Hello, I just want to run a quick check-up with a debug token just to take a look at things. I'm running off an android pihole setup and since the new v6 update, there has been some issues. For one, the initial installation has issues installing and running FTL. So when I log into ssh, I run a quick repair and/or reconfigure, I followed a few guides in regards to FTL on here so I managed to get it working. However, I tried running it as a DHCP server and it's a lot more spotty and less reliable than before (even with rapid connect on, devices couldn't hold onto ip addresses and took forever to actually connect to them), the device pihole is running on is already set with a static IP address. So I had to turn it off and just use it as a manual DNS on select devices.
Can anyone check the debug token to see if there are any errors I should be aware of? The oddities of DHCP is when I went in and tried to delete all the leases whilst my router DHCP was still on. I just updated pi-hole today so I decided to run a debug whilst I was in ssh.
https://tricorder.pi-hole.net/GUivQLef/
