10.42.1.6 pi.hole
-rw-r--r-- 1 root root 0 Apr 22 12:22 /etc/pihole/whitelist.txt
-rw-r--r-- 1 root root 1679 Apr 22 12:23 /etc/dnsmasq.d/01-pihole.conf
   localise-queries
   no-resolv
   cache-size=10000
   log-queries
   local-ttl=2
   log-async
   server=8.8.8.8
   server=8.8.4.4
   dnssec
   trust-anchor=.,19036,8,2,49AAC11D7B6F6446702E54A1607371607A1A41855200FD2CE1CDDE32F24E8FB5
   trust-anchor=.,20326,8,2,E06D44B80B8F1D39A95C0B0D7C65D08458E880409BBC683457104237C7F8EC8D
   interface=eth0
   server=/lan/192.168.86.1
   server=/86.168.192.in-addr.arpa/192.168.86.1
   server=/use-application-dns.net/
-rw-r--r-- 1 root root 3499 Apr 15 18:57 /etc/lighttpd/lighttpd.conf
   server.modules = (
   	"mod_access",
   	"mod_accesslog",
   	"mod_auth",
   	"mod_expire",
   	"mod_compress",
   	"mod_redirect",
   	"mod_setenv",
   	"mod_rewrite"
   server.error-handler-404    = "/pihole/index.php"
   server.pid-file             = "/var/run/lighttpd.pid"
   accesslog.filename          = "/var/log/lighttpd/access.log"
   accesslog.format            = "%{%s}t|%V|%r|%s|%b"
   compress.cache-dir          = "/var/cache/lighttpd/compress/"
   compress.filetype           = ( "application/javascript", "text/css", "text/html", "text/plain" )
   mimetype.assign   = ( ".png"  => "image/png",
                         ".jpg"  => "image/jpeg",
                         ".jpeg" => "image/jpeg",
                         ".html" => "text/html",
                         ".js" => "application/javascript",
                         ".json" => "application/json",
                         ".txt"  => "text/plain",
                         ".svg"  => "image/svg+xml" )
' 2>/dev/null"
   $HTTP["url"] =~ "^/admin/" {
           "X-Frame-Options" => "DENY"
       $HTTP["url"] =~ ".ttf$" {
        url.access-deny = ("")
-rw-r--r-- 1 root root 1704 Feb 26 18:38 /etc/cron.d/pihole
   32 4   * * 7   root    PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
   00 00   * * *   root    PATH="$PATH:/usr/local/bin/" pihole flush once quiet
   */10 *  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker local
   54 17  * * *   root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
   @reboot root    PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 2509 Apr 15 18:59 /var/log/lighttpd/error.log
   2020-04-15 14:57:16: (log.c.217) server started
   2020-04-15 14:58:17: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
   2020-04-15 14:58:17: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
   2020-04-15 14:58:17: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
   2020-04-15 14:58:21: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
   2020-04-15 14:58:21: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
   2020-04-15 14:58:21: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
   2020-04-15 14:58:24: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
   2020-04-15 14:58:24: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
   2020-04-15 14:58:24: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
   2020-04-15 14:58:34: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
   2020-04-15 14:58:34: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
   2020-04-15 14:58:34: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
   2020-04-15 14:59:12: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 46
   2020-04-15 14:59:12: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 47
   2020-04-15 14:59:12: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice:  Undefined offset: 2 in /var/www/html/admin/scripts/pi-hole/php/update_checker.php on line 52
-rw-r--r-- 1 root root 33883 Apr 22 12:53 /var/log/pihole-FTL.log
   [2020-04-15 14:57:04.014 338] Using log file /var/log/pihole-FTL.log
   [2020-04-15 14:57:04.014 338] ########## FTL started! ##########
   [2020-04-15 14:57:04.014 338] FTL branch: master
   [2020-04-15 14:57:04.014 338] FTL version: v4.3.1
