My thopsis to my issue is that when i apply the DNS to my router of 192.168.1.11 it applies it to all of my network devicies including the pi making it so that when the pi wants to resolve the dns it trys to resolve from it self. i have tried changing the DNS to 1.1.1.1 / 1.0.0.1 maunally in the network perfences / interface / eth0 but it does not solve the issue.
the pihole works if i maunally route each device with a custom dns in their settings but if i ever try and change it to the pihole dns via my routers DNS page it does not work.
thank you inadvance.
DNS to be applied across network with any issue.
DNS is applied across network but when searching on multipul devices including PI broswers cannot resolve server.
The Pi-hole device does not get its settings from the router. It uses the DNS server located in /etc/resolv.conf. You have a different CIDR configured than what is present on your network interface (192.168.1.11/24 vs 192.168.1.11/10), and you are unable to resolve against 8.8.8.8.
Here are the applicable sections of your debug log that show what @Mcat12 described:
192.168.1.11/10 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[✓] sec.daten-ueberpruefungsservice.net is 0.0.0.0 via localhost (127.0.0.1)
[✓] sec.daten-ueberpruefungsservice.net is 0.0.0.0 via Pi-hole (192.168.1.11)
BLOCKING_ENABLED=true
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.1.11/24
