The issue I am facing: Pi-Hole Blocks apps like Disney Plus videos and Twitter images, even when its turned off and/or tons of whitelists have been added to avoid this.
Details about my system: Samsung Note 9, Samsung S21 Ultra
Apps affected: : Disney+ app, Twitter official app
What I have changed since installing Pi-hole: Set up the DNS servers (multiple combinations, same result), added default recommended online lists., whitelisted domains.
Issue: Seems NOBODY absolutely NOBODY has been able to solve this anywhere.
I have asked and browsed other similar request and almost every single thread ends empty, abandoned, closed or noone has any clue other than recommending to "check your tail log". Problem is that the tail log looks fine and I have added every whitelist recommended.
The behavior is similar to this: Pi-hole blocking Instagram even when not enabled
But on Twitter's official app.
The text and ads will display correctly, but images and videos will NOT LOAD until after a specified amount of time ( I suspect a timeout inside the app) which is around 1-2 minutes.
Disney plus at first did not load, but after a ton of whitelists. It goes to the main screen which is empty with the circling loading animation then throws an error "Unable to connect to Disney+"
Stopping pihole's dock resolves the issue and/or disconnecting from wifi and doing cell DATA mode also solves the issues. Both images loads instantly and Disney+ immediately loads the main screen.
This behavior happens EVEN when disabling pihole.
I have tried every DNS server that is listed as well with no change at all.
NOTE: this issue only affects my android phones.
I can see Disney+ and Twitter with no issue on Web with a PC.
Also I can see Twitter using a TweetDeck app or a Web version for Android.
All the android phones have no adblockers or anything else.
Pihole is installed in a server as a Docker. The requests are set to go to pihole's IP address from my Gaming WIFI router.
Any ideas what could be the cause? or what else to try to diagnose?
