Pihole blocks only 2%
Hello all,
Im using paspberry Pi 3b+ fresh installl Pihole after the crash update to Vers.6
Now running V 6.01
Why ist it that nothing is blocked more? Only 2% ! so evrything is Green, i dont know.
DEBUG:
*** [ INITIALIZING ]
[i] 2025-02-20:19:08:07 debug log has been initialized.
[i] System has been running for 0 days, 0 hours, 6 minutes
[βœ“] Version: v6.0.1
[i] Remotes: origin GitHub - pi-hole/pi-hole: A black hole for Internet advertisements (fetch)
origin GitHub - pi-hole/pi-hole: A black hole for Internet advertisements (push)
[i] Branch: master
[i] Commit: v6.0.1-0-g9de976c
[βœ“] Version: v6.0
[i] Remotes: origin GitHub - pi-hole/web: Pi-hole Dashboard for stats and more (fetch)
origin GitHub - pi-hole/web: Pi-hole Dashboard for stats and more (push)
[i] Branch: master
[i] Commit: v6.0-0-ga66d859
[βœ“] Version: v6.0
[i] Branch: master
[i] Commit: eaa7dbb4
[βœ“] Distro: Debian
[βœ“] Version: 12
[βœ“] dig return code: 0
[i] dig response: "Raspbian=11,12 Ubuntu=20,22,23,24 Debian=11,12 Fedora=40,41 CentOS=9"
[βœ“] Distro and version supported
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: FirewallD
[i] Firewalld service inactive
*** [ DIAGNOSING ]: System hardware configuration
[i] lshw -short
H/W path Device Class Description
                       system      Raspberry Pi 3 Model B Plus Rev 1.3
/0 bus Motherboard
/0/0 processor cpu
/0/0/0 memory 32KiB L1 Cache
/0/1 processor cpu
/0/1/0 memory 32KiB L1 Cache
/0/2 processor cpu
/0/2/0 memory 32KiB L1 Cache
/0/3 processor cpu
/0/3/0 memory 32KiB L1 Cache
/0/4 processor l2-cache0
/0/5 memory 907MiB System memory
/1 usb1 bus DWC OTG Controller
/1/1 bus USB hub
/1/1/1 bus USB hub
/1/1/1/1 eth0 network Ethernet interface
/2 mmc0 bus MMC Host
/2/e624 /dev/mmcblk0 disk 31GB SC32G
/2/e624/1 volume 512MiB Windows FAT volume
/2/e624/2 /dev/mmcblk0p2 volume 29GiB EXT4 volume
/3 card0 multimedia Headphones
/4 card1 multimedia vc4hdmi
/5 input0 input vc4-hdmi
/6 input1 input vc4-hdmi HDMI Jack
*** [ DIAGNOSING ]: Processor details
[i] lscpu
Architecture: aarch64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Vendor ID: ARM
Model name: Cortex-A53
Model: 4
Thread(s) per core: 1
Core(s) per cluster: 4
Socket(s): -
Cluster(s): 1
Stepping: r0p4
CPU(s) scaling MHz: 100%
CPU max MHz: 1400.0000
CPU min MHz: 600.0000
BogoMIPS: 38.40
Flags: fp asimd evtstrm crc32 cpuid
L1d cache: 128 KiB (4 instances)
L1i cache: 128 KiB (4 instances)
L2 cache: 512 KiB (1 instance)
Vulnerability Gather data sampling: Not affected
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Mmio stale data: Not affected
Vulnerability Reg file data sampling: Not affected
Vulnerability Retbleed: Not affected
Vulnerability Spec rstack overflow: Not affected
Vulnerability Spec store bypass: Not affected
Vulnerability Spectre v1: Mitigation; __user pointer sanitization
Vulnerability Spectre v2: Not affected
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
*** [ DIAGNOSING ]: Disk usage
Filesystem Size Used Avail Use% Mounted on
udev 318M 0 318M 0% /dev
tmpfs 91M 984K 90M 2% /run
/dev/mmcblk0p2 29G 4.1G 24G 15% /
tmpfs 454M 4.5M 450M 1% /dev/shm
tmpfs 5.0M 12K 5.0M 1% /run/lock
/dev/mmcblk0p1 510M 64M 447M 13% /boot/firmware
tmpfs 91M 0 91M 0% /run/user/1000
*** [ DIAGNOSING ]: Network interfaces and addresses
inet6 ::1/128 scope host noprefixroute
link/ether b8:27:eb:17:16:51 brd ff:ff:ff:ff:ff:ff
inet 192.168.178.31/24 brd 192.168.178.255 scope global dynamic noprefixroute eth0
valid_lft 863622sec preferred_lft 863622sec
inet6 2003:ea:f26:5e00:cdbd:c746:2fcb:2bf9/64 scope global dynamic noprefixroute
valid_lft 6825sec preferred_lft 935sec
inet6 fd01:894e:741f:0:8fcd:9ee7:7f81:e71f/64 scope global dynamic noprefixroute
valid_lft 6825sec preferred_lft 3225sec
inet6 fe80::35a2:3dec:bf0f:7cdc/64 scope link noprefixroute
*** [ DIAGNOSING ]: Network routing table
default via 192.168.178.1 dev eth0 proto dhcp src 192.168.178.31 metric 100
192.168.178.0/24 dev eth0 proto kernel scope link src 192.168.178.31 metric 100
[i] Default IPv4 gateway(s):
192.168.178.1%eth0
  • Pinging first gateway 192.168.178.1...
    [βœ“] Gateway responded.
    [i] Default IPv6 gateway(s):
    fe80::cece:1eff:feb3:11aa%eth0
  • Pinging first gateway fe80::cece:1eff:feb3:11aa%eth0...
udp:0.0.0.0:53641 is in use by avahi-daemon
[βœ“] udp:0.0.0.0:53 is in use by pihole-FTL
udp:0.0.0.0:5353 is in use by avahi-daemon
udp:[fe80::35a2:3dec:bf0f:7cdc]:546 is in use by NetworkManager
[βœ“] udp::53 is in use by pihole-FTL
udp:
:49336 is in use by avahi-daemon
udp:*:5353 is in use by avahi-daemon
[βœ“] tcp:0.0.0.0:80 is in use by pihole-FTL
tcp:0.0.0.0:22 is in use by sshd
[βœ“] tcp:0.0.0.0:53 is in use by pihole-FTL
[βœ“] tcp:0.0.0.0:443 is in use by pihole-FTL
[βœ“] tcp:[::]:80 is in use by pihole-FTL
tcp:[::]:22 is in use by sshd
[βœ“] tcp:[::]:53 is in use by pihole-FTL
[βœ“] tcp:[::]:443 is in use by pihole-FTL
[βœ“] flurry.com is NOERROR on lo (127.0.0.1)
[βœ“] flurry.com is NOERROR on eth0 (192.168.178.31)
[βœ“] doubleclick.com is 142.251.36.174 via a remote, public DNS server (8.8.8.8)
[βœ“] flurry.com is NOERROR on lo (::1)
[βœ“] flurry.com is NOERROR on eth0 (2003:ea:f26:5e00:cdbd:c746:2fcb:2bf9)
[βœ“] flurry.com is NOERROR on eth0 (fd01:894e:741f:0:8fcd:9ee7:7f81:e71f)
[βœ“] flurry.com is NOERROR on eth0 (fe80::35a2:3dec:bf0f:7cdc%eth0)
[βœ“] doubleclick.com is 2a00:1450:4001:830::200e via a remote, public DNS server (2001:4860:4860::8888)
*** [ DIAGNOSING ]: Discovering active DHCP servers (takes 6 seconds)
Timeout: 6 seconds
  • Received 548 bytes from 192.168.178.1 @ eth0
    Offered IP address: 192.168.178.31
    Server IP address: 192.168.178.1
    Relay-agent IP address: N/A
    BOOTP server: (empty)
    BOOTP file: (empty)
    DHCP options:
    Message type: DHCPOFFER (2)
    server-identifier: 192.168.178.1
    lease-time: 864000 ( 10d )
    renewal-time: 432000 ( 5d )
    rebinding-time: 756000 ( 8d 18h )
    netmask: 255.255.255.0
    router: 192.168.178.1
    dns-server: 192.168.178.31
    domain-name: "fritz.box"
    mtu: 1500
    broadcast: 192.168.178.255
    ntp-server: 192.168.178.1
    Port Control Protocol (PCP) server: 192.168.178.1
  • Received 192 bytes from fe80::cece:1eff:feb3:11aa @ eth0
    Hop limit: 255
    Stateful address conf.: No
    Stateful other conf.: Yes
    Mobile home agent: No
    Router preference: Medium
    Neighbor discovery proxy: No
    Router lifetime: 1800 s
    Reachable time: N/A
    Retransmit time: N/A
    • Prefix: 2003:ea:f25:bf00::/64
      Valid lifetime: 0 sec
      Preferred lifetime: 0 sec
      On-link: Yes
      Autonomous address conf.: Yes
    • Prefix: 2003:ea:f26:5e00::/64
      Valid lifetime: 7200 sec
      Preferred lifetime: 1784 sec
      On-link: Yes
    • Prefix: fd01:894e:741f::/64
      Preferred lifetime: 3600 sec
      On-link: Yes
      Recursive DNS server 1/1: fd01:894e:741f:0:8fcd:9ee7:7f81:e71f
      DNS server lifetime:1200 sec
      MTU: 1492 bytes (valid)
    • Route: ::/0
      Route preference: Medium
      Route lifetime: 1800 sec
    • Route: 2003:ea:f26:5e00::/56
    • Route: fd01:894e:741f::/64
      Source link-layer address: CC:CE:1E:B3:11:AA
Received 1 DHCP (IPv4) and 1 RA (IPv6) answers on eth0
[βœ“] pihole-FTL daemon is active
*** [ DIAGNOSING ]: Pi-hole-FTL full status
● pihole-FTL.service - Pi-hole FTL
Loaded: loaded (/etc/systemd/system/pihole-FTL.service; enabled; preset: enabled)
Active: active (running) since Thu 2025-02-20 19:01:33 CET; 7min ago
