Just upgraded to 5.1.1 and pihole status shows everything is running. Doing a tail on the log shows queries being processed yet the pihole chronometer shows FTL offline. BUG??
I have this same problem, for the last ~1 hr since updating to 5.1.1.
yep i have the same issue.
First, yeah, it's known.
Third, open a bug report for PADD please.
Loaded PADD but I run a headless system so nothing happens after I reboot. Once I ssh back in, its just the same thing. Manual way to run PADD??
Manual? Yeah, just execute it from the command line.
This appears to be a PADD issue.
Interesting also that pihole chronometer is also not showing any activity. But I do have 267K domains and tailing the log file shows its supposedly working.
Bug #112 opened up over on github here.
I tried playing around with padd.sh a bit to see if I could understand why it wasn't populating, but I either don't understand bash well enough (probably), or the reason I can't find it is the same reason PADD can't, and thus will not report it.
Here a possible solution is posted:
