Expected Behaviour: zerotier should work ??
-Pi-hole v5.16.2
hello i need help
ON my OMV server I have zerotier installed as so I can remotely access my NAS but when ever I set pi hole as my DNS zerotier throws an error
"[Error connecting to the ZeroTier service: connection failed Please check that the service is running and that TCP port 9993 can be contacted via 127.0.0.1.]"
I have setup unbound
I followed this tutorial "https://www.crosstalksolutions.com/the-worlds-greatest-pi-hole-and-unbound-tutorial-2023/ "
This only happening when i using pi-hole as DNS
So any one have any workaround or fix to this problems
Thank you for the help
jfb
May 21, 2023, 1:57pm
2
Use these tools to determine the domains that Pi-hole is blocking that interfere with your desired content. Whitelist as necessary.
Block ads or fix broken sites
This FAQ is written in the context of finding out how to block an ad that isn't blocked automatically, but the same steps can be used to troubleshoot issues with sites that don't function properly. An example is that sometimes certain payment gateways try to collect metrics on the sale, but these domains are blocked by Pi-hole, so the payment cannot be processed. Also, some links send you through several referrers and if one of them is blocked, you may land on a b…
system
Closed
June 11, 2023, 1:58pm
3