Process: 546 ExecStartPre=/opt/pihole/pihole-FTL-prestart.sh (code=exited, status=0/SUCCESS)
Main PID: 585 (pihole-FTL)
Tasks: 11 (limit: 762)
CPU: 16.206s
└─585 /usr/bin/pihole-FTL -f
Feb 20 19:01:34 pihole pihole-FTL[585]: 2025-02-20 19:01:34.025 CET [585M] INFO: FTL user: pihole
Feb 20 19:01:34 pihole pihole-FTL[585]: 2025-02-20 19:01:34.025 CET [585M] INFO: Compiled for linux/arm64/v8 (compiled on CI) using cc (Alpine 14.2.0) 14.2.0
Feb 20 19:01:34 pihole pihole-FTL[585]: 2025-02-20 19:01:34.033 CET [585M] INFO: Wrote config file:
Feb 20 19:01:34 pihole pihole-FTL[585]: 2025-02-20 19:01:34.033 CET [585M] INFO: - 152 total entries
Feb 20 19:01:34 pihole pihole-FTL[585]: 2025-02-20 19:01:34.033 CET [585M] INFO: - 149 entries are default
Feb 20 19:01:34 pihole pihole-FTL[585]: 2025-02-20 19:01:34.033 CET [585M] INFO: - 3 entries are modified
Feb 20 19:01:34 pihole pihole-FTL[585]: 2025-02-20 19:01:34.033 CET [585M] INFO: - 0 entries are forced through environment
Feb 20 19:01:34 pihole pihole-FTL[585]: 2025-02-20 19:01:34.047 CET [585M] INFO: Parsed config file /etc/pihole/pihole.toml successfully
Feb 20 19:01:34 pihole pihole-FTL[585]: 2025-02-20 19:01:34.047 CET [585M] INFO: PID file does not exist or not readable
Feb 20 19:01:37 pihole pihole-FTL[585]: 2025-02-20 19:01:34.047 CET [585M] INFO: No other running FTL process found.
*** [ DIAGNOSING ]: Pi-hole FTL Query Database
-rw-r----- 1 pihole pihole 2.2M Feb 20 19:01 /etc/pihole/pihole-FTL.db
*** [ DIAGNOSING ]: Gravity Database
-rw-rw---- 1 pihole pihole 823M Feb 20 16:50 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
property value
version 19
gravity_restored false
abp_domains 1
updated 1740066436
gravity_count 10473114
Last gravity run finished at: Thu 20 Feb 16:47:16 CET 2025
----- First 10 Gravity Domains -----
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 0 Default 2025-02-20 15:14:18 2025-02-20 16:42:30 The default group
1 1 Whitelist 2025-02-20 16:41:43 2025-02-20 16:42:30 Alles aus
id type enabled group_ids domain date_added date_modified comment
1 0 1 0 click.asos.com 2021-01-12 10:03:48 2021-01-12 10:03:48 Added from Query Log
2 0 1 0 192.124.249.110 2022-06-08 22:02:59 2022-06-08 22:02:59 laserfiles
3 0 1 0 3axis.co 2022-06-08 22:06:21 2022-06-08 22:06:21
4 0 1 0 aliexpress.com 2022-09-29 11:50:48 2022-09-29 11:50:48
5 2 1 0 (.|^)www.binance.com$ 2023-07-14 16:36:02 2023-07-14 16:36:02 binance
7 0 1 0 coinbase.com 2024-03-07 22:54:12 2024-03-07 22:54:12 coin
8 0 1 0 www.coinbase.com 2024-03-08 22:59:10 2024-03-08 22:59:10 coin
9 0 1 0 status.coinbase.com 2024-03-10 16:08:21 2024-03-10 16:08:21
11 0 1 0 exceptions.coinbase.com 2024-04-26 17:02:41 2024-04-26 17:03:10
13 0 1 0 api.coinbase.com 2024-04-26 17:03:48 2024-04-26 17:03:48
14 0 1 0 login.coinbase.com 2024-04-26 17:04:50 2024-04-26 17:04:50
15 0 1 0 themis.binance.com 2024-06-03 18:57:02 2024-06-03 18:57:02 Added from Query Log
16 0 1 0 fstream.binance.com 2024-06-03 18:57:26 2024-06-03 18:57:26 Added from Query Log
17 0 1 0 nbstream.binance.com 2024-06-03 18:57:32 2024-06-03 18:57:32 Added from Query Log
21 0 1 0 native.binance.com 2024-06-03 18:58:14 2024-06-03 18:58:14 Added from Query Log
23 0 1 0 stream.binance.com 2024-06-03 18:58:18 2024-06-03 18:58:18 Added from Query Log
24 0 1 0 google.de 2024-09-13 21:12:17 2024-09-13 21:12:17 Added from Query Log
25 0 1 0 www.google.de 2024-09-13 21:13:40 2024-09-13 21:15:12
26 2 1 0 (.|^)www.youtube.com$ 2024-10-24 08:43:47 2024-10-24 08:43:47
