my ISP supports ipv6 and it is enabled, my router has public ipv6 address.
I've manually set static ipv4 and ipv6 address to my raspberry through /etc/dhcpcd.conf:
slaac hardware
interface eth0
static ip_address=192.168.0.xxxx
static routers=192.168.0.x
static ip6_address=2804:14c:65e4:xxxxx
pi@retropie:~ $ ip -6 address show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 state UNKNOWN qlen 1000
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
inet6 2804:14c:65e4:xxxxx/128 scope global noprefixroute
inet6 fe80::ba27:xxxx/64 scope link
IPV6_ADDRESS is set in /etc/pihole/setupVars.conf.
Then I've switched off DHCP from my router (bad router, provided by ISP) and now my pihole has DHCP enabled for both ipv4 and ipv6, using " Enable IPv6 support (SLAAC + RA)" enabled.
ipv4 dns sinkhole and dhcp is working fine. But ipv6 dhcp is not working. My windows client workstation used to have ipv6 assigned when DHCP came from router...now that is set from pihole, dhcp only works for ipv4 and not ipv6.
Aug 1 17:44:24 dnsmasq-dhcp[1371]: RTR-SOLICIT(eth0) 24:18:1d:ba:dd:ad
Aug 1 17:44:24 dnsmasq-dhcp[1371]: DHCPDISCOVER(eth0) 24:18:1d:ba:dd:ad
Aug 1 17:44:24 dnsmasq-dhcp[1371]: DHCPOFFER(eth0) 192.168.0.44 24:18:1d:ba:dd:ad
Aug 1 17:44:24 dnsmasq-dhcp[1371]: DHCPREQUEST(eth0) 192.168.0.44 24:18:1d:ba:dd:ad
Aug 1 17:44:24 dnsmasq-dhcp[1371]: DHCPACK(eth0) 192.168.0.44 24:18:1d:ba:dd:ad Samsung-Galaxy-S7-edge
Pihole DHCP should assign ipv6 address do clients
Linux retropie 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
pi@retropie:~ $ cat /etc/*release*
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Pihole DHCP not assigning ipv6 address to clients
or3n1nkigl