   [2020-04-15 14:57:04.014 338] FTL commit: b60d63f
   [2020-04-15 14:57:04.014 338] FTL date: 2019-05-25 21:37:26 +0200
   [2020-04-15 14:57:04.014 338] FTL user: root
   [2020-04-15 14:57:04.015 338] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
   [2020-04-15 14:57:04.015 338]    SOCKET_LISTENING: only local
   [2020-04-15 14:57:04.015 338]    AAAA_QUERY_ANALYSIS: Show AAAA queries
   [2020-04-15 14:57:04.015 338]    MAXDBDAYS: max age for stored queries is 365 days
   [2020-04-15 14:57:04.015 338]    RESOLVE_IPV6: Resolve IPv6 addresses
   [2020-04-15 14:57:04.015 338]    RESOLVE_IPV4: Resolve IPv4 addresses
   [2020-04-15 14:57:04.015 338]    DBINTERVAL: saving to DB file every minute
   [2020-04-15 14:57:04.015 338]    DBFILE: Using /etc/pihole/pihole-FTL.db
   [2020-04-15 14:57:04.015 338]    MAXLOGAGE: Importing up to 24.0 hours of log data
   [2020-04-15 14:57:04.015 338]    PRIVACYLEVEL: Set to 0
   [2020-04-15 14:57:04.015 338]    IGNORE_LOCALHOST: Show queries from localhost
   [2020-04-15 14:57:04.015 338]    BLOCKINGMODE: Null IPs for blocked domains
   [2020-04-15 14:57:04.015 338]    ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
   [2020-04-15 14:57:04.016 338]    DBIMPORT: Importing history from database
   [2020-04-15 14:57:04.016 338]    PIDFILE: Using /var/run/pihole-FTL.pid
   [2020-04-15 14:57:04.016 338]    PORTFILE: Using /var/run/pihole-FTL.port
   [2020-04-15 14:57:04.016 338]    SOCKETFILE: Using /var/run/pihole/FTL.sock
   [2020-04-15 14:57:04.016 338]    WHITELISTFILE: Using /etc/pihole/whitelist.txt
   [2020-04-15 14:57:04.016 338]    BLACKLISTFILE: Using /etc/pihole/black.list
   [2020-04-15 14:57:04.016 338]    GRAVITYFILE: Using /etc/pihole/gravity.list
   [2020-04-15 14:57:04.016 338]    REGEXLISTFILE: Using /etc/pihole/regex.list
   [2020-04-15 14:57:04.016 338]    SETUPVARSFILE: Using /etc/pihole/setupVars.conf
   [2020-04-15 14:57:04.016 338]    AUDITLISTFILE: Using /etc/pihole/auditlog.list
   [2020-04-15 14:57:04.016 338]    MACVENDORDB: Using /etc/pihole/macvendor.db
   [2020-04-15 14:57:04.016 338]    PARSE_ARP_CACHE: Active
   [2020-04-15 14:57:04.017 338] Finished config file parsing
   [2020-04-15 14:57:04.017 338] WARNING: Starting pihole-FTL as user root is not recommended
   [2020-04-15 14:57:04.017 338] SQLite3 message: cannot open file at line 38452 of [0eca3dd3d3] (14)
   [2020-04-22 08:23:35.149 3389] Resizing "/FTL-queries" from 589824 to 786432
   [2020-04-22 08:23:35.163 3389] Resizing "/FTL-strings" from 20480 to 24576
   [2020-04-22 08:23:35.164 3389] Resizing "/FTL-queries" from 786432 to 983040
   [2020-04-22 08:23:35.180 3389] Resizing "/FTL-queries" from 983040 to 1179648
   [2020-04-22 08:23:35.191 3389] Resizing "/FTL-strings" from 24576 to 28672
   [2020-04-22 08:23:35.195 3389] Resizing "/FTL-queries" from 1179648 to 1376256
   [2020-04-22 08:23:35.213 3389] Resizing "/FTL-strings" from 28672 to 32768
   [2020-04-22 08:23:35.217 3389] Resizing "/FTL-queries" from 1376256 to 1572864
   [2020-04-22 08:23:35.233 3389] Resizing "/FTL-queries" from 1572864 to 1769472
   [2020-04-22 08:23:35.245 3389] Resizing "/FTL-queries" from 1769472 to 1966080
   [2020-04-22 08:23:35.258 3389] Resizing "/FTL-queries" from 1966080 to 2162688
   [2020-04-22 08:23:35.260 3389] Resizing "/FTL-strings" from 32768 to 36864
   [2020-04-22 08:23:35.273 3389] Imported 43751 queries from the long-term database
   [2020-04-22 08:23:35.273 3389]  -> Total DNS queries: 43751
   [2020-04-22 08:23:35.273 3389]  -> Cached DNS queries: 3968
   [2020-04-22 08:23:35.273 3389]  -> Forwarded DNS queries: 13200
   [2020-04-22 08:23:35.273 3389]  -> Exactly blocked DNS queries: 26583
   [2020-04-22 08:23:35.273 3389]  -> Unknown DNS queries: 0
   [2020-04-22 08:23:35.273 3389]  -> Unique domains: 1369
   [2020-04-22 08:23:35.273 3389]  -> Unique clients: 2
   [2020-04-22 08:23:35.273 3389]  -> Known forward destinations: 2