28 0 1 0 cdp.cloud.unity3d.com 2024-12-08 16:27:37 2024-12-08 16:27:37 Added from Query Log
30 0 1 0 ca.iadsdk.apple.com 2024-12-08 19:41:33 2024-12-08 19:41:33 Added from Query Log
32 0 1 0 stats.gc.apple.com 2024-12-08 19:41:42 2024-12-08 19:41:42 Added from Query Log
35 0 1 0 region1.app-measurement.com 2024-12-08 19:42:03 2024-12-08 19:42:03 Added from Query Log
38 0 1 0 venetia.iad.appboy.com 2024-12-08 19:42:21 2024-12-08 19:42:21 Added from Query Log
40 0 1 0 fundingchoicesmessages.google.com 2024-12-08 19:42:26 2024-12-08 19:42:26 Added from Query Log
42 0 1 0 configv2.unityads.unity3d.com 2024-12-08 19:42:30 2024-12-08 19:42:30 Added from Query Log
43 0 1 0 app-measurement.com 2024-12-08 19:42:33 2024-12-08 19:42:33 Added from Query Log
44 0 1 0 accounts.google.com 2025-01-17 12:55:34 2025-01-17 12:55:34
*** [ DIAGNOSING ]: Clients
id group_ids ip date_added date_modified comment
1 1 E6:55:75:20:6D:C9 2021-01-09 20:35:01 2021-01-09 20:35:12 Izabela Handy
2 1 62:5C:79:85:32:14 2021-01-26 17:30:03 2021-01-26 17:30:25 S20 Izabela S20
3 1 16:D0:95:F4:FF:4C 2024-01-25 07:05:49 2024-01-25 07:06:22 Izabela S24+
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
-rw-rw---- 1 pihole pihole 5.3K Feb 20 18:41 /etc/pihole/dnsmasq.conf
hostsdir=/etc/pihole/hosts
no-resolv
port=53
server=1.1.1.1
server=1.0.0.1
cache-size=10000
localise-queries
log-queries
log-async
log-facility=/var/log/pihole/pihole.log
bogus-priv
use-stale-cache=3600
local-service
rev-server=192.168.178.0/24,192.168.178.1
server=/fritz.box/192.168.178.1
server=//192.168.178.1
domain=lan
local=/lan/
server=/test/
server=/localhost/
server=/invalid/
server=/bind/
server=/onion/
cache-rr=ANY
filter-rr=ANY
-rw-r--r-- 1 root root 439 Feb 20 15:14 /etc/pihole/logrotate
/var/log/pihole/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole/FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
/var/log/pihole/webserver.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-rw---- 1 pihole pihole 51K Feb 20 18:41 /etc/pihole/pihole.toml
[dns]
upstreams = [
"1.1.1.1",
"1.0.0.1"
] ### CHANGED, default =
CNAMEdeepInspect = true
blockESNI = true
EDNS0ECS = true
ignoreLocalhost = false
showDNSSEC = true
analyzeOnlyAandAAAA = false
piholePTR = "PI.HOLE"
replyWhenBusy = "ALLOW"
blockTTL = 2
hosts =
domainNeeded = false
expandHosts = false
domain = "lan"
bogusPriv = true
dnssec = false
interface = ""
hostRecord = ""
listeningMode = "LOCAL"
queryLogging = true
cnameRecords =
port = 53
revServers = [
"true,192.168.178.0/24,192.168.178.1,fritz.box"
[dns.cache]
size = 10000
optimizer = 3600
upstreamBlockedTTL = 86400
[dns.blocking]
active = true
mode = "NULL"
edns = "TEXT"
[dns.specialDomains]
mozillaCanary = true
iCloudPrivateRelay = true
[dns.reply.host]
force4 = false
IPv4 = ""
force6 = false
IPv6 = ""
[dns.reply.blocking]
force4 = false
IPv4 = ""
force6 = false
IPv6 = ""
[dns.rateLimit]
count = 1000
interval = 60
[dhcp]
active = false
start = ""
end = ""
router = ""
netmask = ""
leaseTime = ""
ipv6 = false
rapidCommit = false
multiDNS = false
logging = false
ignoreUnknownClients = false
hosts =
[ntp.ipv4]
active = true
address = ""
[ntp.ipv6]
active = true
address = ""
[ntp.sync]
active = true
server = "pool.ntp.org"
interval = 3600
count = 8
[ntp.sync.rtc]
set = false
device = ""
utc = true
[resolver]
resolveIPv4 = true
resolveIPv6 = true
networkNames = true
refreshNames = "IPV4_ONLY"
[database]
