Pihole Backups
Anyone else notice that pihole -a -t no longer works in version 6.0? I can't get cron'd backups to work now, is this intended?
Teleporter is now handled by pihole-FTL.
Use pihole-FTL --teleporter
You can run pihole-FTL -h to see all the new options.
Funny enough I just found it while I was looking through the help for that. However is there a way to make it a tar.gz, or is the new version .zip file only?
It can read .tar.gz files created by Pi-hole v5, but the new teleporter generates .zip files.
Thx, I already updated my script, and I am good to go, thank you for your help!
