instead of lighttpd
[Hello, running windows 10 as my main pc, new pi4 with pihole only running on it, It's working fine except for my Bria softphone, when I have Pihole running, it kills it completely,and either have to shut down pihole or connect to my roomates wifi. I have whitelisted "phone.totalcloudpacs.com" and every variant I can think of ]
[Bria softphone will not connect at all]