DBimport = true
maxDBdays = 91
DBinterval = 60
useWAL = true
[database.network]
parseARPcache = true
expire = 91
[webserver]
domain = "pi.hole"
acl = ""
port = "80o,443os,[::]:80o,[::]:443os" ### CHANGED, default = "80o,[::]:80o,443so,[::]:443so"
threads = 0
[webserver.session]
timeout = 1800
restore = true
[webserver.tls]
cert = "/etc/pihole/tls.pem"
[webserver.paths]
webroot = "/var/www/html"
webhome = "/admin/"
[webserver.interface]
boxed = true
theme = "default-auto"
[webserver.api]
max_sessions = 16
prettyJSON = false
pwhash = ""
totp_secret = ""
app_pwhash = ""
app_sudo = false
cli_pw = true
excludeClients =
excludeDomains =
maxHistory = 86400
maxClients = 10
client_history_global_max = true
allow_destructive = true
[webserver.api.temp]
limit = 60.000000
unit = "C"
[files]
pid = "/run/pihole-FTL.pid"
database = "/etc/pihole/pihole-FTL.db"
gravity = "/etc/pihole/gravity.db"
gravity_tmp = "/tmp"
macvendor = "/etc/pihole/macvendor.db"
setupVars = "/etc/pihole/setupVars.conf"
pcap = ""
[files.log]
ftl = "/var/log/pihole/FTL.log"
dnsmasq = "/var/log/pihole/pihole.log"
webserver = "/var/log/pihole/webserver.log"
[misc]
privacylevel = 0
delay_startup = 0
nice = -10
addr2line = true
etc_dnsmasq_d = false
dnsmasq_lines =
extraLogging = false
readOnly = false
[misc.check]
load = true
shmem = 90
disk = 90
[debug]
database = false
networking = false
locks = false
queries = false
flags = false
shmem = false
gc = false
arp = false
regex = false
api = false
tls = false
overtime = false
status = false
caps = false
dnssec = false
vectors = false
resolver = false
edns0 = false
clients = false
aliasclients = false
events = false
helper = false
config = false
inotify = false
webserver = false
extra = false
reserved = false
ntp = false
netlink = false
all = false
-rw-rw---- 1 pihole pihole 315 Feb 20 19:02 /etc/pihole/versions
CORE_VERSION=v6.0.1
CORE_BRANCH=master
CORE_HASH=9de976cb
GITHUB_CORE_VERSION=v6.0.1
GITHUB_CORE_HASH=9de976cb
WEB_VERSION=v6.0
WEB_BRANCH=master
WEB_HASH=a66d859a
GITHUB_WEB_VERSION=v6.0
GITHUB_WEB_HASH=a66d859a
FTL_VERSION=v6.0
FTL_BRANCH=master
FTL_HASH=eaa7dbb4
GITHUB_FTL_VERSION=v6.0
GITHUB_FTL_HASH=eaa7dbb4
*** [ DIAGNOSING ]: contents of /var/log/pihole
-rw-r----- 1 pihole pihole 58K Feb 20 19:02 /var/log/pihole/FTL.log
-----head of FTL.log------
2025-02-20 15:14:17.874 CET [1614M] INFO: ########## FTL started on pihole! ##########
2025-02-20 15:14:17.875 CET [1614M] INFO: FTL branch: master
2025-02-20 15:14:17.875 CET [1614M] INFO: FTL version: v6.0
2025-02-20 15:14:17.875 CET [1614M] INFO: FTL commit: eaa7dbb4
2025-02-20 15:14:17.875 CET [1614M] INFO: FTL date: 2025-02-18 17:19:26 +0000
2025-02-20 15:14:17.875 CET [1614M] INFO: FTL user: pihole
2025-02-20 15:14:17.875 CET [1614M] INFO: Compiled for linux/arm64/v8 (compiled on CI) using cc (Alpine 14.2.0) 14.2.0
2025-02-20 15:14:17.885 CET [1614M] INFO: Wrote config file:
2025-02-20 15:14:17.885 CET [1614M] INFO: - 152 total entries
2025-02-20 15:14:17.885 CET [1614M] INFO: - 151 entries are default
2025-02-20 15:14:17.885 CET [1614M] INFO: - 1 entry is modified
2025-02-20 15:14:17.885 CET [1614M] INFO: - 0 entries are forced through environment
2025-02-20 15:14:17.888 CET [1614M] INFO: Parsed config file /etc/pihole/pihole.toml successfully
2025-02-20 15:14:17.888 CET [1614M] INFO: PID file does not exist or not readable
2025-02-20 15:14:17.888 CET [1614M] INFO: No other running FTL process found.
