anowak
February 3, 2023, 8:27pm
1
Hi All,
I currently run PiHole as a docker container - see previous post Move from Full Pihole to Docker - #10 by anowak .
Understand PiHole was not intended for parental control but seemed to be the easiest way to prevent access to social media sites during school days.
The idea is to have a cron job run a script twice a week. Once on Monday morning and then on Friday afternoon. This script would enable or disable the gravity database blacklist table based on the comment with the word "script".
Cron Job.
00 6 * * Mon /opt/script/enabledisable_domainlist.sh
30 16 * * Fri /opt/script/enabledisable_domainlist.sh
#!/bin/bash
dayofweek="$(date +%w)"
# Monday
if [ ${dayofweek} = "1" ]; then
enabled=1
# Friday
elif [ ${dayofweek} = "5" ]; then
enabled=0
else
exit
fi
gravitydb="/etc/pihole/gravity.db"
# Enable/Disable blacklists with script in comment.
pihole-FTL sqlite3 ${gravitydb} "update 'domainlist' SET enabled = '${enabled}' WHERE comment like '%Script%';"
pihole restartdns reload-lists
Using docker-compose, I inject the initialisation script into /etc/cont-init.d to create the Cron jobs.
Initialisation script
#!/bin/bash
chmod +x /opt/script/enabledisable_domainlist.sh
crontab /opt/script/cron.txt
All seems to work, as the scripts are being triggered correctly and modify the DB.
The issue I am having is that PiHole, even though I have the blocklist enabled through the script - seem to ignore the changes until I manually restart the DNS Service or manually run *pihole restartdns reload-lists*.
anowak
February 3, 2023, 8:35pm
2
I created some logging to see what was happening and the script is being triggered and DB is being updated but it ignores the changes until I manually rung the restart?
root@pihole:/var/log# cat cron.log
Fri Jan 20 16:30:01 AEDT 2023: 0
Fri Jan 20 16:30:01 AEDT 2023: /etc/pihole/gravity.db
id type domain enabled date_added date_modified comment
1 3 (.|^)youtube.*$ 0 1661230986 1674192601 Script Block YouTube
2 3 (.|^)googlevideo.*$ 0 1661230986 1674192601 Script Block YouTube
3 3 .*youtu.?be.* 0 1661230986 1674192601 Script Block YouTube
4 3 (.|^)tiktok.*$ 0 1661230986 1674192601 Script Block TikTok
5 3 (.|^)tiktok.com$ 0 1661230986 1674192601 Script Block TikTok
6 3 (.|^)twitch.tv$ 0 1661230986 1674192601 Script Block Twitch
DNS Restarted
Mon Jan 23 06:00:01 AEDT 2023: 1
Mon Jan 23 06:00:01 AEDT 2023: /etc/pihole/gravity.db
1 3 (.|^)youtube.*$ 1 1661230986 1674414001 Script Block YouTube
2 3 (.|^)googlevideo.*$ 1 1661230986 1674414001 Script Block YouTube
3 3 .*youtu.?be.* 1 1661230986 1674414001 Script Block YouTube
4 3 (.|^)tiktok.*$ 1 1661230986 1674414001 Script Block TikTok
5 3 (.|^)tiktok.com$ 1 1661230986 1674414001 Script Block TikTok
6 3 (.|^)twitch.tv$ 1 1661230986 1674414001 Script Block Twitch
DNS Restarted
Fri Jan 27 16:30:01 AEDT 2023: 0
Fri Jan 27 16:30:01 AEDT 2023: /etc/pihole/gravity.db
1 3 (.|^)youtube.*$ 0 1661230986 1674797401 Script Block YouTube
2 3 (.|^)googlevideo.*$ 0 1661230986 1674797401 Script Block YouTube
3 3 .*youtu.?be.* 0 1661230986 1674797401 Script Block YouTube
4 3 (.|^)tiktok.*$ 0 1661230986 1674797401 Script Block TikTok
5 3 (.|^)tiktok.com$ 0 1661230986 1674797401 Script Block TikTok
6 3 (.|^)twitch.tv$ 0 1661230986 1674797401 Script Block Twitch
DNS Restarted
Mon Jan 30 06:00:01 AEDT 2023: 1
Mon Jan 30 06:00:01 AEDT 2023: /etc/pihole/gravity.db
1 3 (.|^)youtube.*$ 1 1661230986 1675018801 Script Block YouTube
2 3 (.|^)googlevideo.*$ 1 1661230986 1675018801 Script Block YouTube
3 3 .*youtu.?be.* 1 1661230986 1675018801 Script Block YouTube
4 3 (.|^)tiktok.*$ 1 1661230986 1675018801 Script Block TikTok
5 3 (.|^)tiktok.com$ 1 1661230986 1675018801 Script Block TikTok
6 3 (.|^)twitch.tv$ 1 1661230986 1675018801 Script Block Twitch
DNS Restarted
Fri Feb 3 16:30:01 AEDT 2023: 0
Fri Feb 3 16:30:01 AEDT 2023: /etc/pihole/gravity.db
1 3 (.|^)youtube.*$ 0 1661230986 1675402201 Script Block YouTube
2 3 (.|^)googlevideo.*$ 0 1661230986 1675402201 Script Block YouTube
3 3 .*youtu.?be.* 0 1661230986 1675402201 Script Block YouTube
4 3 (.|^)tiktok.*$ 0 1661230986 1675402201 Script Block TikTok
5 3 (.|^)tiktok.com$ 0 1661230986 1675402201 Script Block TikTok
6 3 (.|^)twitch.tv$ 0 1661230986 1675402201 Script Block Twitch
DNS Restarted
