Hello there,
I'm a new Pi-Hole user (just started using it yesterday) and I'd need some assistant if someone can help me out.
The initial plan was to install PH and on top of its blocking features to use it as my local dns server. The thing is I didn't know that I couldn't add Ports..
So I've looked around and asked and people told me I can use Apache with reserve proxy so I can start typing custom local domain names instead of IPs:Port.
The thing is I can't figure out how to do this and mix it with PH.
Any ideas/suggestions would be highly appreciated.
Thank you!
