websites such as www.reddit.com are not resolving.
The following are added to the white list as regex whitelist entries:
www.reddit.com$
www.rereddit.com$
Only default AdList is installed and is currently disabled.
PiHole is running off a Proxmox Container on Ubuntu 22.10 Standard.
No queries are shown as blocked.
Reviewing /var/log/pihole.log shows:
Feb 6 20:01:03 dnsmasq[1379]: query[A] styles.redditmedia.com from
Feb 6 20:01:03 dnsmasq[1376]: forwarded www.reddit.com to 1.0.0.1
Feb 6 20:01:03 dnsmasq[1376]: reply www.reddit.com is NXDOMAIN
Feb 6 20:01:03 dnsmasq[1379]: forwarded styles.redditmedia.com to 1.0.0.1
Feb 6 20:01:03 dnsmasq[1379]: reply styles.redditmedia.com is NXDOMAIN
Feb 6 20:01:03 dnsmasq[1380]: query[A] www.reddit.com from
Feb 6 20:01:03 dnsmasq[1380]: forwarded www.reddit.com to 1.0.0.1
Feb 6 20:01:03 dnsmasq[1380]: reply www.reddit.com is NXDOMAIN
Feb 6 20:01:03 dnsmasq[1381]: query[HTTPS] www.reddit.com from
Feb 6 20:01:03 dnsmasq[1377]: forwarded styles.redditmedia.com to 1.0.0.1
Feb 6 20:01:03 dnsmasq[1377]: reply styles.redditmedia.com is NXDOMAIN
Feb 6 20:01:03 dnsmasq[1378]: forwarded www.reddit.com to 1.0.0.1
Feb 6 20:01:03 dnsmasq[1378]: reply www.reddit.com is NXDOMAIN
Feb 6 20:01:03 dnsmasq[1381]: forwarded www.reddit.com to 1.0.0.1
Feb 6 20:01:03 dnsmasq[1381]: reply www.reddit.com is NXDOMAIN
Feb 6 20:01:04 dnsmasq[1382]: query[A] www.reddit.com from
Feb 6 20:01:04 dnsmasq[1383]: query[HTTPS] www.reddit.com from
Feb 6 20:01:04 dnsmasq[1382]: forwarded www.reddit.com to 1.0.0.1
Feb 6 20:01:04 dnsmasq[1382]: reply www.reddit.com is NXDOMAIN
Feb 6 20:01:04 dnsmasq[1383]: forwarded www.reddit.com to 1.0.0.1
Feb 6 20:01:04 dnsmasq[1383]: reply www.reddit.com is NXDOMAIN
Pinging reddit.map.fastly.net [151.101.193.140] with 32 bytes of data:
Reply from 151.101.193.140: bytes=32 time=36ms TTL=59
Reply from 151.101.193.140: bytes=32 time=33ms TTL=59
Reply from 151.101.193.140: bytes=32 time=34ms TTL=59
tracert www.reddit.com
Tracing route to reddit.map.fastly.net [151.101.129.140]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms
2 2 ms 1 ms 1 ms 10.0.0.1
3 9 ms 10 ms 11 ms 174.0.32.1
4 11 ms 10 ms 11 ms rc3no-be121-1.cg.shawcable.net [64.59.133.165]
5 12 ms 10 ms 11 ms 24.244.57.137
6 10 ms 11 ms 8 ms rc3so-be214.cg.shawcable.net [24.244.57.21]
7 32 ms 34 ms 32 ms rc1wt-be82.wa.shawcable.net [66.163.76.9]
8 * * * Request timed out.
9 34 ms 32 ms 33 ms 151.101.129.140
From the Pi-hole terminal try the same lookup via Pi-hole (which is sending to 1.0.0.1) and 1.0.0.1 directly. Also try a known blocked domain. Any differences between them all? Via Pi-hole (localhost):
flurry appears to work. Both commands for reddit.com returns nothing. I also tried via different DNSes (8.8.8.8, 8.8.4.4, etc.). All the same.
I did figure out the issue though. I run a few VLANs some of which have content filtering. So what was happening is the PiHole lives in an Network Management VLAN which has stricter content filtering than other VLANs, as the DNS request is sent into PiHole onto Network Management VLAN and then it is forwarded on it appears to originate from that VLAN and is then filtered.
To fix this I have changed the content filter to whitelist the PiHole.
