PiNoob7
September 26, 2022, 6:54am
1
The site https://nextcloudpi.com/ should resolve and show the page.
OS = W10
Browser = Firefox
When navigating to the site I get "Hmm. We’re having trouble finding that site.".
Query Log shows SERVFAIL when navigating to the site.
Using Mobile Data fixes the issue, so I would assume its something to do with my PiHole and Unbound setup.
https://tricorder.pi-hole.net/Dhr9bhDt/
jfb
September 28, 2022, 2:18am
2
From the Pi terminal, what are the outputs of the following commands:
nslookup nextcloudpi.com 127.0.0.1
nslookup nextcloudpi.com 1.0.0.1
sudo grep nextcloud /var/log/pihole/pihole.log | tail -n15
PiNoob7
September 30, 2022, 9:13pm
3
Server: 127.0.0.1
Address: 127.0.0.1#53
Non-authoritative answer:
nextcloudpi.com canonical name = nextcloud.github.io.
Address: 185.199.109.153
Address: 185.199.108.153
Address: 185.199.111.153
Address: 185.199.110.153
Address: 2606:50c0:8002::153
Address: 2606:50c0:8001::153
Address: 2606:50c0:8003::153
Address: 2606:50c0:8000::153
Server: 1.0.0.1
Address: 1.0.0.1#53
Sep 30 22:05:53 dnsmasq[13773]: query[A] nextcloudpi.com from 127.0.0.1
Sep 30 22:05:53 dnsmasq[13773]: forwarded nextcloudpi.com to 127.0.0.1#5335
Sep 30 22:05:53 dnsmasq[13773]: reply nextcloudpi.com is
Sep 30 22:05:53 dnsmasq[13773]: reply nextcloud.github.io is 185.199.109.153
Sep 30 22:05:53 dnsmasq[13773]: reply nextcloud.github.io is 185.199.108.153
Sep 30 22:05:53 dnsmasq[13773]: reply nextcloud.github.io is 185.199.111.153
Sep 30 22:05:53 dnsmasq[13773]: reply nextcloud.github.io is 185.199.110.153
Sep 30 22:05:53 dnsmasq[13773]: query[AAAA] nextcloud.github.io from 127.0.0.1
Sep 30 22:05:53 dnsmasq[13773]: forwarded nextcloud.github.io to 127.0.0.1#5335
Sep 30 22:05:53 dnsmasq[13773]: reply nextcloud.github.io is 2606:50c0:8002::153
Sep 30 22:05:53 dnsmasq[13773]: reply nextcloud.github.io is 2606:50c0:8001::153
Sep 30 22:05:53 dnsmasq[13773]: reply nextcloud.github.io is 2606:50c0:8003::153
Sep 30 22:05:53 dnsmasq[13773]: reply nextcloud.github.io is 2606:50c0:8000::153
After trying to browse to that site:
sudo grep -i SERVFAIL -B10 /var/log/pihole/pihole.log | tail -20
Oct 2 17:04:42 dnsmasq[13773]: reply error is SERVFAIL
Oct 2 17:08:09 dnsmasq[13773]: reply piholediscourse.b-cdn.net is 143.244.38.137
Oct 2 17:08:09 dnsmasq[13773]: query[A] piholediscourse.b-cdn.net from 192.168.0.227
Oct 2 17:08:09 dnsmasq[13773]: cached piholediscourse.b-cdn.net is 143.244.38.137
Oct 2 17:08:12 dnsmasq[13773]: query[A] safebrowsing.googleapis.com from 192.168.0.227
Oct 2 17:08:12 dnsmasq[13773]: forwarded safebrowsing.googleapis.com to 127.0.0.1#5335
Oct 2 17:08:12 dnsmasq[13773]: reply safebrowsing.googleapis.com is 142.250.200.42
Oct 2 17:08:19 dnsmasq[13773]: query[A] nextcloudpi.com from 192.168.0.227
Oct 2 17:08:19 dnsmasq[13773]: forwarded nextcloudpi.com to 127.0.0.1#5335
Oct 2 17:08:19 dnsmasq[13773]: reply error is SERVFAIL
Oct 2 17:08:19 dnsmasq[13773]: query[A] www.nextcloudpi.com from 192.168.0.227
Oct 2 17:08:19 dnsmasq[13773]: forwarded www.nextcloudpi.com to 127.0.0.1#5335
Oct 2 17:08:20 dnsmasq[13773]: query[A] www.nextcloudpi.com from 192.168.0.227
Oct 2 17:08:20 dnsmasq[13773]: forwarded www.nextcloudpi.com to 127.0.0.1#5335
Oct 2 17:08:21 dnsmasq[13773]: reply error is SERVFAIL
That SERVFAIL
message is coming from Unbound.
