pihole -up should not break my installation
pihole commands should output anything
pihole commands do not output anything
no dns or web portal
attempting to rerun the install commands fails due to existing install
I am unable to run the debug script
I got things working again by manually removing the directories that contained the git repos it was failing to update, and rerunning the installation.
I reran the debugger after it completed, maybe someone can tell me what went wrong.
https://tricorder.pi-hole.net/qDaCe7vy/
This log doesn't show issues, but the debug log was written to show details about Pi-hole operation, not about Pi-hole installation, so no information about failed installations will be there.
Your screenshots also don't show error messages, so probably it will be impossible to know what happened.
I didn't see any other results when searching for a solution, so at the very least I wanted to post this for documentation purposes
Exactly... this doesn't seem to be a Pi-hole issue.
This was probably an issue in your local installation. Probably a temporary issue.
Please feel free to post if you find some more information.
Recovering from a failed install might be beneficial to document, but what do I know.
I had the same error. Then I realized during the install/setup I left it set to ethernet, but I was only using wifi on the pi. Reran the install/setup, selected wifi, and got past this error.
system
Closed
March 27, 2025, 2:18am
7
