PiHole API not accessible from network
I am trying to get Homarr integration to work with my PiHole, after a lot of trouble shooting I have noticed the API is accessible to local host but not to any other devices on my network. Is there a fix for this issue?
  • Operating System Raspbian
  • Hardware - Raspberry pi 5
API is not reachable from outside of local host
https://tricorder.pi-hole.net/Mq0pbNyr/
