Pihole and TV platforms
Good evening, I would like your help.
I have set up a pihole with Rpi 5, and it works satisfactorily with YouTube ads.
However, there is a problem with the following platforms: Cosmote TV, Ant1+, and Ertflix cannot connect to the Internet.
Netflix works normally after excluding the domain *.netflix.com in pihole, but it did not work before that.
I tried to exclude the domains that appear in the qwery log when I select one of these platforms, but nothing happened.
mwapi-prod.cosmotetvott.gr
pn.cosmotetvott.gr
prod.antennaplus.gr
antenna-ott.brightcove.services
api.app.ertflix.gr
*The applications are installed on Xiaomi Mi Box S 3rd Gen.
Any help would be appreciated, thank you.
Translated with DeepL.com (free version)