2025-02-20 15:14:17.894 CET [1614M] INFO: PID of FTL process: 1614
2025-02-20 15:14:17.895 CET [1614M] INFO: listening on 0.0.0.0 port 53
2025-02-20 15:14:17.896 CET [1614M] INFO: listening on :: port 53
2025-02-20 15:14:17.898 CET [1614M] INFO: PID of FTL process: 1614
2025-02-20 15:14:17.899 CET [1614M] WARNING: No database file found, creating new (empty) database
2025-02-20 15:14:17.986 CET [1614M] INFO: Database version is 1
2025-02-20 15:14:17.986 CET [1614M] INFO: Updating long-term database to version 2
2025-02-20 15:14:18.003 CET [1614M] INFO: Updating long-term database to version 3
2025-02-20 15:14:18.018 CET [1614M] INFO: Updating long-term database to version 4
2025-02-20 15:14:18.031 CET [1614M] INFO: Updating long-term database to version 5
2025-02-20 15:14:18.068 CET [1614M] INFO: Updating long-term database to version 6
2025-02-20 15:14:18.082 CET [1614M] INFO: Updating long-term database to version 7
2025-02-20 15:14:18.101 CET [1614M] INFO: Updating long-term database to version 8
2025-02-20 15:14:18.144 CET [1614M] INFO: Updating long-term database to version 9
2025-02-20 15:14:18.165 CET [1614M] INFO: Updating long-term database to version 10
2025-02-20 15:14:18.199 CET [1614M] INFO: Updating long-term database to version 11
2025-02-20 15:14:18.220 CET [1614M] INFO: Updating long-term database to version 12
2025-02-20 15:14:18.241 CET [1614M] INFO: Updating long-term database to version 13
2025-02-20 15:14:18.265 CET [1614M] INFO: Updating long-term database to version 14
2025-02-20 15:14:18.282 CET [1614M] INFO: Updating long-term database to version 15
-----tail of FTL.log------
2025-02-20 19:01:36.117 CET [585M] INFO: 10000 queries parsed...
2025-02-20 19:01:36.300 CET [585M] INFO: 20000 queries parsed...
2025-02-20 19:01:36.469 CET [585M] INFO: 30000 queries parsed...
2025-02-20 19:01:36.513 CET [585M] INFO: Imported 32653 queries from the long-term database
2025-02-20 19:01:36.513 CET [585M] INFO: -> Total DNS queries: 32653
2025-02-20 19:01:36.513 CET [585M] INFO: -> Cached DNS queries: 18255
2025-02-20 19:01:36.513 CET [585M] INFO: -> Forwarded DNS queries: 12903
2025-02-20 19:01:36.513 CET [585M] INFO: -> Blocked DNS queries: 888
2025-02-20 19:01:36.513 CET [585M] INFO: -> Unknown DNS queries: 0
2025-02-20 19:01:36.513 CET [585M] INFO: -> Unique domains: 1988
2025-02-20 19:01:36.513 CET [585M] INFO: -> Unique clients: 40
2025-02-20 19:01:36.513 CET [585M] INFO: -> DNS cache records: 194
2025-02-20 19:01:36.513 CET [585M] INFO: -> Known forward destinations: 3
2025-02-20 19:01:37.477 CET [585M] INFO: FTL is running as user pihole (UID 999)
2025-02-20 19:01:37.479 CET [585M] INFO: Reading certificate from /etc/pihole/tls.pem ...