If its easy to reproduce, you could try run Unbound manually with extra debug logging to see what is logged when encountering that SERVFAIL
message:
Run below to see the systemd journals for unbound:
journalctl --full --no-pager -u unbound
Run below to see if any mistakes in the config files:
unbound-checkconf
Run below ones to checkout extended debug logs:
sudo service unbound stop
sudo /usr/sbin/unbound -ddd -vvv -c /etc/unbound/unbound.conf
To stop debugging press CTRLc and run below to try start here up normal again:
sudo service unbound restart
Post relevant bits here for us to inspect?
> `journalctl --full --no-pager -u unbound`
-- Journal begins at Tue 2022-09-06 22:48:47 BST, ends at Tue 2022-10-04 17:04:57 BST. --
Sep 25 16:38:47 raspberrypi systemd[1]: Starting Unbound DNS server...
Sep 25 16:38:47 raspberrypi package-helper[11950]: /var/lib/unbound/root.key does not exist, copying from /usr/share/dns/root.key
Sep 25 16:38:47 raspberrypi unbound[11954]: [1664120327] unbound[11954:0] error: can't bind socket: Address already in use for ::1 port 53
Sep 25 16:38:47 raspberrypi unbound[11954]: [1664120327] unbound[11954:0] fatal error: could not open ports
Sep 25 16:38:47 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Sep 25 16:38:47 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Sep 25 16:38:47 raspberrypi systemd[1]: Failed to start Unbound DNS server.
Sep 25 16:38:47 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 1.
Sep 25 16:38:48 raspberrypi systemd[1]: Stopped Unbound DNS server.
Sep 25 16:38:48 raspberrypi systemd[1]: Starting Unbound DNS server...
Sep 25 16:38:48 raspberrypi unbound[12102]: [1664120328] unbound[12102:0] error: can't bind socket: Address already in use for ::1 port 53
Sep 25 16:38:48 raspberrypi unbound[12102]: [1664120328] unbound[12102:0] fatal error: could not open ports
Sep 25 16:38:48 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Sep 25 16:38:48 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Sep 25 16:38:48 raspberrypi systemd[1]: Failed to start Unbound DNS server.
Sep 25 16:38:48 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 2.
Sep 25 16:38:48 raspberrypi unbound[12247]: [1664120328] unbound[12247:0] error: can't bind socket: Address already in use for ::1 port 53
Sep 25 16:38:48 raspberrypi unbound[12247]: [1664120328] unbound[12247:0] fatal error: could not open ports
Sep 25 16:38:48 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 3.
Sep 25 16:38:48 raspberrypi unbound[12372]: [1664120328] unbound[12372:0] error: can't bind socket: Address already in use for ::1 port 53
Sep 25 16:38:48 raspberrypi unbound[12372]: [1664120328] unbound[12372:0] fatal error: could not open ports
Sep 25 16:38:48 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 4.
Sep 25 16:38:49 raspberrypi systemd[1]: Stopped Unbound DNS server.
Sep 25 16:38:49 raspberrypi systemd[1]: Starting Unbound DNS server...
Sep 25 16:38:49 raspberrypi unbound[12493]: [1664120329] unbound[12493:0] error: can't bind socket: Address already in use for ::1 port 53
Sep 25 16:38:49 raspberrypi unbound[12493]: [1664120329] unbound[12493:0] fatal error: could not open ports
Sep 25 16:38:49 raspberrypi systemd[1]: unbound.service: Main process exited, code=exited, status=1/FAILURE
Sep 25 16:38:49 raspberrypi systemd[1]: unbound.service: Failed with result 'exit-code'.
Sep 25 16:38:49 raspberrypi systemd[1]: Failed to start Unbound DNS server.
Sep 25 16:38:49 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 5.
Sep 25 16:38:49 raspberrypi unbound[12613]: [1664120329] unbound[12613:0] error: can't bind socket: Address already in use for ::1 port 53
Sep 25 16:38:49 raspberrypi unbound[12613]: [1664120329] unbound[12613:0] fatal error: could not open ports
Sep 25 16:38:49 raspberrypi systemd[1]: unbound.service: Scheduled restart job, restart counter is at 6.
Sep 25 16:38:49 raspberrypi systemd[1]: unbound.service: Start request repeated too quickly.
Sep 25 16:53:13 raspberrypi systemd[1]: Starting Unbound DNS server...
Sep 25 16:53:13 raspberrypi unbound[12919]: [12919:0] info: start of service (unbound 1.13.1).
Sep 25 16:53:13 raspberrypi systemd[1]: Started Unbound DNS server.
Sep 25 17:15:35 raspberrypi unbound[12919]: [12919:0] info: service stopped (unbound 1.13.1).
Sep 25 17:15:35 raspberrypi systemd[1]: Stopping Unbound DNS server...
