Hi, I have the pihole in a docker on a mikrotik. It works to work, except that I can't get the hostname of the devices.
Before making two VLANs everything worked. Now I put the pihole in its own network 192.168.55.xx and I have two vlans 192.168.240.1 and 192.168.0.1
I have the checkbox:
-Respond only on interface eth0
-Never forward non-FQDN A and AAAA queries
-Never forward reverse lookups for private IP ranges
-Use DNSSEC
-Use Conditional Forwarding (with parameters of 192.168.0.1)
Thanks for the reply.
Here is the output of what you asked me, the only note that in the 192.168.55.0 network there is only the pihole, so I had to dig from the pihole.
Thanks again for the time you are giving me
PC-Surface IP: 192.168.0.xxx
dig PC-Surface @192.168.0.1
; <<>> DiG 9.16.45 <<>> PC-Surface @192.168.0.1
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 3864
;PC-Surface. IN A
;; Query time: 4 msec
;; SERVER: 192.168.0.1#53(192.168.0.1)
;; WHEN: Sat Feb 10 22:19:31 ora solare Europa occidentale 2024
;; MSG SIZE rcvd: 39
Alexa-View-Studio IP: 192.168.240.xxx
dig Alexa-View-Studio @192.168.240.1
; <<>> DiG 9.16.45 <<>> Alexa-View-Studio @192.168.240.1
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 2535
;Alexa-View-Studio. IN A
;; SERVER: 192.168.240.1#53(192.168.240.1)
;; WHEN: Sat Feb 10 22:48:34 ora solare Europa occidentale 2024
;; MSG SIZE rcvd: 46
pihole IP: 192.168.55.xxx
I'm not sure about the pihole hostname, because I use a script to create static DNS in mikrotik and in the 192.168.55.0 network I didn't put that script
dig pi.hole @192.168.55.1
; <<>> DiG 9.16.44-Debian <<>> pi.hole @192.168.55.1
Your router replies with NXDOMAIN, i.e. it does not know local hostnames.
Some routers may allow you to script their DHCP servers to register hostnames as presented during DHCP lease negotiation in their own DNS server, or switching DHCP server to dnsmasq, which does that automatically.
Alternatively, you could consider creating relevant respective DNS records directly in Pi-hole.
Thanks, but I don't understand why before creating the VLANs and I had the pihole and devices in a single network everything worked...
I use this script in Mikrotik to create static DNS and I haven't changed it:
# When "1" all DNS entries with IP address of DHCP lease are removed
:local dnsRemoveAllByIp "1"
# When "1" all DNS entries with hostname of DHCP lease are removed
:local dnsRemoveAllByName "1"
# When "1" addition and removal of DNS entries is always done also for non-FQDN hostname
:local dnsAlwaysNonfqdn "1"
# DNS domain to add after DHCP client hostname
:local dnsDomain "lan"
# DNS TTL to set for DNS entries
:local dnsTtl "00:15:00"
# Source of DHCP client hostname, can be "lease-hostname" or any other lease attribute, like "host-name" or "comment"
:local leaseClientHostnameSource "comment"
:local leaseComment "dhcp-lease-script_$leaseServerName_$leaseClientHostnameSource"
:if ($leaseClientHostnameSource = "lease-hostname") do={
:set leaseClientHostname $"lease-hostname"
} else={
:set leaseClientHostname ([:pick \
[/ip dhcp-server lease print as-value where server="$leaseServerName" address="$leaseActIP" mac-address="$leaseActMAC"] \
0]->"$leaseClientHostnameSource")
:local leaseClientHostnameShort "$leaseClientHostname"
:local leaseClientHostnames "$leaseClientHostname"
:if ([:len [$dnsDomain]] > 0) do={
:set leaseClientHostname "$leaseClientHostname.$dnsDomain"
:if ($dnsAlwaysNonfqdn = "1") do={
:set leaseClientHostnames "$leaseClientHostname,$leaseClientHostnameShort"
:if ($dnsRemoveAllByIp = "1") do={
/ip dns static remove [/ip dns static find comment="$leaseComment" and address="$leaseActIP"]
:foreach h in=[:toarray value="$leaseClientHostnames"] do={
:if ($dnsRemoveAllByName = "1") do={
/ip dns static remove [/ip dns static find comment="$leaseComment" and name="$h"]
/ip dns static remove [/ip dns static find comment="$leaseComment" and address="$leaseActIP" and name="$h"]
:if ($leaseBound = "1") do={
:delay 1
/ip dns static add comment="$leaseComment" address="$leaseActIP" name="$h" ttl="$dnsTtl"
this is the script of the 192.168.0.0 network
I use the same script on the 192.168.240.0 network with dnsDomain lan changed to dnsDomain domus
That would be out of Pi-hole's scope, so I can only try a guess:
If the scripts themselves would be operational, the most obvious explanation would be that those scripts never get triggered.