2025-02-20 19:01:37.480 CET [585M] INFO: Using SSL/TLS certificate file /etc/pihole/tls.pem
2025-02-20 19:01:37.481 CET [585M] INFO: Web server ports:
2025-02-20 19:01:37.481 CET [585M] INFO: - 80 (HTTP, IPv4, optional)
2025-02-20 19:01:37.481 CET [585M] INFO: - 443 (HTTPS, IPv4, optional)
2025-02-20 19:01:37.481 CET [585M] INFO: - 80 (HTTP, IPv6, optional)
2025-02-20 19:01:37.481 CET [585M] INFO: - 443 (HTTPS, IPv6, optional)
2025-02-20 19:01:37.481 CET [585M] INFO: Restored 0 API sessions from the database
2025-02-20 19:01:37.493 CET [585M] INFO: Blocking status is enabled
2025-02-20 19:01:37.594 CET [585/T593] INFO: Compiled 0 allow and 0 deny regex for 40 clients in 0.3 msec
2025-02-20 19:01:37.594 CET [585/T593] WARNING: List with ID 52 (https://zerodot1.gitlab.io/CoinBlockerLists/list.txt) was inaccessible during last gravity run
2025-02-20 19:01:37.596 CET [585/T593] WARNING: List with ID 53 (https://zerodot1.gitlab.io/CoinBlockerLists/list_browser.txt) was inaccessible during last gravity run
2025-02-20 19:01:37.598 CET [585/T593] WARNING: List with ID 54 (https://zerodot1.gitlab.io/CoinBlockerLists/list_optional.txt) was inaccessible during last gravity run
2025-02-20 19:01:41.687 CET [585/T592] INFO: Received 8/8 valid NTP replies from pool.ntp.org
2025-02-20 19:01:41.687 CET [585/T592] INFO: Time offset: 1.639396e+04 ms (excluded 0 outliers)
2025-02-20 19:01:41.687 CET [585/T592] INFO: Round-trip delay: 1.583511e+01 ms (excluded 0 outliers)
2025-02-20 19:01:58.081 CET [585/T592] INFO: Local time is too inaccurate, retrying in 600 seconds before launching NTP server
2025-02-20 19:01:58.597 CET [585/T595] ERROR: Cannot receive UDP DNS reply: Timeout - no response from upstream DNS server
2025-02-20 19:01:58.597 CET [585/T595] INFO: Tried to resolve PTR "1.1.1.1.in-addr.arpa" on 127.0.0.1#53 (UDP)
2025-02-20 19:02:00.609 CET [585/T595] ERROR: Cannot receive UDP DNS reply: Timeout - no response from upstream DNS server
2025-02-20 19:02:00.609 CET [585/T595] INFO: Tried to resolve PTR "1.0.0.1.in-addr.arpa" on 127.0.0.1#53 (UDP)
-rw-r----- 1 pihole pihole 901 Feb 20 19:01 /var/log/pihole/webserver.log
-----head of webserver.log------
[2025-02-20 15:14:18.791 CET 1614] Initializing HTTP server on ports "80o,443os,[::]:80o,[::]:443os"
[2025-02-20 15:25:54.022 CET 550] Initializing HTTP server on ports "80o,443os,[::]:80o,[::]:443os"
[2025-02-20 15:45:47.077 CET 586] Initializing HTTP server on ports "80o,443os,[::]:80o,[::]:443os"
[2025-02-20 15:57:15.367 CET 586] Initializing HTTP server on ports "80o,443os,[::]:80o,[::]:443os"
[2025-02-20 16:20:30.378 CET 587] Initializing HTTP server on ports "80o,443os,[::]:80o,[::]:443os"
[2025-02-20 16:36:23.981 CET 587] Initializing HTTP server on ports "80o,443os,[::]:80o,[::]:443os"
[2025-02-20 17:43:25.977 CET 588] Initializing HTTP server on ports "80o,443os,[::]:80o,[::]:443os"
[2025-02-20 18:41:07.639 CET 588] Initializing HTTP server on ports "80o,443os,[::]:80o,[::]:443os"
[2025-02-20 19:01:37.477 CET 585] Initializing HTTP server on ports "80o,443os,[::]:80o,[::]:443os"
-----tail of webserver.log------
*** [ DIAGNOSING ]: contents of /dev/shm
total 4.6M
-rw------- 1 pihole pihole 340K Feb 20 19:01 FTL-585-clients
-rw------- 1 pihole pihole 4.0K Feb 20 19:01 FTL-585-clients-lookup
-rw------- 1 pihole pihole 328 Feb 20 19:01 FTL-585-counters
-rw------- 1 pihole pihole 80K Feb 20 19:08 FTL-585-dns-cache
-rw------- 1 pihole pihole 16K Feb 20 19:08 FTL-585-dns-cache-lookup
-rw------- 1 pihole pihole 72K Feb 20 19:05 FTL-585-domains
-rw------- 1 pihole pihole 20K Feb 20 19:01 FTL-585-domains-lookup
-rw------- 1 pihole pihole 556K Feb 20 19:01 FTL-585-fifo-log
-rw------- 1 pihole pihole 88 Feb 20 19:01 FTL-585-lock
-rw------- 1 pihole pihole 8.0K Feb 20 19:01 FTL-585-overTime
-rw------- 1 pihole pihole 4.0K Feb 20 19:01 FTL-585-per-client-regex
-rw------- 1 pihole pihole 2.6M Feb 20 19:09 FTL-585-queries