Sep 25 17:15:35 raspberrypi systemd[1]: unbound.service: Succeeded.
Sep 25 17:15:35 raspberrypi systemd[1]: Stopped Unbound DNS server.
Sep 25 17:15:35 raspberrypi systemd[1]: Starting Unbound DNS server...
Sep 25 17:15:35 raspberrypi systemd[1]: Started Unbound DNS server.
> `unbound-checkconf`
unbound-checkconf: no errors in /etc/unbound/unbound.conf
Do you know of any way to save the debugging logs to a file? I have tried saving using >
, but that has not worked.
I have got the output for another command that @jfb recommended on the thread you posted.
> `sudo grep -v '#\|^` -R /etc/unbound/unbound.conf*`
/etc/unbound/unbound.conf.d/pi-hole.conf: logfile: "/var/log/unbound/unbound.log"
/etc/unbound/unbound.conf.d/pi-hole.conf: verbosity: 2
/etc/unbound/unbound.conf.d/pi-hole.conf: interface: 127.0.0.1
/etc/unbound/unbound.conf.d/pi-hole.conf: port: 5335
/etc/unbound/unbound.conf.d/pi-hole.conf: do-ip4: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-udp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-tcp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: do-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf: prefer-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf: harden-glue: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: harden-dnssec-stripped: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: use-caps-for-id: no
/etc/unbound/unbound.conf.d/pi-hole.conf: edns-buffer-size: 1232
/etc/unbound/unbound.conf.d/pi-hole.conf: prefetch: yes
/etc/unbound/unbound.conf.d/pi-hole.conf: num-threads: 1
/etc/unbound/unbound.conf.d/pi-hole.conf: so-rcvbuf: 1m
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 192.168.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 169.254.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 172.16.0.0/12
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: 10.0.0.0/8
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: fd00::/8
/etc/unbound/unbound.conf.d/pi-hole.conf: private-address: fe80::/10
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:forward-zone:
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf: name: "."
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf: forward-addr: 192.168.0.1
/etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf: auto-trust-anchor-file: "/var/lib/unbound/root.key"
Above three directives are messing up your setup forwarding everything to your router @192.168.0.1 instead of recursive lookups as is intended.
Try below:
First check if your effected by a recent change that was made in the openresolv package that comes with Pi-OS Bullseye:
pi@ph5b:~ $ lsb_release -d
Description: Raspbian GNU/Linux 11 (bullseye)
pi@ph5b:~ $ apt policy openresolv
openresolv:
Installed: 3.12.0-1
Does below file exist and what is its content?
cat /etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
If exists, delete it with below one because it configures Unbound to function like a regular forwarding DNS server instead of …
You can un-hash/comment below logfile
line and up verbosity
pi@ph5b:~ $ head /etc/unbound/unbound.conf.d/pi-hole.conf
server:
# edns-buffer-size: 1500
#edns-buffer-size: 1500
# logfile: "/var/log/unbound/unbound.log"
verbosity: 0
port: 5335
pi@ph5b:~ $ man unbound.conf
verbosity: <number>
The verbosity number, level 0 means no verbosity, only er‐
rors. Level 1 gives operational information. Level 2 gives
detailed operational information. Level 3 gives query level
information, output per query. Level 4 gives algorithm
level information. Level 5 logs client identification for
cache misses. Default is level 1. The verbosity can also
be increased from the commandline, see unbound(8).
Restart to apply:
A warning though, use this only to diagnose issues and dont leave it running for too long with upped verbosity.
This log file is not log rotated like the Pi-hole ones and many other log files are ... I believe.
So your disk could run full with logs.
EDIT:
pi@ph5b:~ $ ls -1 /etc/logrotate.d/
alternatives
apt
btmp
dpkg
lighttpd
monit
rsyslog
wtmp
pi@ph5b:~ $ cat /etc/pihole/logrotate
/var/log/pihole/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole/FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
As well as the steps you’ve linked, should I remove those three lines?
jfb
October 4, 2022, 6:15pm
11
Edit file /etc/resolvconf.conf
and comment out the last line which should then read:
#unbound_conf=/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
Delete the unwanted unbound configuration file:
sudo rm /etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
Restart unbound:
If you look closely, this should have been sorted already when followed the steps:
My mistake, I had not read the thread yet, but it has worked! Thanks @jfb and @deHakkelaar https://nextcloudpi.com/ now loads.
Just out of curiosity, did I miss a crucial step in the unbound setup docs that caused the line to not be commented out.
jfb
October 4, 2022, 6:28pm
14
No. This is an oddity of Bullseye OS.
jfb:
Bullseye OS
Worth adding a section to the docs about this?
system
Closed
October 25, 2022, 6:32pm
17