   [2020-04-22 08:23:35.273 3389] Successfully accessed setupVars.conf
   [2020-04-22 08:23:35.274 3389] *************************************************************************
   [2020-04-22 08:23:35.274 3389] * WARNING: Required Linux capability CAP_NET_ADMIN not available        *
   [2020-04-22 08:23:35.739 3389] PID of FTL process: 3389
   [2020-04-22 08:23:35.739 3389] Listening on port 4711 for incoming IPv4 telnet connections
   [2020-04-22 08:23:35.739 3389] Listening on port 4711 for incoming IPv6 telnet connections
   [2020-04-22 08:23:35.740 3389] Listening on Unix socket
   [2020-04-22 08:23:35.741 3389] Received SIGHUP, reloading cache
   [2020-04-22 08:23:35.741 3389] Blocking status is enabled
   [2020-04-22 08:23:35.741 3389] Compiled 0 Regex filters and 0 whitelisted domains in 0.1 msec (0 errors)
   [2020-04-22 08:23:35.741 3389] /etc/pihole/black.list: parsed 0 domains (took 0.0 ms)
   [2020-04-22 08:23:36.099 3389] /etc/pihole/gravity.list: parsed 92112 domains (took 357.5 ms)
   [2020-04-22 08:53:31.998 3389] Resizing "/FTL-queries" from 2162688 to 2359296
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 root root 323584 Apr 22 12:23 /dev/shm/FTL-clients
-rw------- 1 root root 108 Apr 22 12:23 /dev/shm/FTL-counters
-rw------- 1 root root 65536 Apr 22 12:23 /dev/shm/FTL-domains
-rw------- 1 root root 12288 Apr 22 12:23 /dev/shm/FTL-forwarded
-rw------- 1 root root 28 Apr 22 12:23 /dev/shm/FTL-lock
-rw------- 1 root root 53248 Apr 22 12:23 /dev/shm/FTL-overTime
-rw------- 1 root root 2359296 Apr 22 12:53 /dev/shm/FTL-queries
-rw------- 1 root root 12 Apr 22 12:23 /dev/shm/FTL-settings
-rw------- 1 root root 36864 Apr 22 12:23 /dev/shm/FTL-strings
*** [ DIAGNOSING ]: Locale
    LANG=
-rw-r--r-- 1 pihole pihole 3536024 Apr 22 12:53 /var/log/pihole.log
   -----head of pihole.log------
   Apr 22 00:00:03 dnsmasq[30950]: query[A] reports.crashlytics.com from 10.42.1.1
   Apr 22 00:00:03 dnsmasq[30950]: /etc/pihole/gravity.list reports.crashlytics.com is 0.0.0.0
   Apr 22 00:00:19 dnsmasq[30950]: query[A] api.segment.io from 10.42.1.1
   Apr 22 00:00:19 dnsmasq[30950]: /etc/pihole/gravity.list api.segment.io is 0.0.0.0
   Apr 22 00:00:21 dnsmasq[30950]: query[A] reports.crashlytics.com from 10.42.1.1
   Apr 22 00:00:21 dnsmasq[30950]: /etc/pihole/gravity.list reports.crashlytics.com is 0.0.0.0
   Apr 22 00:00:24 dnsmasq[30950]: query[A] logsink.devices.nest.com from 10.42.1.1
   Apr 22 00:00:24 dnsmasq[30950]: forwarded logsink.devices.nest.com to 8.8.8.8
   Apr 22 00:00:24 dnsmasq[30950]: reply logsink.devices.nest.com is 35.190.54.210
   Apr 22 00:00:24 dnsmasq[30950]: query[AAAA] czfe146-front01-iad01.transport.home.nest.com from 10.42.1.1
   Apr 22 00:00:24 dnsmasq[30950]: forwarded czfe146-front01-iad01.transport.home.nest.com to 8.8.8.8
   Apr 22 00:00:24 dnsmasq[30950]: reply czfe146-front01-iad01.transport.home.nest.com is <CNAME>
   Apr 22 00:00:24 dnsmasq[30950]: reply ec2-18-232-72-120.compute-1.amazonaws.com is NODATA-IPv6
   Apr 22 00:00:31 dnsmasq[30950]: query[A] www.youtube.com from 10.42.1.1
   Apr 22 00:00:31 dnsmasq[30950]: cached www.youtube.com is <CNAME>
   Apr 22 00:00:31 dnsmasq[30950]: forwarded www.youtube.com to 8.8.8.8
   Apr 22 00:00:31 dnsmasq[30950]: reply www.youtube.com is <CNAME>
   Apr 22 00:00:31 dnsmasq[30950]: reply youtube-ui.l.google.com is 172.217.13.78
   Apr 22 00:00:31 dnsmasq[30950]: reply youtube-ui.l.google.com is 172.217.13.238
[✓] ** FINISHED DEBUGGING! **
    * For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
    * If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
[✓] Your debug token is: https://tricorder.pi-hole.net/i22eluyjaq
   * Provide the token above to the Pi-hole team for assistance at
   * https://discourse.pi-hole.net
   * Your log will self-destruct on our server after 48 hours.
   * A local copy of the debug log can be found at: /var/log/pihole_debug.log