-rw------- 1 pihole pihole 768K Feb 20 19:01 FTL-585-recycler
-rw------- 1 pihole pihole 144 Feb 20 19:01 FTL-585-settings
-rw------- 1 pihole pihole 120K Feb 20 19:06 FTL-585-strings
-rw------- 1 pihole pihole 28K Feb 20 19:01 FTL-585-upstreams
-rw-r--r-- 1 root root 121 Feb 20 19:01 /etc/resolv.conf
search fritz.box
nameserver 192.168.178.31
nameserver fd01:894e:741f:0:8fcd:9ee7:7f81:e71f
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
*** [ DIAGNOSING ]: Locale
LANG=en_GB.UTF-8
-rw-r----- 1 pihole pihole 23M Feb 20 19:09 /var/log/pihole/pihole.log
-----head of pihole.log------
Feb 20 15:14:18 dnsmasq[1614]: started, version pi-hole-v2.91rc4 cachesize 10000
Feb 20 15:14:18 dnsmasq[1614]: DNS service limited to local subnets
Feb 20 15:14:18 dnsmasq[1614]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN2 DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth DNSSEC loop-detect inotify dumpfile
Feb 20 15:14:18 dnsmasq[1614]: warning: no upstream servers configured
Feb 20 15:14:18 dnsmasq[1614]: using only locally-known addresses for onion
Feb 20 15:14:18 dnsmasq[1614]: using only locally-known addresses for bind
Feb 20 15:14:18 dnsmasq[1614]: using only locally-known addresses for invalid
Feb 20 15:14:18 dnsmasq[1614]: using only locally-known addresses for localhost
Feb 20 15:14:18 dnsmasq[1614]: using only locally-known addresses for test
Feb 20 15:14:18 dnsmasq[1614]: using only locally-known addresses for lan
Feb 20 15:14:18 dnsmasq[1614]: read /etc/hosts - 7 names
Feb 20 15:14:18 dnsmasq[1614]: read /etc/pihole/hosts/custom.list - 0 names
Feb 20 15:25:39 dnsmasq[1614]: exiting on receipt of SIGTERM
Feb 20 15:25:54 dnsmasq[550]: started, version pi-hole-v2.91rc4 cachesize 10000
Feb 20 15:25:54 dnsmasq[550]: DNS service limited to local subnets
Feb 20 15:25:54 dnsmasq[550]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN2 DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth DNSSEC loop-detect inotify dumpfile
Feb 20 15:25:54 dnsmasq[550]: warning: no upstream servers configured
Feb 20 15:25:54 dnsmasq[550]: using only locally-known addresses for onion
Feb 20 15:25:54 dnsmasq[550]: using only locally-known addresses for bind
Feb 20 15:25:54 dnsmasq[550]: using only locally-known addresses for invalid
-----tail of pihole.log------
Feb 20 19:09:30 dnsmasq[585]: cached a2047.mm2.akamai.net is 88.221.110.122
Feb 20 19:09:30 dnsmasq[585]: cached a2047.mm2.akamai.net is 2.16.100.169
Feb 20 19:09:30 dnsmasq[585]: cached a2047.mm2.akamai.net is 88.221.110.114
Feb 20 19:09:30 dnsmasq[585]: cached a2047.mm2.akamai.net is 88.221.110.88
Feb 20 19:09:30 dnsmasq[585]: cached a2047.mm2.akamai.net is 88.221.110.75
Feb 20 19:09:30 dnsmasq[585]: cached a2047.mm2.akamai.net is 88.221.110.80
Feb 20 19:09:30 dnsmasq[585]: query[A] video.bytedance.map.fastly.net from 192.168.178.102
Feb 20 19:09:30 dnsmasq[585]: cached video.bytedance.map.fastly.net is 146.75.122.73
Feb 20 19:09:30 dnsmasq[585]: query[AAAA] video.bytedance.map.fastly.net from 192.168.178.102
Feb 20 19:09:30 dnsmasq[585]: cached-stale video.bytedance.map.fastly.net is NODATA-IPv6
Feb 20 19:09:30 dnsmasq[585]: forwarded video.bytedance.map.fastly.net to 1.0.0.1
Feb 20 19:09:30 dnsmasq[585]: query[A] cl-gl179d406a.gcdn.co from 192.168.178.102
Feb 20 19:09:30 dnsmasq[585]: cached-stale cl-gl179d406a.gcdn.co is 93.123.17.253
Feb 20 19:09:30 dnsmasq[585]: forwarded cl-gl179d406a.gcdn.co to 1.0.0.1
Feb 20 19:09:30 dnsmasq[585]: query[AAAA] cl-gl179d406a.gcdn.co from 192.168.178.102
Feb 20 19:09:30 dnsmasq[585]: cached-stale cl-gl179d406a.gcdn.co is NODATA-IPv6
Feb 20 19:09:30 dnsmasq[585]: reply video.bytedance.map.fastly.net is NODATA-IPv6
Feb 20 19:09:30 dnsmasq[585]: reply cl-gl179d406a.gcdn.co is 93.123.17.253
Feb 20 19:09:30 dnsmasq[585]: reply cl-gl179d406a.gcdn.co is NODATA-IPv6
[βœ“] ** FINISHED DEBUGGING! **
Problem solved.
I found a good Guide here it worked for me.
